Notices
Closed Thread
Old 04-16-2018, 12:34 PM #1
ZOMBRNR's Avatar
ZOMBRNR ZOMBRNR is offline
Real Name: Brandon
ZOMBRNR is on a distinguished road
ZOMBRNR's Avatar
Real Name: Brandon
**CLOSED** - Cook Partner Group Buy Spring 2018
Hello all,
I'm working with Endless Horizon Outfitters on a Partner Steel Cook Partner group buy!
We need 15 people minimum to get this thing going. Once we've reached the 15 person minimum, I will need to get each members Full Name, Shipping Address, and final order. We will then send you an invoice, once everyone is paid, the stoves will be shipped out. Please reply to this thread to add your name.
***NOTE***
These stoves are designed to use the larger sized (5lb or bigger) propane bottles/tanks, so you will need the 1lb bottle adapters if you wish to run the small 1lb bottles.
Who: Endless Horizon Outfitters
What: Cook Partner 16, 18, 22" Stoves with or without windscreen, 1lb propane bottle adapters, all size griddles
Shipping: $30 flat rate to the lower 48
When: 2 weeks. Now until April 30th.
Pricing: Please PM, but it is Excellent!
16" & 18" 2 Burner Stove
These 2 burner 16" and 18" wide stoves are half the weight of the full 4 burner stoves, and can still be used with a stove stand. The only difference between these stoves is the 16" stove will fit in a 25mm ammo box and the 18" will not. 13 lbs, 12 x 18 x 3 1/2. Burners are 9 1/2" apart. This stove can not be fit with a break-apart hinge to remove the lid. A Partner Steel carry bag is available for when the stove is not in use. Windscreens sold separately If you have a preference, you can specify gas connection either on the left or right end.
22" 2 Burner Stove
Our newest stove is 22" wide. We have incorporated some important features requested by users. This stove has the burners spaced 12" apart to more easily accommodate 10" pans. Additionally, the grill spacing has been reduced over the burner plates so that a small coffee cup can be warmed. The windscreen is a standard feature with this stove. Griddle and stand is available. 12 x 22 x 3 1/2, 17lbs. A Partner Steel carry bag is available for when the stove is not in use. You can specify the gas connection on the left or right end.
1lb Propane Bottle Adapter
This bottle adapter is required to use a 1 lb. propane bottle with a Partner Steel stove.
Griddles
Partner Steel griddles come in anodized food grade aluminum that forms these durable griddles is hard anodized with a tough coating that makes cleanup easier and promotes even heating. They are rectangular and feature 1 1/4" sloped sides with welded handles on the ends. These griddles heat rapidly and clean up easily; anodized surface means that a steel spatula won't scrape off the finish.
Build Thread | Enter The Adventure | YouTube | Instagram
2006 V8 4x4 Limited JBL | ZOMB RNR
ZOMBRNR is offline
Old 04-16-2018, 12:35 PM #2
ZOMBRNR's Avatar
Real Name: Brandon
ZOMBRNR's Avatar
Real Name: Brandon
Reserved for interest list:
1. @Brandoc 0mmando - 22" w/1lb Adapter, Medium Griddle
2. @TacoLand - 22" w/1lb Adapter
3. @Chrisinvermont - 22" w/1lb Adapter, Medium Griddle
4. @raptore - 22" w/1lb Adapter
5. @mjohns2 - 22" w/1lb Adapter
6. @SurgicalApple
7. @Peadog - 22" w/1lb Adapter
8. @ElysianComrade - 22" w/1lb Adapter, Medium Griddle
9. 5150Bronco(TW) - 22" w/1lb Adapter, Medium Griddle
10. @hstexan - 22" w/1lb Adapter
11. jowybyo(TW) - 18" w/1lb Adapter
12. @bigears2303 - 22" w/1lb Adapter, Medium Griddle
13. @sactown - 22" w/1lb Adapter
14. @Gxblade1 - 22" w/1lb Adapter
15. @TCLLC - 22" w/1lb Adapter
16. @Krayziekid - 22" w/1lb Adapter
17. @ColoradoFrosty - 18" w/1lb Adapter, Small Griddle
18. @JPOVS - 16" w/1lb Adapter
19. @rlarroque - 22" w/1lb Adapter
20. @5280 TRail-Runner - 22"
21. @clydeepants - 22" w/1lb Adapter
22. @ramonortiz55 - 22" w/1lb Adapter
23. @AZFIRERUNNER - 22”
24. @Stevee - 22" w/1lb Adapter
25. @skaterpdx - 22" w/1lb Adapter, Medium Griddle
26. @nglayton - 22” w/1lb Adapter
27. tslick(TW) - 22"
28. @TrDpRo_J - 22" w/1lb Adapter
29. MachineGun1987 (TW) - 22" w/1lb Adapter, Medium Griddle
30. RisingWithoutWings (TW) - 22" w/1lb Adapter
31. RJW (TW) - 22" w/1lb Adapter, Medium Griddle
32. @Aznwolf118 - 22" w/1lb Adapter, Medium Griddle
33. @geoalesolo - 22" w/1lb Adapter
34. @whte4r - 1lb Adapter
35. @matt922 - 18" w/1lb Adapter
All invoices have been sent!
ZOMBRNR is offline
Old 04-16-2018, 04:57 PM #3
TacoLand TacoLand is offline
TacoLand is on a distinguished road
I would be interested if it's actually happening this time ... sign me up!
TacoLand is offline
Old 04-16-2018, 05:19 PM #4
ZOMBRNR's Avatar
Real Name: Brandon
ZOMBRNR's Avatar
Real Name: Brandon
It is indeed happening. Added you to the list.
ZOMBRNR is offline
Old 04-16-2018, 06:22 PM #5
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Just an FYI on their stoves. They're designed fit a 5lb or larger propane tanks. So if you plan on running a smaller propane tank like the Coleman brand you can find at Wally World you'll need an adapter.
MStudt is offline
Old 04-16-2018, 06:35 PM #6
ZOMBRNR's Avatar
Real Name: Brandon
ZOMBRNR's Avatar
Real Name: Brandon
Thanks for noting this Mike, I'll update the first post so everyone is aware.
We can do special pricing on the adapters as well if needed!
ZOMBRNR is offline
Old 04-16-2018, 08:42 PM #7
Chrisinvermont Chrisinvermont is offline
Chrisinvermont is on a distinguished road
I'm in. Stove and adapter. Discount on griddle as well?
Old 04-16-2018, 09:36 PM #8
ZOMBRNR's Avatar
Real Name: Brandon
ZOMBRNR's Avatar
Real Name: Brandon
Added to the list. And yes we can do the griddle as well!
ZOMBRNR is offline
Old 04-16-2018, 09:54 PM #9
raptore raptore is offline
Real Name: Richie
raptore is on a distinguished road
Real Name: Richie
I'm in
raptore is offline
Old 04-16-2018, 11:32 PM #10
hstexan's Avatar
hstexan hstexan is offline
hstexan will become famous soon enough
hstexan's Avatar
Was just on a camp trip over the weekend discussing these with a buddy. Very interested in a 22" with adapter...sent PM for pricing
2006 Toyota 4Runner Limited 4x4 V6 Shadow Mica Sold
Dobinsons Suspension 300/221 Front & 505/637 Rear | FN Wheels f(x) pro | BFGoodrich KO2 275/70/17 | Front Runner Slimline II | ARB 2000 | Gobi Ladder | Treeline Outdoors Tamarack RTT
hstexan is offline
Old 04-16-2018, 11:43 PM #11
ZOMBRNR's Avatar
Real Name: Brandon
ZOMBRNR's Avatar
Real Name: Brandon
PM replied!
Originally Posted by raptore View Post
I'm in
Added to list!
ZOMBRNR is offline
Old 04-16-2018, 11:59 PM #12
mjohns2 mjohns2 is offline
mjohns2 is on a distinguished road
In please. 22" with Adapter
mjohns2 is offline
Old 04-17-2018, 12:05 AM #13
SurgicalApple SurgicalApple is offline
SurgicalApple is on a distinguished road
Sign me up!
Old 04-17-2018, 09:06 AM #14
Krayziekid's Avatar
Krayziekid Krayziekid is offline
Real Name: Jake
Krayziekid will become famous soon enough
Krayziekid's Avatar
Real Name: Jake
Wow talk about perfect timing. Seriously considering picking one up. What size do most people seem to go with? 22"? 18"? I am using an old gas coleman grill and have no idea what size it is, but I don't want to get something too massive!
"Po" - '18 Super White TRDORP - Build Thread Here
"Sirius Black" - '03 Limited V8 Build (Sold) - Build Thread Here l 03->06 Headlight Swap Guide
My Photography // My Videography
Old 04-17-2018, 09:26 AM #15
Peadog's Avatar
Peadog Peadog is offline
Real Name: Korey
Peadog is on a distinguished road
Peadog's Avatar
Real Name: Korey
I'm in for a 22".
2017 Cement TRD Pro
Peadog is offline
Closed Thread
HTML code is Off
RCI Group Buy - CLOSED MStudt Group Buys 313 12-26-2018 04:56 PM
**Wet Okole Fall 2018 - Group buy** ramonortiz55 Group Buys 17 10-29-2018 09:13 AM
**Partner Steel Stoves - Group Buy** ramonortiz55 Group Buys 38 04-16-2018 03:48 PM
Partner Steel Group Buy MStudt Group Buys 34 02-25-2016 06:08 PM
