Off Road Trailer Group Buy (that's right!)
DannyLlama
***UPDATE**
25% OFF Offer is activated through 2/14/2020
Simon has agreed to extend group buy to 2/14!! Get your orders in!
Any orders ordered after today will be delayed due to the time it takes to produce.
For starters - HAPPY NEW YEAR!!
What a way to kick start the new year with a new trailer!!
Who Fourleafcloverfabtrailers ... They don't have a website but you can contact them direct on IG, user name - fourleafcloverfabtrailers
Website - Four Leaf Clover Fabrication
They are a new trailer fabrication company that are focused on producing trailers similar to the M416 trailers
Where The company is located in Northern California but can deliver depending on location. Personal delivery to Colorado (buyer covers gas) and shipping fees apply outside of that range.
What OK!! So here is the deal. We will need four committed buyers to unlock a 25% off of the retail price of $4,000.00
Specifications to the model in this group buy is as follows:
  • Full builds with brakes
  • Box is constructed of 14 Gauge steel laser cut and CNC bent
  • Frame is 2x3 .125 wall rectangular box tubing.
  • Cargo box dimensions 72 inches long, 26.25 inches tall. 50 inches wide at the top and 40 inches wide at the floor. 46 cubic feet.
  • Overall length is 141 inches
  • Overall width is 64 inches
  • Frame and body are powder coated (some custom colors require automotive grade spray process)
  • Raptor liner is sprayed inside the tub. (linex or rhino lining is an option at an additional charge)
  • Trailer can accommodate up to a 37 inch tire.
  • 2- inch hitches are utilized at both ends
  • Nose box included
  • Trailer comes completely wired with LED brake, turn and marker lamps
  • Axle is rated at 3500 pounds and has electric brakes (tow vehicle will need a brake controller installed)
  • Multiple wheel bolt patterns available
  • Lid is supported by 3 heavy duty hinges and also features 2 gas struts to aide in opening. Latches are lockable. Includes two load bars to support a tent.
  • Rear of trailer features drop tail gate for easy access
Available upon request (not included)
  • Group 31 battery $250 with tray. (installed in nose box)
  • Custom colors in powder are $300, color matched with PPG paint is $800-1000
  • Fridge tray with tie downs $200
  • Spare tire mount that swings out of the way $450
  • 19 gallon water tank with manual pump $400
  • Jerry can holders $150 each
  • Awning mounts $200
  • Additional RTT load bar $50 each
  • RTT raised mount load bars ( for tents with an annex) $200
  • Power outlets in cargo box. $40 each
  • Power inverter. 1000 watts. $200
Lead Time Disclaimer Four to six week to complete building one of these trailers.
PICTURES!!!!
I've seen these on 95eighty's IG, but didn't know they had a separate account. These look like awesome trailers, and I'd love to participate, but the timing doesn't work for me. Hope it works out for some others. Have you posted to Expedition Portal?
Big Question - are these trailer manufactured and produced in accordance to NHTSA regs? Meaning - will they have individual VINs?
Why this is a big deal? The NHTSA has been cracking down on the Mom & Pop "trailer companies" around the country who have been trying to bypass the system by claiming the manufactured trailer is a "home built".
Looks like a cool trailer. Just wanted to make sure it's all legit. Some states are weird about registering trailers.
Official response - Its built to nhsta guidelines and that I am a NATM member.
Vin tags are issued by the DMV and linked to the registration when they do the inspection.
Just to clarify...by VIN tags, you mean the manufacturer applied VIN stickers on the frame, correct? Those specify the gross weight, tires specs, manufacturer info, etc and have the VIN stamped / printed on them.
If the DMV is issuing the VIN 'tag', the trailer is likely considered 'home built' and must be then inspected by the DMV for special VIN assignment - in the state registered.
VIN assignments for manufacturers may be obtained via SAE VIN formula registration and registration via the NHTSA.
SAE Global Standardization: WMI/VIN Information
https://www.nhtsa.gov/sites/nhtsa.dot.gov/files/frenchik-vin-vpic.pdf
While I am certain this is a proper, well built trailer...groups not doing this are not helping the industry.
Thanks for the info [MENTION=148699]Terrapod[/MENTION]. Should I add you to the list of the group buy?
Nah. Simply trying to help out a fellow fabricator. Best of luck with your trailer. Would love to see it thrive. Be sure to hit the Jeeper forums. They will be all over this.
Thanks for the pointers... any specific jeep forum to post on?
erinobr2000
