Hello all,
I'm working with
Endless Horizon Outfitters on a Partner Steel Cook Partner group buy!
We need 15 people minimum to get this thing going. Once we've reached the 15 person minimum, I will need to get each members Full Name, Shipping Address, and final order. We will then send you an invoice, once everyone is paid, the stoves will be shipped out. Please reply to this thread to add your name.
***NOTE***
These stoves are designed to use the larger sized (5lb or bigger) propane bottles/tanks, so you will need the 1lb bottle adapters if you wish to run the small 1lb bottles.
Who: Endless Horizon Outfitters
What: Cook Partner 16, 18, 22" Stoves with or without windscreen, 1lb propane bottle adapters, all size griddles
Shipping: $30 flat rate to the lower 48
When: 2 weeks. Now until April 30th.
Pricing: Please PM, but it is Excellent!
16" & 18" 2 Burner Stove
These 2 burner 16" and 18" wide stoves are half the weight of the full 4 burner stoves, and can still be used with a stove stand. The only difference between these stoves is the 16" stove will fit in a 25mm ammo box and the 18" will not. 13 lbs, 12 x 18 x 3 1/2. Burners are 9 1/2" apart. This stove can not be fit with a break-apart hinge to remove the lid. A Partner Steel carry bag is available for when the stove is not in use. Windscreens sold separately If you have a preference, you can specify gas connection either on the left or right end.
22" 2 Burner Stove
Our newest stove is 22" wide. We have incorporated some important features requested by users. This stove has the burners spaced 12" apart to more easily accommodate 10" pans. Additionally, the grill spacing has been reduced over the burner plates so that a small coffee cup can be warmed. The windscreen is a standard feature with this stove. Griddle and stand is available. 12 x 22 x 3 1/2, 17lbs. A Partner Steel carry bag is available for when the stove is not in use. You can specify the gas connection on the left or right end.
1lb Propane Bottle Adapter
This bottle adapter is required to use a 1 lb. propane bottle with a Partner Steel stove.
Griddles
Partner Steel griddles come in anodized food grade aluminum that forms these durable griddles is hard anodized with a tough coating that makes cleanup easier and promotes even heating. They are rectangular and feature 1 1/4" sloped sides with welded handles on the ends. These griddles heat rapidly and clean up easily; anodized surface means that a steel spatula won't scrape off the finish.
