11-04-2019, 10:13 AM
#106
Originally Posted by TodiN
Can you post some pictures on how you routed the RCA extension cable, including the firewall pass through?
How long did it take you to install it?
Thanks
Took about 2-3 hours. Biggest challenge was getting the RCA through the firewall. It didn’t help that I already had two existing sets of wiring harnesses through the firewall for my light bars so I didn’t have enough space to feed it through. I had to cut a slit in the rubber grommet (the one where the bigger factory harness and hood release cable goes through). Once I did that, it was pretty easy to get it through with a coat hanger. Sorry don’t have pics of it.
11-05-2019, 12:14 AM
#107
Mine showed up today!
order #2742 has arrived.
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
11-05-2019, 02:45 AM
#108
Well spent 3 hours installing.
Used crimp/heat shrink connections for everything, followed the instructions to a t.
Turned on truck, flipped the switch, black screen ... Put it in reverse ... Same thing ...
Disconnected all harnesses and reinstalled factory ... camera worked in reverse.
This is on a 2019 TRD OR. Not sure what's going on.
I skipped installing the front camera, but everything is hooked up (ran rca wires under the dash with the red wire covered in heat srink). Not sure if that has something to do with it, but doubt it.
Any help is appreciated (emailed anytimebackup).
11-05-2019, 03:38 PM
#109
Received mine on the first and installed today. Easy install and everything works perfectly.
11-05-2019, 03:41 PM
#110
Check your grounds. I grounded mine on a dash bracket bolt inside and under the hood I put it with the rest on bussbar for my switchpros setup.
11-05-2019, 05:46 PM
#111
Appreciate the advice. They are on grounded mounts but I will go recheck (maybe crimp new lugs).
Brian has been very responsive and he is helping troubleshoot everything.
So far, I have stock reverse activated camera functionality and switch activated reverse camera. Next step is getting the front camera/harness functioning.
11-05-2019, 09:33 PM
#112
Anyone else having the issue of both lights on the switch lighting up when you switch it to front camera?
When switch is clicked to rear, only the rear light is illuminated. Which I'm assuming is the correct way.
I've seen a few install videos, and their switch lights up the same way.
Other than that, no issues.
Sent from my SM-G975U using Tapatalk
11-05-2019, 09:41 PM
#113
My order came in yesterday.
I've added it to my collection of things I need to install to include a Sprint Booster, dash dimmer doohickey, and differential breather kit.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
11-06-2019, 12:41 PM
#114
Is this switch for the Nav override so you can switch on and off?
11-08-2019, 09:56 AM
#115
Real Name: J
Real Name: J
That’s exactly what it is. Just got my kit yesterday.
It’s nice that we have the option to turn it on and off, but I have been trying to figure out a time when I would need to turn it off....?
Wondering if it’s possible to bypass the switch all together and just have it constant.
As simple as connecting the red and black together on the white wire...?
Maybe someone can chime in.
2013 Blizzard Pearl Ltd/14’+Tail Light Swap/Anytime Backup Cam/275-55-20 Wildpeaks/TailAsTurn/Triton V3 Switchback Fronts/5100’s/1” Eibach Rear Coils/CaliRaised Ditch Pods&Brackets
Sold-2005 V8 Dorado Gold Pearl Ltd
Retired-1996 Evergreen Pearl Ltd
11-08-2019, 05:43 PM
#116
So I asked this before ordering.
It's advised to leave it turned off so the GPS can update more efficiently. Only switch when needed.
11-08-2019, 05:46 PM
#117
Update, worked through troubleshooting.
Brian sent out a new a relay harness (awaiting its arrival). There was a bad RCA connection unfortunately.
I can take apart my dash in about 2 mins now tho so there's that! And I have a much better concept of the circuit that makes everything work lol.
Can't wait to get the front hooked up.
11-08-2019, 07:04 PM
#118
Real Name: J
Real Name: J
“Update” in what regards?
11-08-2019, 07:40 PM
#119
This is the response I received:
"It can be left on all the time but we advise using a switch because when overridden your gps position on the map will not smoothly update so that is why we recommend the switch."
Hope this helps.
11-09-2019, 12:14 AM
#120
Real Name: Neal
Real Name: Neal
The Update refers to your location. It can't update your location.
If the override is left on, your location is less accurate and the on screen position starts to drift.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
HTML code is Off
