04-08-2011, 04:06 PM
My 4x4 car build: Toyota Integra TDI (half complete)
Hey people,
I don't spend a lot of time on here but thought some of you would like to see what I'm building. Toyota Integra TDI
I'm starting with the frame and drive train from a 91 4Runner (22re, 5spd) and putting a VW TDI in to it, and then replacing the body with a '94 Acura Integra.
Here's a photo chop that I made of what it might look like.
I've already got the engine and body mounted. Now I'm working on getting the engine running in it's new home and then all the engine bay stuff.
You also might be interested in seeing my off-runner. It's basically just a 4Runner with a bunch of stuff cut off. But I like it for riding the quad trails around my home. Off-Runner - Toyota Integra TDI
04-08-2011, 04:33 PM
Awesome. Subscribed. Keep us updated!
Sent from my LS670 using Tapatalk
2006 T4R SR5 v8 4wd: Napa Ultra Premium Rotors; Weather Tech liners; AVS Ventshades; Westin Bull Bar; Hydrocarbon Delete; Blackhoused Headlights; Fog Light Mod; Sulfer TSB; Magnaflow 22" Muffler (#12586); Front: Bilstein 5100's set at .85" + Toytec 1" Net "Top1-T" Spacer = 2" total Front Lift; Rear: Cornfed 1" + Air Lift 1000; Plasti-Dip center grill + rear Toyota Emblem; JVC Bluetooth + HD Radio HDR81BT
http://www.toyota-4runner.org/new-me...purchased.html
04-08-2011, 06:18 PM
very neat, i'll be interested in what becomes of the finished product!
04-08-2011, 07:48 PM
Real Name: Chris
Real Name: Chris
Im diggin it!! I like the idea! What size tires are you planning on runnin?
2007 SE V8
HID's, interior LED mod, sweet floor mats, awesome tunes and some more stuff...
...more stuff
04-08-2011, 08:40 PM
To each their own. personally i think thats a waste of a VW motor and a 4runner frame.
04-08-2011, 11:01 PM
I'll be running either 32" or 33" tires to get the gearing to work right with the diesel and the 4.10 gears.
04-09-2011, 08:46 AM
Real Name: Bryan
Real Name: Bryan
Subscribed for sure!
John- give the negativity a rest for a minute...at least till you see the finished product
Millennium Silver 2001 4Runner SportR5lander
Photo Timeline - Solid Axle Club
All-Pro, Fox, Eibach, OME, Goodyear, Trail Gear, Yukon, Solo Fabworks, Marlin, TJM, Smittybilt, Front Range Offroad, Inchworm, Addco, Savage Offroad, B&M, Borla, Pioneer, Cobra
Northeast 4Runner Owners Association
04-09-2011, 10:40 AM
Overlooking the stuff i dont like, what motor are you using? there are quite alot of of 1.9TDI's to use but newer the motor gets the more regs it gets put on it. There's the 1Z AHU ALH BEW, and those are the main ones theres others like AFN ATD AXR AHF ASV AJM AUY ASZ ARL and im sure im missing a few. I suggest using the 1Z or AHU because they have alot less wiring (or so im told) and that will make the swap easier.
04-09-2011, 11:01 AM
The AHU and 1Z have about the same amount of wiring as the newer ALH and BEW's. The advantage of the older motors is the lack of immobilizer. But even this is an easy fix with a custom tune to delete the immobilizer.
I'm using an AHU TDI that's got 67,000kms on the clock. I've got the parts to do a VNT turbo conversion (GT1749VA). With bigger nozzles and a custom tune I'm hoping to see around 150hp and 250ft-lbs of torque.
Toyota Integra TDI: '91 4Runner frame, '94 Integra body, '98 VW TDI engine
04-09-2011, 02:04 PM
Skip the VNT 15 and the VNT 17, go straight for the VNT 17/22 its the VNT 17 but spools up like a 22 so more airflow, it has alot more power than the standard VNT 17. Have Jeff at Rocketchip give the stage 4 tune, but you probably have looked into all this already.
04-09-2011, 07:27 PM
Yeah, I've done my research and looked in to the 17/22. I got my turbo new for $500 and a new 17/22 is $1000+. I'll stick with what I have and maybe upgrade in the future if I feel it's needed. I'm probably going with a Malone stage 3 tune. I don't want to sacrifice reliability with this project by going for too much hp. If I get 150hp out of the diesel it will be more fun to drive then my DD '91 V6 4Runner, and that's good enough for me.
04-10-2011, 12:33 AM
Real Name: Bryan
Real Name: Bryan
any pics of the actual truck? progress? anything?
04-10-2011, 10:53 AM
Have you check out my site yet? I've got over 500 pics in the gallery.
I'll try to upload a picture later tonight of how it sits right now.
04-10-2011, 02:11 PM
I would just take a 2.0 Clean TDI (140hp/236 ft.lbs torque) and fab it to use in a 2nd gen. 35-40mpg would be very achievable. Especially if you could do it in a 6spd
04-10-2011, 09:31 PM
Real Name: Blair
Real Name: Blair
Great build, Dennis!
I am very jealous of your skills and creativity
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
