Notices
Old 09-05-2017, 09:14 PM #91
4runnerlaw's Avatar
4runnerlaw 4runnerlaw is offline
4runnerlaw is on a distinguished road
4runnerlaw's Avatar
4runnerlaw is offline   Reply With QuoteReply With Quote
Old 09-05-2017, 09:16 PM #92
4runnerlaw's Avatar
4runnerlaw's Avatar
I had it behind the grill at first but the angle wasn't good enough to show how close I was parking to objects. It works better being in front of the grill
Old 03-18-2020, 06:05 PM #93
Camping4R Camping4R is offline
Camping4R is on a distinguished road
Has anyone mounted one of these on the front of a 2020? Wondering if it’s possible with the radar cruise sensor.
Camping4R is offline   Reply With QuoteReply With Quote
Old 03-20-2020, 04:08 PM #94
Gremmin Gremmin is offline
Gremmin is on a distinguished road
The radar shouldn't be a problem as long as you don't block it, but I'm not sure the harness will work with the new head unit.
Gremmin is offline   Reply With QuoteReply With Quote
Old 03-20-2020, 05:53 PM #95
The guy sells a new kit that is compatible with the 2020 head unit. That’s the one I am going to buy but I’m not sure where I can mount it because the radar cruise is centered and pretty tall so there isn’t a lot of grille space left in the center. Haven’t found any pics of a 2020 with the camera installed either so was hoping someone’s done it or seen it done.
Old 03-21-2020, 08:04 PM #96
If you got a pro you can mount it on the upper grille, otherwise you can mount it on the side of the radar. doesn't need to be perfect center unless it's something that would bother you.
If you don't have the pro you can buy the pro grille and mount it on the upper piece.
Old 03-22-2020, 04:09 PM #97
I have an SR5 but I already did the OEM pro grille mod so that could be an option. I’ll have to take a look at the space left on the upper grille. Also just heard back from anytime backup camera, and he suggested the front license plate frame could be used. Not sure if that will be too low to the ground or not. Probably gonna have to play around with it.
Old 04-08-2020, 12:56 AM #98
For future readers, I was able to mount on the upper grill portion. I haven't yet connected all the wires up, but this mounting location looks great. Based on the camera angle I think it will clear the TOYOTA lettering just fine. To install it you'll need to take off the upper grill and cut out a good bit of plastic from the black inwards-facing piece. It looks pretty good in my opinion and almost OEM, doesn't stand out at all like I was worried it might.
Old 04-29-2020, 06:25 AM #99
Hubble's Avatar
Hubble Hubble is offline
Real Name: Marco
Hubble will become famous soon enough
Hubble's Avatar
Real Name: Marco
I was thinking of mounting my camera in the same spot. How did this camera view end up working out for you once you had it all connected?
2018 Toyota 4Runner TRD Offroad
285/70R17 BFG KO2's ** SCS Stealth 6 ** ToyTec Boss Lift Kit 3"F/2"R
XenonDepot Xtreme HID Kit 5000K ** XenonDepot H16 Xtreme LED Pro Fog Light Kit ** AUXITO 6000K Interior/reverse Bulb LED Kit
RCI Aluminum Front/Filler, T-case, Tranny, Gas Tank, and Lower Link Skid Plates ** BPF Rear Shock Skid Plates ** LineX Coated RSG Angled Sliders
SSO Slimline Bumper ** Smittybilt X2O Comp Winch ** Baja S8 20" Lightbar ** SSO Roof Rack **
Hubble is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 04:08 PM #100
It worked Okay. Not perfect, as the view doesn’t clear the lettering. It’s still useful for some situations but it’d be better if it was farther forward. I may adjust it later.
Anytime Backup Camera and Front Camera - February 2017 Group Buy-b101cf7a-0505-433e-9161-7adbe435012e-jpeg
Old 05-06-2020, 10:59 AM #101
Hubble's Avatar
Real Name: Marco
Hubble's Avatar
Real Name: Marco
I mounted mine in the same spot prior to seeing your post. I might look for a different camera and try to mount it below the Pro grill
Old 05-06-2020, 11:39 AM #102
If I didn’t have a 2020 with safety sensor I would have definitely mounted it below the pro grill. I think there are adjustable cameras you can buy too that would fix this issue.
HTML code is Off
Backup Camera Relocate & Wireless Wifi Front Camera dahorst 5th gen T4Rs 14 03-27-2021 02:51 PM
Anytime Backup Camera - GROUP BUY - 2017 bjohnston115 Group Buys 37 10-04-2018 02:07 PM
"Anytime Backup Camera" *Jicko Group Buy Series* Spring 2017 jicko Group Buys 101 08-07-2017 03:04 PM
Check Engine and VSC Lights when employing Anytime Reverse Camera matthewkristof 4th Gen T4Rs 1 05-31-2016 06:48 PM
Anytime Camera w/Multi Input Switcher matthewkristof 4th Gen T4Rs 0 07-28-2014 07:01 PM
