When I was installing the Schrockworks bumper, I was installing the new hella turn signal lights and I had the blinkers on when I was hooking up the lights to make sure the wires were right and when I did that the signals stop working so I assumed it was a easy fix and it was probably just a fuse so I checked the fuse panel and there is no fuse for the turn signals, and I checked every fuse in the dash and they all work, does anyone have any idea of what maybe the problem and what may be the fix??
When I turn the signal lever nothing happens just to clarify
some times problems with the hazard circuit will keep the turn signals from working, for example I was working on my 4 runner and I forgot to plug the hazard switch back in , when I found it unplugged and plugged it back in the turn signals were back to normal
