04-21-2015, 08:40 AM
#46
That's great feedback and a great use of the tray. If I still had my 3rd Gen this is definitely the way I would go.
2015 Gray SR5 Premium 4Runner - Toytec Ultimate - LR UCAs - ARB Fridge - Airaid CAI - Flowmaster - 255/75 Cooper ST Maxx
Gone: 1998 Desert Dune 4Runner - Toytec/Eibachs w/ LC 8 Wraps - Bilstein 5100s All Around
Gone: 07 Sunfusion FJ Cruiser - OME lift and a bunch of other stuff (I miss this one)
Gone: 05 Silver TRD Offroad Tacoma Doublecab - Toytec lift and other goodies
04-23-2015, 10:11 PM
#47
Just received mine today. I have a 5th Gen with third row seat and from the initial look of things the tie downs don't really line up. If anyone has suggestions or pictures of how they strapped this thing down please post.
I'll be looking into other options tomorrow and will report back what I come up with.
04-24-2015, 08:29 PM
#48
Real Name: Reid
Real Name: Reid
Received and installed mine yesterday. Very happy with it so far.
I too have the 3rd row and am looking into a turnbuckle solution to more solidly secure it.
2011 SR5 - Trail hood - Method NV wheels, 285,70-17 Duratracs - Toytec Boss lift - Shrockworks dimple sliders/trail trim/battery, ACR & Switch mounts/skids - Weathertech mats - LED bulbs - 18% tint - Gobi Stealth, cargo slider, ARB dual twin compressor with 1.5 gal tank, Retrofit head lights (MORIMOTO FX-R Stage III, XB 55, DS2 XB 5500k, XB LED Fogs, DDM LED high beams) Bussman box, Switchpros, Bluesea ACR, Odyssey second battery.
(Have but need to install: Seat heaters)
04-25-2015, 09:13 AM
#49
PM'd, hope I did not miss out.
2015 4Runner TE Magnetic Grey
Gone: 2007 SR5
04-25-2015, 10:06 AM
#50
Share pics and share details! Thanks!
2015 SR5 Premium 4x4 / 3rd row seat
Jicko's Build & Adventure Thread
"Group buy, anyone?"
04-27-2015, 10:53 PM
#51
Got off work a little earlier today, and finally got a chance to install mine.
I too have the 3rd row seats. And using just the 4 straps with the cargo space tie downs do have "some" play, probably fine, but not as "solid" as I'd like.
So, I used the 2 remaining straps, and fish them thru from behind to the 2nd row seats' child-seat LATCH anchors (middle 2), and hook them to the rear cross member of the lower frame of the slide. Wa-la, that makes a night and day different! I can totally sit on the extended slide and it is not going anywhere! (Ok, I am nowhere near the 250lb limit.... but you get the idea)
More installation details in my build thread: Jicko Build Thread ...
04-29-2015, 06:59 PM
#52
I received mine today. (good to be in NC, arrived overnight on UPS ground). Super easy install and very good build quality. Thanks again for setting up the group buy!
Needsmoresalt. Hi Charlie!
Gone: 2007 SR5
06-21-2015, 08:02 AM
#53
Waking up this thread ;)
I finally broke down and got a fridge. Set it up with the Goal Zero to provide round the clock power, without impacting the 4Runner battery. This setup will go well with my camping trailer. ;)
Gone: 2007 SR5
06-21-2015, 01:51 PM
#54
Real Name: Keith
Real Name: Keith
How long will the Goal Zero 400 run your fridge with the car off? Then it charges fine using the rear power outlet & how in what time?
Nice setup...been thinking about doing the same.
2015 TEP/KDSS
06-21-2015, 02:50 PM
#55
I have gotten over 50 hrs straight on the yeti 400. I do not charge from the outlet, but from the panels during the day. So, during the day, I top up from solar, and deplete at night. I have run over 2 weeks this way with yeti never dropping below 60 %.
Gone: 2007 SR5
07-02-2015, 07:14 PM
#56
Does that fridge put out much heat?
07-02-2015, 10:22 PM
#57
Greats choice of fridge!!
ARB 10800472 Fridge Freezer- 50 Quart
Theoretically, average DC(12V) power consumption: 0.7 to 2.3 amp hr
So, how much output are your panels?
Nope.
07-05-2015, 10:46 PM
#58
@ Hammerhead
Not that much heat, never noticeable.
Jicko: Using this formula, at 60 watts DC, at 12v, I got 5 ah. Nominal is really 2.5. So no issues with this setup up, "except" when it is cloudy, all the numbers are crap. So, your milage will vary considerably.
DC watts to amps calculation
The current I in amps (A) is equal to the power P in watts (W), divided by the voltage V in volts (V):
I(A) = P(W) / V(V)
Originally Posted by jicko
Gone: 2007 SR5
10-15-2015, 03:30 PM
#59
Any of these still available? If so PM ME.
I don't own a 4Runner anymore.
10-16-2015, 12:22 AM
#60
PM ME, I am not sure, but I can potentially provide you with some contact info (after I ok'ed with them).
HTML code is Off
