Old 09-01-2008, 09:40 PM #1
crosso crosso is offline
crosso is an unknown quantity at this point
Air Conditioning
I purchased a 2003 4Runner a couple of months ago....and I love it. However, I am having a little problem with the air conditioning. Sometimes it works, other times it doesn't. It will suddenly stop blowing cold air and the AC indicator will flash. According to the manual, this flashing indicates a problem in the system. If I shut it down for awhile. then hit the AUTO button again, it will often fire back up...blowing reasonably cold air. I have an extended warranty for some of the bigger parts, ie. compressor. Anyone run into this same problem?
crosso is offline   Reply With QuoteReply With Quote
Old 09-01-2008, 11:47 PM #2
drmorbius's Avatar
drmorbius drmorbius is offline
drmorbius is on a distinguished road
drmorbius's Avatar
Re: Air Conditioning
You need to buy the upgraded compressor relay. Do a search, this is a well documented problem.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
drmorbius is offline   Reply With QuoteReply With Quote
Old 09-02-2008, 11:33 PM #3
Uneek's Avatar
Uneek Uneek is offline
Super Moderator
Uneek is on a distinguished road
Super Moderator
Uneek's Avatar
Here's that thread. If you have the Platinum warranty, you should be covered. I don't know about the Gold warranty though. Reference the TSB in the thread, EL011-05, to point the dealer in the right direction.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
Uneek is offline   Reply With QuoteReply With Quote
Old 11-26-2010, 12:47 PM #4
dancar1996 dancar1996 is offline
dancar1996 is on a distinguished road
actually i ran into this same problem yesterday with my V8 T4R2003 and as i was reading some older posting,after i pop up my hood i checked the heater and magnetic clutch relay,because if you push the auto control of the ac it will come on but a moment later the ac indicator light flashing and wont go away and it will blows hot air.first thing that i did was checked the relay as i mentioned above try to shake relays they might be sticking and after i did i start the engine and turn ac control to auto mode and everything works fine.hope this will help and if it doesnt work you may need to check your relays or replace it not that expensive cost less than $50
dancar1996 is offline   Reply With QuoteReply With Quote
Air conditioning trouble-shooting Thai Problems & Warranty Issues 1 05-23-2011 11:22 PM
Cold Air Intake BFLAN 5th gen T4Rs 15 01-28-2011 01:12 AM
2003-up Range Rover (RR3) Thai Comparisons & Reviews 50 06-09-2006 08:32 AM
K&N air filters Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 3 10-02-2003 09:26 AM
