Originally Posted by fourwd1
I don't think your question should be to add a cooler or not, but should you tow that much weight with a V6 or not. Adding a cooler is a no-brainer.
As I said earlier, installing a trans cooler should be a must.
As for the amount of weight being towed, that depends on several things.
My '03 V6 is rated for 6300 lbs, with the weight distribution hitch and receiver I have installed. I did install a Hayden trans cooler, inline with the oem radiator cooler. I don't know what the max tow ratings for the '05 V6 are. I would assume the same as the '03, but not sure.
That being said, the max tow ratings are just a guideline. Just because the vehicle is rated for that much, doesn't mean one should take it to the limit if they are not comfortable with, or don't have experience towing heavier loads.
As you can see from my sig, it occasionally tow a 27 ft camper which when loaded (wet) comes in at 5,700 lbs (measured on scales). I don't tow it more that 3-4 times a year, and generally don't go more that 200 miles. I am comfortable with the tow, but do recognize the size and weight and allow for these limits when I do tow. I wouldn't tow across country, or try to climb Pikes Peak.
I would recommend being sure of how the hitch is setup and balanced, don't rely on a shop to do it for you. I have heard of too many bad stories about mistakes being made by shops that didn't really understand the proper method of seting up a weight distribution hitch. Once the hitch and trailer are properly setup, I would strongly suggest taking the fully loaded (all gear, water and fuel you would normally carry) trailer and tow vehicle to a set of truck scales and have them weighed. When at the scales, be sure to check the total weight, and tongue weight. Many are surprised to find that the weight numbers posted by dealers are inaccurate, and how much more all the gear and fluids add to the total weight. There is a wealth of info on the RVnet.com site, and it is a good place to find more indepth towing info. If one is a novice at towing heavier loads, proceed with caution and practice in a safe area (especially backing up) before taking any long trips.
