Notices
Closed Thread
Old 06-18-2019, 02:02 AM #1
eddielasvegas eddielasvegas is offline
Real Name: Eddie
eddielasvegas has a spectacular aura about eddielasvegas has a spectacular aura about
Real Name: Eddie
NorthStar Battery - PSA
Hello All,
Before I get to the details of this post, I want to say this is simply about passing along information to the T4R member community. No drama, hurt feelings or ill will intended.
The recent NorthStar battery GB got me to thinking (which usually does not get me very far) about a battery GB and what a hassle it is to deal with in the event a warranty issue arises. So I called NorthStar and here's what they told me:
In the recent GB, mailing back the battery under warranty is not required, but an inspection to verify its failure is. This takes time and could be a real hassle if you do not have a second car, or at least access to one. Plus, once it's verified as failed, you have to wait 2-4 days for your new battery.
Well, take a look at Batteries+Bulbs. They sell the NS battery (called X2Power) with a different color top. Internals are (see attachment):
But wait, it gets better: The B+B battery has a 5 year full replacement warranty. You simply take it to your local B+B and they give you a new battery. Most people will be up and running within a couple hours instead of a couple days.
B+B battery cost is more out of pocket, but on a per warranty year basis, it is about the same. There is always a 10% coupon on B+B's web site, but you will have to pay sales tax. Occasionally, there is a $30 rebate on their X2Power batteries, which would make my 24F battery about $270. Without the rebate, it's $300, which is $60 per warranty year. That's about the same as the recent GB price IIRC.
I will need a battery by mid November so I'll be watching this link and will jump on an X2 if a rebate shows up. Otherwise, I'll pony up the $300 knowing I have 5 years and an easy swap out of anything happens.
2001 Toyota 4Runner V6 3.4L 585CCA Car and Truck Batteries at Batteries Plus Bulbs
Eddie
NorthStar Battery - PSA-mcvid-jpg
2001 T4R SR5 - 180k miles and counting.
Old 06-18-2019, 07:37 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
if you want to save at battery plus, you need to do the online order and apply coupon codes and do store pick up, also i would fit the biggest battery i can, pretty sure 27f might, i know its more wider.
94r might also. when i had a 3rd gen, i put in an PC1700MJT | ODYSSEY Batteries
odyssey pc1700mjt, it was a wide and short, but had enough juice for my needs.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
Old 06-18-2019, 08:35 AM #3
halflife78's Avatar
halflife78 halflife78 is offline
halflife78 will become famous soon enough
halflife78's Avatar
You sure have been on a mission to bash that groupbuy since you got slapped around in the opening page of it haven't you? This is also a good look for when you try to setup another GB.
And this isn't a GB thread, so it needs to be purged.
2016 TRD Pro: C4 Rock Sliders | Victory 4x4 Roof Rack | Ellis Precision Shifters | Blackvue 650s 2 CH | Full Front Clearbra | 20% Tint | Beavertail | Borla S-Type | Pedal Commander | Tail as Turn | DRL LED Foglights | ArcLight Triple State Voltage Booster | Victory 4x4 Front Winch Bumper | Victory 4x4 Front Skid | TRD CAI | SCS Stealth 6 | Dobinsons Lift & UCA | Warn Zeon 10s | Northstar 31m | Factor55 Flat Link | ARCLightLED Hatch/Map/Dome Lights | Lock'er Down Console Safe | XD Door Light / License Plate Bulbs
Old 06-18-2019, 08:40 AM #4
FrenchToasty's Avatar
FrenchToasty FrenchToasty is offline
Real Name: Morgan
FrenchToasty will become famous soon enough
Real Name: Morgan
They want your business, most of the time they will honor the online coupon in store with no issues. Sometimes you get lucky and the counter monkeys don’t charge you for the core!
2010 SR5 Blizz Pearl- Borla cat back, Firestone ride rite, Huskyliners, Afe Cai, Urd MAF, Gobi stealth with ladder, 5100s, icon 2" rear, toytec 1.6" front, TC UCA, HAF custom sliders, hand hold light mod, Led interior, stock rims and BFG KO2 265/70 C, Arb CKMA12- slider tanks w/ couplers, BD S8 10", opt7 40", BD dome light led in rear hatch
Old 06-18-2019, 09:19 AM #5
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
That's why I also went with the local B+B route, I was fine with the lighter 24 size battery and yes online pickup with coupon and rebate helps you recoup. Now my local rep explained to me that the battery will have to be tested at the shop and it has to fail in order to get a replacement, testing can possibility take over night to know the results. I guess it all depends on the timing when they start the test. Just a fair warning.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Old 06-18-2019, 09:26 AM #6
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
You accept the responsibilities that comes with ordering a battery that's an online only process. You obviously know what they are. If they're worth saving some money to you, then you go for it. Otherwise, you move on. In this case, I think you should move on. No need to prolong the contrast of the two options as I feel it will likely get heated considering the replies here and the replies in the actual GB thread about the topic.
>> Closed
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline
Closed Thread
battery , northstar , rebate , recent , warranty
HTML code is Off
**Northstar Battery - group buy 5.0** ramonortiz55 Group Buys 53 01-05-2018 08:51 PM
Group 31 Northstar X2 Battery Install cyclist 5th gen T4Rs 6 07-04-2017 02:52 PM
**Northstar battery group buy 3.0** ramonortiz55 Group Buys 68 12-23-2016 11:02 AM
Northstar Battery group buy 2.0 ramonortiz55 Group Buys 128 07-09-2016 01:16 AM
