Notices
Closed Thread
Old 12-15-2021, 08:11 PM #1
MillerPKA's Avatar
MillerPKA MillerPKA is offline
Real Name: Weston
MillerPKA is a jewel in the rough MillerPKA is a jewel in the rough MillerPKA is a jewel in the rough
MillerPKA's Avatar
Real Name: Weston
GOBI Racks - Limited Edition Open Air Roof Racks - T4R Exclusive Group buy
Group buy is closed!
ORDER HERE: GOBI Racks - 5th gen 4Runner Open Air - T4R Group buy - Order Form
What's up T4R members!
Quite a few of you have been asking me about another group buy, and we've decided to offer something special just for this forum. We've been cooking up a new concept at GOBI Racks and offering it as a limited edition run for now - available only to this group buy.
Introducing the Open Air concept - featuring the same trademark look and structure as our OG racks, but now with an added customization. With the Open Air, the expanded metal floor that is typically welded to rack is now an optionable insert!
There are a few major benefits to the Open Air:
- Only 35 pounds! (Standard rack is 70 pounds)
- Full removal of the rack floor makes it a breeze to clean your roof!
- Same load rating as our regular racks (300 lbs. dynamic, 800 lbs. static)
- Full, normal use of the crossbars that come equipped with the rack
- Compatible with all of our accessories!
- Using a rooftop tent and don't need the floor? Keep it at home and save the weight!
- You can insert the two floor inserts and sunroof insert for a full-length floor, and the sunroof will still be fully operable!
- Oh yeah, the lead time...only 30-45 DAYS (after group buy is closed)
This is in addition to the perks our racks have offered for 20 years:
- Single piece welded carbon steel racks means strong, field-tested design with no squeaking, no rattling, no exposed hardware on sides (keeps rack streak free), and no assembly required
- Sleek aerodynamic open design allows air to flow through entire rack from all sides (keeps roof top free from accumulating debris)
- Predrilled grommeted holes allow you to route your wiring inside the rack, protecting it from the elements
- Universal light tabs allow for easy compatibility with most all aftermarket lighting options
- Wind deflector can be removed without affecting structural integrity
- 300 lb. dynamic and 800 lbs. static load limits
- Made by hand here in America, from start to finish at our Denver HQ
Here are the details:
- Cost of roof rack alone is $1,175.00 which includes wind deflector, cross bars, all mounting hardware, tax and either shipping or free install at our Denver headquarters.
- Cost of roof rack with ladder is $1400.00 which includes wind deflector, cross bars, all mounting hardware, tax and either shipping or free install at our Denver headquarters.
- You can choose Stealth or Ranger, LED or Multi-light setup, and rise or no-rise (explained below)
- We will take your card information but will NOT charge you until your order is up for production. No down payments or deposits.
- The focus of this group buy is the base rack system. Optional floor inserts and any accessories will have to be ordered and shipped separately.
- Floor inserts will cost $250.00 apiece and have a 200 lb. traversable body load limit. Front sunroof insert is $250 with same 200 lb. traversable body load limit.
This group buy has 50 spots available. To proceed, please submit your information through this order form. I will update the spots filled as submissions come in. Let me know if you have any questions!
Explaining the options
Stealth vs. Ranger
This refers to the height of the rack. While the design and shape are identical, the Ranger rack is 2" taller than the Stealth.
LED vs. Multi-light setup
This has to do with the front portion of the rack. The multi-light features two vertical support bars and is a great option for those running round lights, for example four BajaDesigns LP4s.
The LED setup has no vertical support bars, allowing a 40" light bar to sit further inside the rack structure for a more integrated look.
You can still run an LED bar on the multi-light setup, but the light bar body would have to sit in front of the vertical support bars.
Rise vs. No-Rise
This also refers to the front of the rack. The standard racks feature our signature look, with the top perimeter of the front rack "rising" up. You can opt for the no-rise option which removes that feature, making the top of the rack completely flat.
The New - 2019 TRD ORP, Supercharged, Lifted, 285s, armored,
https://www.toyota-4runner.org/5th-g...9-trd-orp.html
The Old - 2000 SR5, Supercharged, E-locker, 35s, 4.88
www.outworldhq.com/2000-toyota-4runner
Old 12-15-2021, 08:13 PM #2
MillerPKA's Avatar
Real Name: Weston
MillerPKA's Avatar
Real Name: Weston
Old 12-15-2021, 08:14 PM #3
MillerPKA's Avatar
Real Name: Weston
MillerPKA's Avatar
Real Name: Weston
1. A. Bumanglag
2. A. McKinney
3. M. Kamel
4. W. Wambsgans
5. @Lawless82
6. @CementTruck
7.
8.
9.
10.
11.
12.
13.
14.
15.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
Old 12-17-2021, 06:11 PM #4
snowboardwcu snowboardwcu is offline
Real Name: George
snowboardwcu is on a distinguished road
Real Name: George
Boooooooooooo Gobi #neverforget
2005 V8 170k
Doug Thorley Shorties, Magnaflow Cats, Gibson Exhaust
Falken Wildpeak AT3 265/70-17
Gen5 Brake Upgrade
Transmission Fluid Coolant Line Replace
Old 12-27-2021, 10:23 AM #5
pumacat24's Avatar
pumacat24 pumacat24 is offline
pumacat24 has a spectacular aura about pumacat24 has a spectacular aura about
pumacat24's Avatar
Submitted my request online, and cannot wait to be added to this list!!
2019 TRD Pro | IG: @trdprocat | RSG Sliders | Falken Wildpeak AT3W | Morimoto/XD LEDs | CTX Tint
past: '18 4Runner TRD ORP... RIP, Kaiyo!
'07 4Runner SE... SOLD
'02 4Runner SR5 4WD... SOLD
Old 01-05-2022, 02:05 AM #6
montijo505's Avatar
montijo505's Avatar
Savage. I like the cut of your jib.
Old 01-18-2022, 02:41 AM #7
AlumniCU's Avatar
AlumniCU AlumniCU is offline
AlumniCU is on a distinguished road
AlumniCU's Avatar
Is this still open?
2015 Trail Premium w/ KDSS, OME suspension & UCAs, 255/80 17 Falken Wildpeaks, Hefty Banshee w/ Warn winch, RCI sliders & skids, all knockin' around the Rockies (~);}
AlumniCU is offline
Old 01-18-2022, 04:49 PM #8
Dusty Driftwood's Avatar
Dusty Driftwood Dusty Driftwood is offline
Real Name: Jeff
Dusty Driftwood will become famous soon enough
Real Name: Jeff
Originally Posted by MillerPKA View Post
pictures...
Is this open air model and group buy open to GX owners?
Specifically, is there a model that will fit a 2013 GX460?
Thanks,
Jeff
2013 Knight's Armor Pearl GX460 Premium "Grace"
2007 Nautical Blue Metalic SR5 4X4 V6 "Carl"
SOLD: 2008 Driftwood Pearl SR5 4X4 V6 "Dusty"
Dusty's Cargo Drawers
Old 03-14-2022, 07:36 PM #9
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
Thanks,
Jeff
The OP Closed this Group Buy on Feb 3.
'89 4Runner SR5 - stock
fourwd1 is offline
Closed Thread
buy , floor , group , rack , racks
HTML code is Off
GOBI Racks Group buy! (3rd, 4th, 5th gens welcome) MillerPKA Group Buys 282 04-06-2021 03:12 PM
Gobi Racks Group Buy Feeler! MillerPKA 5th gen T4Rs 69 03-18-2020 07:45 PM
**Group Buy: Gobi Racks and accessories** RiDE 5th gen T4Rs 547 04-29-2017 01:47 AM
FS: (2) 4th Gen Roof Racks; Gobi & Sport racks daPitbull For Sale: T4R Items 14 04-08-2014 11:41 PM
Roof Racks Other Than Baja and Gobi WaySlowWhitey 5th gen T4Rs 2 11-07-2012 02:18 PM
