07-06-2009, 12:21 PM
positive camber!!
I've had my older daystar 2.5/1.5 inch lift for about 20k now. I got an alignment right after I installed the lift but now I'm starting to see lots of wear on my outer tread of my front tires. Is there anything I can do to help lessen the camber effect? Should I get another alignment adjustment? I understand the nature of lifting the car... just wanted to see if there was much I can do.
2007 SPORT 4x4 | DDM 4300k HIDS | Dobinson Coils | Bilstein 5100 | JBA UCA |SuperPro LCA | Goodyear SS brakelines | Allpro 1.5 spacers | Toytec sway mods and diff drop | Energy Suspension poly sway bushings | TRD Exhaust | RSG Sliders | Defiant Light Bar
07-06-2009, 01:36 PM
Super Moderator
Super Moderator
Yes, do another alignment. Have them put the back tires on the front just prior to the alignment so as not to align to uneven tires.
Camber should be fine. When you lift a T4R with stock UCA's the caster is tough to get ideal but the camber should be fine. With the Daystar 2.5 even the caster should be ok. You really have to go higher than that (it seems) to have the caster become an issue.
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
07-06-2009, 01:40 PM
thx! you're always my hero when it comes to problems!
07-06-2009, 01:49 PM
Super Moderator
Super Moderator
Thanks
Chris
