08-03-2011, 02:53 PM
#31
Banned
Banned
Good points,
Originally Posted by jwyshrek
Wow...nothing personal guys, but with all the implied experience here, I'm surprised that no one mention uneven pad wear.
I've worked on enough vehicles and done enough brake work to know that uneven pad wear does occur, not only between the 'inner' and 'outer' pads on a given caliper, but uneven wear can occur between the top and bottom of the pad...due to a faulty/worn out caliper...especially the single piston floating type.
Anything could have happened, but maybe both places are right (or wrong...who knows). If there was uneven pad wear and both places measured at different points, they could have gotten different thickness values.
Very Good points, Flat rate, is the guy even gonna pull the wheel ? or just peak in there ?
Uneven wear, different sides, you can only assume that the second dealership would have pulled the wheels and even removed the calipers and did a complete inspection, after all if somebody brings me a pile and says "Do the brakes" I pull the wheels and look @ it, if one side dont need em, pull the other ???? dont need em here either ?? pull the back off , Hell dont need em here either ?
Crap I just wasted a half hour, oh well dont need brakes anywhere,
Gotta do some more digging Tech Jockey the second dealership would not have wasted their time inspecting it and turning it loose without sucking up a little gravy brake job,
Give em hell!!!
08-03-2011, 02:54 PM
#32
I'm flat rate.
I measure pads and shoes.
Just for this reason. If someone comes back and tells me another shop called me out, I can pull up the old R.O., show the measurements recorded, and what's on the car now.
As for uneven wear.... that's a possibility too. Sticking calipers and slide pins and yadda yadda can affect the measure ment in a short time as well.
We still check all the pads and shoes, to help stop this from happening.
Once again, one or the other of the shops is likely wrong.
Either one should be willing to re-inspect, SHOW the owner what's up, and go from there.
08-03-2011, 03:19 PM
#33
Banned
Banned
3rd Shop?
Originally Posted by Rix
I'm flat rate.
Yep good point Rixxer, if the first shop clams up and wont reinspect good sign they know they are in the wrong,
Or better yet a third party ? Maybe Swhabs ?
And so it goes, as in anything Rixxer your shop is being called out on a entirely different matter and your clamming up,
Hiding
08-03-2011, 03:54 PM
#34
Why don't you leave other topics in other, threads, frank.
Or can you not restrain yourself?
08-03-2011, 04:08 PM
#35
Banned
Banned
All the same
Dishonesty,and or stupidity from Toyota Sales establishments, all the same to me , Brakes or grease or whatever,
Falls into the same section in my Book "BS" So When its all said and done Rixxer What do you think they will pull, for you ?
The Stupid Card, Theory #2, incapable of using the goop, might get on the brakes, so full circle, right back to the binders,
To much trouble educating and insuring the Job is done correctly,, Hell we have a problem here with a simple measurement ??
All the same,
08-03-2011, 04:44 PM
#36
after all this time... your name just clicked.
i always just thought you were a tranny named frank...
2004 4Runner SR5 V6 2wd
My Build/Mod/Repair Thread
My Beauty Shots
08-03-2011, 05:43 PM
#37
Rix- please stop replying to the other party as he clearly just wants to personally attack you and Toyota dealership/ techs.
OP- they will either tell you the tech made an error or maybe they will show you how they measure/ estimate life remaining and sell you the job. Knowledge is power so have them show you and explain their shop methods. I also recommend picking up a repair manual and searching on here how to do some of the basic repairs like pad replacement. Will save you a lot of money and you will learn a lot more about your vehicle.
99 SR5 V6 4WD- just started
SOLD1998 T4R SR5 All-Pro CO's, UCA's and Sliders, SS 1.2 rear only DIY rear bumper, Aussie Locker and 1st gen roll bar mod. Outdoor Logic Front bumper, roof rack and Vision X lights.
08-03-2011, 05:56 PM
#38
Yup.
On both accounts.
08-03-2011, 06:27 PM
#39
Banned
Banned
Supervise Dealer Marketing,
Well Pikeman you dont seem to get the whole gist of things here, sure good advise telling him to buy a book,
Make sure the repair manual is not written by Toyota Sales, Knowledge is power , imparting false, knowledge is a means of power as well,
and the means by which Rixxer is brainwashed,
and you Pike man are not "Master of the Obvious" need to pay closer attention here
While you dont realize I am merely deprogramming Rix, he is just a victim,
and hell yeah I am after Toyota sales, and not all dealerships mind you,
not all, must not be paying attention or able to afford to Pikeman, some Toyota dealerships will give you good advise,
However we have the "Supervise Dealer Marketing," aspect of Toyota motor sales, that infultrate and confound baffle and brainwash poor Rixxer,
I really do feel sorry for Rixxer, and not attacking him @ all, Merely deprogramming, constant unrelenting attack of the Toyota sales Asshools that trained him
Be clear Pike man, Do you Understand ?
08-03-2011, 06:32 PM
#40
So educational and entertaining! The flame war was so intense, I think everyone missed what Dous posted. I got a big laugh out of it, perfect timing.
Has anyone noticed that Techjockey who started this hasn't been heard from in 3 days. I wonder what he's going to do and I hope we hear back from him. At the very least, he should buy each of you (Rix and tranny Frank) a beer. I might add tranny Frank and Rix so I show no favoritism.
2005 SR5 V6 4WD 94,000 miles 8/1, 96,000 9/1/11
5100 Bilsteins with .85" front lift, stock springs, debadged tailgate, Michelin C/T 265/65/17 Now Firestone Destination A/T 255/70/17 @ 95,572
California Dreaming & Arizona, British Columbia, Colorado, Idaho, Montana, Oregon, Utah, Washington, and Wyoming
08-03-2011, 06:36 PM
#41
Re: Pikeman
Good response. In my own experiences I have met both good quality sales reps and mechanics, and the shade tree types. How I take that is this, I'm not going to throw all of Toyota under the bus and say they are trained this way. It is up to the individual to be honest or dishonest. The nearest Dealership/Service Center lost my trust after losing my skid plate accessory. Long story, not gonna bother explaining. After that I went to another Toyota Dealership that's between home and work. I told them about what had happened and the service manager has always gone out of his way to inform me, and let me take a peek when the 4runner is in the shop. I always feel like I'm paying for what needs to be done. They earn my business. When going in for service feels like you are buying a car from pushy service managers trying to earn more commission for BS inspections not being needed, its time to get out.
OP since I don't know how the staff at service center #1 made you feel, I would inquire about the discrepancy between the two measurements. If you felt like they were taking you for a ride, then call them out still being polite. No matter what. Starting off being pissed won't get you anywhere being calm won't when it comes to customer service. If you are still getting the BS from them you can let them know how much of a pain in the ass you _could_ be for their reputation via social media. This is if you want to spend this much time. You don't have anything to lose by putting pressure on service center #1. There's always someone else with higher authority, another manager, a rival service center to bring your business to. My opinion.
2005 Sport Edition 4.7L V8 4x4
-Borla Dual Exhaust -HCF Delete -OEM 2006 Tail Light MOD -Pioneer AVH-4200NEX -Automatic Start -Lo Jack -Heated Seats Mod -WeatherTech All Weather Floor Mats -Sport Pedals -Black Headlight Housings -ALL LED External Lights -Bilstein 6112/5160 Lift -FJ Coil Swap -C4 Low Pro Bumper -Warn VR Evo 10k-S Winch -Sherpa Princeton roof rack -Extreme LED Light Bars -SCS SR8 wheels on Falken Wildpeak tires 285/70/R17
http://www.toyota-4runner.org/4th-ge...ld-thread.html
08-03-2011, 06:38 PM
#42
Banned
Banned
Thanks Scenic seeker, but you will have to clue me in on what the limp wristed multi colored flag dude means ?
Uhm sorry dont get it ?? and I to hope we here back from Tech Jockey, thanks
08-03-2011, 06:52 PM
#43
In the icons it's listed as "so gay". I'm not saying anything else and have to agree with Jerry Seinfeld on the subject.
08-03-2011, 07:01 PM
#44
@tranny Frank... I get it. Your very first post in this thread had a personal attack on another member and so far you have not really given any constructive advice. You simply continue to ramble on against Toyota. You already mentioned that you are a former Toyota tech and given your anti-Toyota tech banter I can only imagine you left on bad terms. If you continue on your anti-Toyota rant and personal attacks on other forum members you will be reported to the moderators for violation of forum rules.
Knowing your vehicle and how to do the basic repairs is vital. There are times you may not be in the position to afford to pay the mechanic or even be close enough to a mechanic to get the repair done(trail repair). Choosing/ finding a good honest mechanic is not always the easiest chore and will take time with some trial and error. The repair manual does not have to be factory Toyota, it can be a Clymber or Haines manual you get from the local auto parts store. Also on our vehicles if you can change a tire you can change the break pads, and only adds 10-15 minutes a side.
08-03-2011, 07:20 PM
#45
He is NOT a former toyota tech.
He's a former ford mechanic, and he's worked on like 3 toyotas.
