10-23-2008, 11:55 PM
#16
Don't bother drilling, just try to "pull" it out with a putty knife. A couple of the plastic nipples will shear when you try to take it out.
I did this ages ago and have been getting 20-21 MPG from the trip computer when I commute in So Cal Traffic (slow & go). That translates to 18-19 MPG via the real world odometer readings, traffic and some city driving. I thnk there's more difference between 3/4 and full throttle... kind of hard to explain. Also, I got in the habit of turning off the a/c whenever I get in the truck.
Now I'll wait for the same response telling me how I have no proof that removing the filter improves gas mileage or power... Toyota engineers are all knowing, and how I kill four thousand infants with the additional polution I contribute to the enviornment.
Sean
2007 V8 limited 4x4
SAW C/Os
ED sub in stock enclosure...
10-24-2008, 12:48 AM
#17
Originally posted by CJ3Flyr
Very cool... I might give it a go The amount of HC that can escape from a sequential fire FI that shuts the injectors off when the engine shuts off has got be near 'nil.
Sean
The problem is not with one or two people removing smog control devices. It has to do with clean air requirements. In my field, CARB requires, we install special valves in VOC service. This used to be limited to lethal services only. (For example...something that might cost $100 bucks easily costs $1000+ for a 1" valve) If it is just one person (or one valve) it isn't that big of an issue. But when you multiply that over 10,000 4runners (or piping connections,) the fugitive emissions add up FAST! Fortunately or Unfortunately (depending how you want to see it) it is a part of the system we have. There doesn't seem to be much you can do about it anymore unless you own a vehicle older than 1978/79 (something like that) you don't have to worry about anything and you can pollute to your hearts content!
My Rig: 2007 Limited V8 (Nautical Blue) | Front Lift & Sliders: Downey Kit | Rear Lift: OME 896 (Heavy with Nitro Sport) |Skids : BudBuilt | Bullbar : Shrockworks| Winch : Warn 9.5XP Amsteel Line | Lights : PIAA 580s | Tires : 265/65 BFG TA/KOs on 18" Stock Wheels | Audio : VaisTech Video iPOD Kit for Factory Nav | Newest Addition - BajaRack | June T4ROTM (Thanks guys!)
10-24-2008, 01:09 PM
#18
Super Moderator
Super Moderator
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
10-24-2008, 04:02 PM
#19
Thanks! The mpg thing is what I was wondering about. You rig had tires and a lift. That mileage is very respectable. I don't have the stink bad but it's enough that I'm going to give removal of the HCF a try.
I did see the Sequoia, very cool
Hey thanks!
Just did this mod to the sequoia as well Once again it seems to have stepped up the throttle response (not that it really needed it ) but it also made it so I can actually hear the engine. Now to get an exhaust put on to wake up the neighbors.
Sold out to the Sequoia 10/08
Will miss my 2005 Titanium 4WD SR5 V6
Mods and Accessories:
22" Xpower Revolver Rims wrapped in 285/45/22 Nitto Dune Grapplers. Cornfed 3" Front / 2" Rear Spacer Lift. Halo Projector Headlights. 6000k. HIDs Low Beam & Fog. Chrome Door Handles. Custom Iron Cross Grill. Led Running Board Lights. All bulbs replaced with Leds. Bumper Light Mod (Running Lights only). Map light mod. Constant Power 12V Outlets. Tinted Front Windows to Match Stock. Pioneer DEHP7600-MP HU. JBL 400w Amp. Eclipse 12" in Bandpass box. K&N Drop In. Flowmaster SUV 50 Series. Chrome Taillights. Added 12v Outlet to Center Console. Hayden 679 Trans Cooler. Tekonsha Prodigy Brake Controller. Hidden Hitch Class III WD Hitch. Air Lift 1000's. Load Controller II
10-24-2008, 08:27 PM
#20
Looking back, and exacto knife around the edge of the filter media would work too.
Just leave in the filter frame.
It appears that at 4000 to the redline is more responsive.
Seems to be a bit more air intake sound at WOT.
This may have provided a couple of ponies above 4500.
Less restriction is a good thing. Good mod. Do it gang.
I wonder if this reduces the converter smell for those who have it?
07' Sport
4WD
4.7L
18.7 mpg
Awesome!
10-25-2008, 08:42 AM
#21
xacto knife worked for me just left the frame there.
'14 4Runner SR5 Premium Bilstien 1500's, Airlift bags, 275 70R 17 Cooper AT3's,Power Stop rotors & brakes, Xenon Depot 9005 Extreme Pro LED, Morimoto H11 2Stroke 2.0, AEM dry flow filter, Magnaflow exhaust, Sprint Booster
'19 Tundra Limited CM, 2.5/1 Bilsteins 5600's, Cooper AT3 275 70 18 on Method NV305's
'12 Subaru Legacy Limited
10-27-2008, 01:56 PM
#22
I am guessing this would void your emissions warranty if the dealership bothered to check. Not that I am one to judge. I put a CAI on my 04 @ 20k miles. I have almost 90k now and have never had a problem passing North Carolinas yearly emissions/Safety check. I do have a CARB sticker under the hood for mine.
K&N's kits did have a C.A.R.B. approval at one time, but I think they pulled it back since you can not find a 57 series (FIPK) kit on there web site anymore for the 4th gen 4Runners. The 63 series kit (Aircharger) are not 50 state emissions legal like the 57 series usually are.
04 4x2 Black SR5 V-6, Bilstein 5100s @ .85 w/ Moog 81088 springs 2.75" lift front, FJ Rear Springs, 265/70s, Scion T1807 HU w/ AUX input cable. 151K miles. 07/08/14 Traded-in.
08 4x4 Salsa Red SE V-6 Daystar 2.5/1.5", 265/70 Revo 2s, SpiderTrax. Traded-in on 09/14/11 W/55k miles for 08 Sequoia 5.7L
10-27-2008, 03:01 PM
#23
Super Moderator
Super Moderator
I am sure you're right.
The good news for the V6 is that it's listed as a separate part for around $35. So if V6 4Runner showed up at the dealer minor evidence of tampering is explainable... "Oh I changed it and couldn't get the little buttons to work right that's why it looks like it was messed with... " Not that that makes it right.
Chris
10-28-2008, 01:51 AM
#24
we've been debating about these things for years here. Do a search and I'm sure you'll find several threads, at least two of which I have taken part in. I think the general consensus is that we aren't sure removing it does anything, either good or bad. I haven't taken mine out, even though I've had it open and looked at it several times. I think someone talked about taking an air compressor to it and noticing that it blocked the airflow significantly. I'd love to see a dyno on this. Two before, and two after. Still not sure if I'll take it out.
10-31-2008, 07:27 PM
#25
Super Moderator
Super Moderator
I took mine out a couple of days ago.
1) It's only been two days but the onboard lie-o-meter has settled at 1.4mpg higher than it was.
2) As previously reported; riding with the back window down is MUCH better. It is not perfect, it can't be without installing a side exit exhaust but it's way better in terms of sulfur and ammonia smell. Why? No clue...
Thanks LV4R
Chris
11-04-2008, 07:18 PM
#26
Thanks LV4R
No probs! Believe it or not I actually have the sulfur smell with the Sequoia too. It's not as bad as the 4r though thankfully.
11-06-2008, 05:57 PM
#27
I just removed mine... 1.6 avg mpg better on the factory display.
04 SR5 4x4 v6
Urban Runner Bars & Rack-2/3 CF Lift-HID Converted Head/Fog Lights-JDM Taillights-Misc parts 18" Helo HE835 Black/Polished Wheels 265/70/18 Nitto Terra Grappler Tires
11-24-2008, 02:50 AM
#28
Real Name: Phil
Real Name: Phil
Just did this. The computer recognized an immediate improvement. The range went from 253 to 276 immediately (3/4ths). I then proceeded to fill up the tank. Range was 394! Woo! I just filled up Friday and the range was 352!
Can't really tell MPG until next week.
Was getting 16 MPG.
'95 4Runner V6 4WD 168k SOLD 10/11
'98 Honda Accord LX 4-Cyl 216k
'04 4Runner V6 4WD 157k
Denso Iridium Plugs - Synthetic Fluids - Python Alarm W/Remote start - 265/65/17 REVO's - Silverstars - Ash Tray Mod - WeatherTech Mats
12-13-2008, 05:45 PM
#29
For those decide to try to experience... Please use the old school away to check your mileage meaning filling up the gas tank at the same gas station (at the same station twice), write down the mileage...
This would be a more accurate way of checking the gas mileage otherwise it could be that the sensor is confused. I don't know how Toyota do it exactly but it's only a rough estimate and my guess is that any mod to the engine would require the sensor to be recalibrate.
2003 V8 Limited
12-15-2008, 09:31 AM
#30
Super Moderator
Super Moderator
The onboard does give a quick, accurate indication of the trend based on my experience.
The old school way reveals an average of .8mpg better over quite a while now. The onboard has settled down to indicate an average of .9-1.0 better. Once again the onboard shows 10-15% optimistic.
Chris
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
