11-02-2008, 03:35 PM
Tire Valve Stem Caps--Orginal OEM vs Costco Green!
Hey Folks,
Just had my summers changed to winters. Costco, in all of it's wisdom, threw away the original black flat metal(?) caps and put on the ugly green ones.
Ummm is this a problem? I argued with the tire tech that it's better for the TPMS with the original, but he started mentioning something about Galvanic rust?
Any insight?
2007 4runner Sport Edition V6, Black.
2011 BMW 335Xi Special Edition, Jerez Black.
11-02-2008, 04:39 PM
go back and tell them you want what you had on the vehicle when you came in. Their bust on throwing them away.
I had a nice set of chrome ones on my sporttrac and a tire shop lost one of them and replaced it with a black one. I made them buy a set of the chrome ones and give me just one.
2008 SR5 V6 2WD (Sold)
2009 Tundra DC TRD 4x4(Sold)
2013 Tundra DC TRD 4x4
2013 4Runner Limited
11-02-2008, 05:12 PM
Super Moderator
Super Moderator
Our local dealer has plastic blue one's on all the 4R's .
< 2016 Classic Silver TE w/KDSS >< Bone stock at the moment >
11-02-2008, 06:32 PM
i too would get the metal ones back.....
1987 dlx
SHAKKA
Originally Posted by SCRunner12
Where's T?@\7 at? He's always talking about bong rips in his posts. I thought he would be all over this post by now.
11-02-2008, 07:36 PM
What about all the Galvanic Rust crap that the tire tech was spewing off about?
Are the orignals actually metal?
Guess I'll stick with the green for the winter..and then buy some originals in the summer...maybe some nicer ones. What a hassle for just a few bucks. Still just pisses me off.
11-02-2008, 07:52 PM
The original caps are some sort of metal, and they can corrode and seize up in areas where road salt is used. I think a lot of members have switched to plastic ones for this reason. Honda went so far as to recall their metallic caps a few years ago.
The caps have nothing to do with the operation of the TPMS. The sensors are part of the valve stem assembly, but the caps don't do anything except keep dirt out of the valve.
Still, it's disrespectful for the tech to just throw away something that was on the car and was in perfect working order. I'd complain to management about the principle. That makes me wonder if he realized the valve stems had TPMS sensors. If one of those got messed up through carelessness, then you're talking about big dollars.
2006 Limited V8 4x4, Shadow Mica/Stone
11-02-2008, 08:07 PM
The reason why they are green is because your tires have been filled with nitrogen.
11-02-2008, 08:10 PM
good to know!
Too bad they arent the green ones that LIGHT UP! ;)
1987 dlx
SHAKKA
11-03-2008, 09:56 AM
I switched mine to black plastic last year. The aluminum/tin valve caps that came with it were getting really difficult to remove every time I wanted to deflate/inflate the tires.
11-03-2008, 10:22 AM
Costco checked and rotated my tires for free. My concern is, they maybe strict and may refuse to service your tires if they don't see the "green caps" and you will lose your "Costco Tire Warranty". You can put chromes on, and keep the greens when you need to avail Costco free services incl. tire repairs and replacements if under warranty period.
Costco Advantage:
"It also includes some Lifetime services that extend throughout the life of the tires you purchase. (Some limits may apply). These Lifetime services include inflation pressure checks, tire balancing, tire rotations, as well as flat repairs.
Upon the service of your tires our Michelin Certified Tire Technicians will also install new rubber valve stems (Note TPMS valve stems and accessories will be an additional charge). Additionally, we inflate your tires with nitrogen, not compressed air. Nitrogen retains tire pressure better over time than compressed air, which can positively impact the life of your tires, as well as the fuel economy of your vehicle. We offer this service FREE OF CHARGE."
2017 SR5 4WD - Blistein 5100s - Cooper AT3s - HID Lows - LED Fogs
2003 SR5 V8 - Sold
11-03-2008, 11:01 AM
Not to hijack but...I have had a very slow leak in one of my valves. Seems to be a problem with that pin in the middle of the valve, because when I check or add the air will really leak through the valve afterword. Tire shop says to change valve I must get a new TPMS? I went with a metal cap with an o-ring which seems to be holding. So new valve = TPMS= big $. Is that true?
11-04-2008, 01:34 AM
I'm just gonna leave it, because of our harsh, cold, snowy winters, the metal on metal does scare me a bit.
For the summer, I'll pick up a nice set of chromes. Few dollars, oh well.
Considering costco only charges 33 bucks for seasonal changeover, and pretty much everyone else charges 80-100, I'll suck up the extra few dollars just this one time.
11-04-2008, 08:28 AM
next time you go in there, id just take the caps off before i let them pull my car in there..... then youll have your original caps, and keep the green ones as spares,or if someone else needs one.... all caps are the same size.
Black 97 V6 4x4
285/70/17 Trail Grapplers Tundra 10 Spokes, spidertrax
3" Toytec, 5% tint
11-04-2008, 09:44 AM
Originally posted by 4boer
Not to hijack but...I have had a very slow leak in one of my valves. Tire shop says to change valve I must get a new TPMS?
If you have to replace the valve stem, then yes, you have to buy the whole thing. The valve stem and the TPMS sensor is one integrated unit. You'll also have to have a Toyota dealer re-program the computer with the ID number of the new transmitter. This is probably a job best done by a Toyota dealer and not a tire place.
11-04-2008, 12:29 PM
Super Moderator
Super Moderator
I have nice metal ones but if you remove them regularly as I do when i check my pressure once a month they should never seize up.
The reason most tire places switch over to plastic is because the common person doesn't do this and sometimes goes months w/o removing them thus they seize up.
2010 Lexus RX350
'99 4RUNNER Highlander SR5 4wd *Sold
