Super Moderator
Super Moderator
Re: Miles per gallon
Originally posted by Iron Clad Lou
I have upsized my tires from 265/65/17 to 265/70/17...how do I adjust the onboard miles per gallon ticker? do I add a percentage? I know the speedometer reads 2 mph less, just wondering if I should add or subtract from the computer mpg...
I used two different GPS's and did the following:
1) I reset the tripmeter on the T4R and the warmed up, locked on GPS. I drove exactly one mile and noted the difference. Even with stock tires I discovered the tripmeter under-reported by .025%. So if the T4R tripmeter indicates 100.0 miles I have travelled 102.5mi. When I calculate mpg I just take my tripmeter miles X 1.025/gallons. The on-board mpg readout is famous for being optimistic. I read, here, that some of the people actually saw it get closer to correct with slightly oversized tires
2) I then compared indicated speed to GPS speed and discivered it was perfect. I mean I couldn't see the slightest difference between the two.
FYI- The Garmin and the Magellan showed no difference in speed indication or difference in distance travelled. Over time I have seen my 1.025 to be fairly accurate. When I road trip with the GPS at 100miles on the tripmeter the GPS shows 102.4-102.6. Local driving is 'off' because I am usually rolling by the time the GPS finds itself.
No GPS? Next time you're on the highway reset the tripmeter and compare it to the mile markers.
Hope that helps.
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
