Notices
Old 11-13-2019, 07:51 PM #136
J-Roc's Avatar
J-Roc J-Roc is offline
Real Name: J
J-Roc will become famous soon enough J-Roc will become famous soon enough
J-Roc's Avatar
Real Name: J
Nice spot, but I hope you didn’t have to get rid of “Party Mode”
Best feature of these trucks!
Lol
2013 Blizzard Pearl Ltd/14’+Tail Light Swap/Anytime Backup Cam/275-55-20 Wildpeaks/TailAsTurn/Triton V3 Switchback Fronts/5100’s/1” Eibach Rear Coils/CaliRaised Ditch Pods&Brackets
Sold-2005 V8 Dorado Gold Pearl Ltd
Retired-1996 Evergreen Pearl Ltd
J-Roc is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 04:03 PM #137
dktxt4r's Avatar
dktxt4r dktxt4r is offline
dktxt4r will become famous soon enough dktxt4r will become famous soon enough
dktxt4r's Avatar
I'm a little frustrated. My rear camera doesn't work and communication is horrible right now. No resolution in sight.
dktxt4r is offline   Reply With QuoteReply With Quote
Old 11-21-2019, 01:25 PM #138
funrunner91's Avatar
funrunner91 funrunner91 is offline
funrunner91 is on a distinguished road
Plan on installing mine this weekend but after reading all the post I’m pretty worried has anybody’s Kit successfully worked?
All stock 2014 trail edition
funrunner91 is offline   Reply With QuoteReply With Quote
Old 11-21-2019, 01:35 PM #139
Gonecamping's Avatar
Gonecamping Gonecamping is offline
Gonecamping will become famous soon enough
I have full function, and had great communication in resolving the issue I had.
There was a faulty rca (female) and Brian sent one of the relay harnesses out immediately (after spending the course of 2 days troubleshooting - only had limited time at night for me to work on it).
I'm sure others have had success installing without any problems. Mine just happened to be a faulty connector.
Gonecamping is offline   Reply With QuoteReply With Quote
Old 11-21-2019, 01:44 PM #140
aznxpsyko aznxpsyko is offline
aznxpsyko is on a distinguished road
Make sure you wire everything up and test it before you start tucking and routing thru firewall. I recommend using wire loom to protect the wires in the engine bay. Also, I routed the RCA cable thru the large grommet (directly below the hood release cable) and had no issues there.
The only issue I had was the front camera not turning on. I was scratching my head for hours, only to find out I had a bad ground the entire time lol.
aznxpsyko is offline   Reply With QuoteReply With Quote
Old 11-22-2019, 01:41 PM #141
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Mine has worked perfectly. Got to test it out on the trails and it definitely helped!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 11-24-2019, 09:45 PM #142
buckalew buckalew is offline
buckalew is on a distinguished road
no issues with mine.
I did watch his video a thousand times trying to visualize it on the truck.
I wish someone would do a step by step video on an actual vehicle.
It took me longer to figure out where to mount the front camera(since there are no instructions on this)
buckalew is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 10:09 AM #143
Styner89's Avatar
Styner89 Styner89 is offline
Styner89 is on a distinguished road
Styner89's Avatar
Mine has worked great from the first day of install. I kind of waited a bit after running the wires to the front camera to actually install the front camera because I needed to remove license plate and bracket to get drill in. It have all worked from day 1 though. If you have problems I would check the connections you have to make first. I used the solder seal wire connectors listed below and they worked great.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
CURRENT-2019 TRD OR, Cooper AT3 XLT 285s, Clazzio leather seat covers, XD High/Low beam LEDs, RSG Angled Sliders, Eibach Pro Truck lift
SOLD-2004 V8 4x4, Eibach Pro Truck lift, Wildpeaks
Styner89 is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 06:10 PM #144
CementTruck CementTruck is offline
CementTruck is on a distinguished road
Curious if you have the nav override in yours. I have yet to install mine but wondering if all the successful installs also do not have the nav override.
CementTruck is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 11:23 PM #145
J-Roc's Avatar
Real Name: J
J-Roc's Avatar
Real Name: J
I did not add the front camera option, I am going to order and add it after winter as I don’t want to get in that deep while the snow falls here.
I installed the anytime back up harness and the nav override. Both have worked great, no issues so far.
Old 12-25-2019, 04:44 PM #146
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
So did anyone hook up the blue and grey wires on the switch for illumination?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 12-25-2019, 11:09 PM #147
Charlievee's Avatar
Charlievee's Avatar
So far, so good with the install. Test was successful, just need to mount the front camera when i finish the china pro grill mod tomorrow. I think "old red" spoiled me with his work. Think the ground wires could be a bit longer (on the relay/switch) camera feed a few feet shorter and the directions well, better. Not sure why one needs to add connectors, no reason why male/female could not be added from the "manufacturer", but like i said. Spoiled by old red (to bad the powers that be shunned him).
Old 12-26-2019, 10:48 AM #148
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
I did for awhile, then I disconnected them.
i wasn't happy with the way it "looked" when it was on so I disconnected the illumination. Where I have it mounted it is next to the mirror switch and it's not lit either so it looks better in dark mode.
nglayton is offline   Reply With QuoteReply With Quote
Old 12-26-2019, 04:11 PM #149
Charlievee's Avatar
Charlievee's Avatar
Install complete. Nice that the front has the reference lines.
Anytime Backup Camera/Front Camera Group Buy ***CLOSED***-20191226_135419_resized-jpg  Anytime Backup Camera/Front Camera Group Buy ***CLOSED***-20191226_135458_resized-jpg
Old 12-31-2019, 12:00 PM #150
redneckcrawler's Avatar
redneckcrawler redneckcrawler is offline
redneckcrawler will become famous soon enough
My front doesn't have reference lines. now I' jealous.
redneckcrawler is offline   Reply With QuoteReply With Quote
brian , buy , group , list , people
HTML code is Off
Anytime Backup Camera and Front Camera - February 2017 Group Buy bjohnston115 Group Buys 101 05-06-2020 11:39 AM
Anytime Backup Camera - GROUP BUY - 2017 bjohnston115 Group Buys 37 10-04-2018 02:07 PM
