Originally Posted by Signal
Is it necessary to remove the cubby to drill the hole or can I just drill it without uninstalling the cubby?
You can drill w/o removing the cubby, but it may be tricky to fish the wires through. You may also have trouble fitting your drill body into the cubby hole depending how long your drill bit is. I had to remove mine anyway to swap the cubby to a 2014+. Once out, I drilled from the backside and it was easy to route the wires from the driver's side gourmet. It's not that hard to remove the plastic trim, though I had to pucker up my first time. I am impressed how Toyota made the clips to be reusable. Check my post on page 2 for the link to removing the center console.
