08-09-2008, 06:02 PM
Observations after removing the hydrocarbon filter
So I removed the HCF about a month ago. I have a few observations that I thought I would share. First one is that the sulfur smell seems to have been reducecd significantly. I have done the TSB for it and it really didnt do much. It seems that now I can actually punch it and not have to worry that I will pass out from the smell.
My second observation happened when I went to Huntington Beach, CA which is about 290 miles from here in Las Vegas. I had 7 people on the way there in the 4R including our luggage and a hitch luggage carrier. 5 on the way back. Did about 70 mph avg and got around 17 mpg. I had over a quarter tank when I got back to Vegas which has never happened before on a trip to Cali.
No I have not done any scientific calculations on my mpgs before and after the removal. These are simply observations. The car also does not rev up then drop down when I start it.
Anyone else removed the HCF and noticed any changes?
Sold out to the Sequoia 10/08
Will miss my 2005 Titanium 4WD SR5 V6
Mods and Accessories:
22" Xpower Revolver Rims wrapped in 285/45/22 Nitto Dune Grapplers. Cornfed 3" Front / 2" Rear Spacer Lift. Halo Projector Headlights. 6000k. HIDs Low Beam & Fog. Chrome Door Handles. Custom Iron Cross Grill. Led Running Board Lights. All bulbs replaced with Leds. Bumper Light Mod (Running Lights only). Map light mod. Constant Power 12V Outlets. Tinted Front Windows to Match Stock. Pioneer DEHP7600-MP HU. JBL 400w Amp. Eclipse 12" in Bandpass box. K&N Drop In. Flowmaster SUV 50 Series. Chrome Taillights. Added 12v Outlet to Center Console. Hayden 679 Trans Cooler. Tekonsha Prodigy Brake Controller. Hidden Hitch Class III WD Hitch. Air Lift 1000's. Load Controller II
08-09-2008, 10:43 PM
Super Moderator
Super Moderator
Re: Observations after removing the hydrocarbon filter
HCF? The filter in the vapor tank (charcoal canister in the old school vernacular)? Having an effect on the smell is interesting.
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
08-11-2008, 12:09 PM
Re: Re: Observations after removing the hydrocarbon filter
The Hydrocarbon filter, I used HCF for short . It is the filter after the air filter that requires removing the divets to get it out.
08-11-2008, 01:23 PM
Super Moderator
Super Moderator
Got it, thanks. I did not understand it's purpose. Does it have a replacement schedule? Did you just decide give it a try outta the blue or did you read of someone doing it on a FJC or something?
Chris
08-11-2008, 03:49 PM
I actually was reading on tundrasolutions that guys were doing this with their tundras and seeing positive results. I figured why not try it. I guess it would be the same thing as using an aftermarket cold air intake. The filter is to prevent the escape of unburnt fumes after turning the engine off.
08-11-2008, 04:00 PM
Super Moderator
Super Moderator
Very cool... I might give it a go The amount of HC that can escape from a sequential fire FI that shuts the injectors off when the engine shuts off has got be near 'nil.
Chris
08-14-2008, 10:59 AM
I removed my filter box and took a look at the filter.
Looks EZ to remove but I have not done it yet.
IMO it looks like it would restrict airflow.
07' Sport
4WD
4.7L
18.7 mpg
Awesome!
10-19-2008, 07:39 AM
Super Moderator
Super Moderator
Bump- LV4R, update please
Chris
10-19-2008, 11:17 AM
did you drill the divets out ? was the air box still mounted on the engine or did you remove it to take the filter out? i was wondering about that filters purpose. thanks for the info.
'14 4Runner SR5 Premium Bilstien 1500's, Airlift bags, 275 70R 17 Cooper AT3's,Power Stop rotors & brakes, Xenon Depot 9005 Extreme Pro LED, Morimoto H11 2Stroke 2.0, AEM dry flow filter, Magnaflow exhaust, Sprint Booster
'19 Tundra Limited CM, 2.5/1 Bilsteins 5600's, Cooper AT3 275 70 18 on Method NV305's
'12 Subaru Legacy Limited
10-19-2008, 01:00 PM
Remove the box, set on a bench and drill em' out.
Thats what I will do when I get around to it.
That filter has to resticting some air.
Fook the carbon foot print
07' Sport
4WD
4.7L
18.7 mpg
Awesome!
10-20-2008, 04:01 AM
Banned
Banned
pics please?
10-20-2008, 10:27 AM
So, am I correct in assuming that the HC filter would be eliminated by installing an aftermarket cold air intake anyway?
2008 Toyota 4Runner SR5 V6 4x4
2005 Dodge Ram 1500 QCSB 4x4 HEMI
1998 Yamaha Virago VX1100 Special
10-20-2008, 05:13 PM
Absolutely. Pretty easy removal and you can do it with it still on the engine. I just drilled one of the lower ones out then yanked it out.
10-20-2008, 05:15 PM
Bought a new Sequoia over the weekend and sold the 4runner . The only thing I can tell you is that my mileage seems to have stayed the same with a possible increase in power.
10-20-2008, 05:23 PM
I removed mine today.
EZ to do and took less than 30 minutes.
I removed the housing and drilled out the plastic rivets.
Drill only .125" deep so you don't ruin the housing.
I then just used an exacto knife to shear off the drillled plastic rivet.
EZ, EZ to do.
Seems like better throttle response from 60mph +
Too soon to tell if mpg will increase
07' Sport
4WD
4.7L
18.7 mpg
Awesome!
