Old 01-07-2014, 07:27 PM #1
MT4X4's Avatar
MT4X4 MT4X4 is offline
MT4X4 is on a distinguished road
MT4X4's Avatar
GX470 Rear Coil Conversion Kit Available @ Metal Tech 4x4
It is well known that the GX470 is an up and coming 4x4 platform that is now within the price range for a lot of people. Being aware of the rear air bag suspension and the downfalls that it has we decided to come up with a coil spring conversion kit to get rid of the air bags and switch to a traditional coil spring that the FJ Cruiser and 4Runner platform uses. We have seen other conversion kits out there but felt that they weren't close to what Toyota had designed. Being very familiar with the FJ Cruiser and 4Runner (they use the Prado 120 platform) suspension set up we developed this kit to be as close to factory as possible. Starting with using the Prado 120 secondary spring isolators and then using the polyurethane spring tail isolator that has the built in ramp to conform to the spring. We then have a spring locator that bolts onto the axle housing to help keep the spring in place if it were to come loose. This kit is 100% bolt on and requires zero modification.
This kit is designed to be used on your stock GX470 using factory coil springs from a 4Runner/FJ Cruiser or to raise the rear end 2-3" to match the lift in the front.
For a limited time introductory offer, if you purchase a full coilover suspension kit we will include the rear coil conversion kit for free with free shipping. This offer will expire on January 31st, 2014. To receive this discount you will need to use the Coupon Code - GX470
Metal Tech is offering two different versions of this rear coil conversion kit, one that comes complete with the Prado 120 secondary spring isolators and the second with just the lower half and you source the secondary spring isolators.
MT4X4 is offline   Reply With QuoteReply With Quote
Old 01-07-2014, 07:35 PM #2
MT4X4's Avatar
MT4X4's Avatar
Here are a couple of photos of the lower half installed to show it looks.
Old 01-08-2014, 10:54 AM #3
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
This kit would likely work for the 4th gen 4Runner LTD's with rear air suspension as well, would it not?
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 01-08-2014, 01:19 PM #4
MT4X4's Avatar
MT4X4's Avatar
I am going to assume yes, I haven't seen the 4Runner set up but seeing that the 4Runner frame is the Prado 120 and the GX470 is a Prado 120 it would be a safe bet. Do you have pictures of the air bag set up?
Old 01-08-2014, 01:20 PM #5
IanB's Avatar
IanB's Avatar
No, I've got a GX470, just asking for others as I believe they are the same setup in the rear.
Old 11-05-2014, 05:18 PM #6
Whiskytangofoxtrot Whiskytangofoxtrot is offline
Whiskytangofoxtrot is on a distinguished road
4th gen market
If you guys could rebrand/tool this product to us 4th gen runners with the inevitable failing setup, I'd safely say you'd sell more t4r units than the GX.
Looks like some time has gone by since the OP, have you had any 4runners convert with your system? I'm pretty much sold on the kits just looking for confirmation.
Rebar has pix of the air setup on his build if you haven't seen the 4runner rear air.
Rebar's Build Thread - Long Version
16 Trail Premium KDSS- 5100's (2.5 Front/ Icon 2" rear springs) l Diff. drop 285/70/17 BFG KO2 l Timbren bumps l LaminX l
07 Limited- v8 4x4 RAS /275/65/18 /Grabber-AT2 >210k
SOLD
Whiskytangofoxtrot is offline   Reply With QuoteReply With Quote
Old 11-05-2014, 05:49 PM #7
470SNC's Avatar
470SNC 470SNC is offline
Real Name: Sang
470SNC is on a distinguished road
470SNC's Avatar
Real Name: Sang
the 4runner and GX airbag wise are the same, it will work for a 4th gen 4runner with air ride
470SNC is offline   Reply With QuoteReply With Quote
Old 04-23-2015, 05:46 PM #8
paraordnance's Avatar
paraordnance paraordnance is offline
paraordnance is on a distinguished road
Yes. Its direct fit in 4Runner with rear air. I just installed Toytec Ultimate kit and used this kit from Metal Tech. Works great
2004 4Runner Limited V8 4WD
Toytec Ultimate 3" (X-REAS & RAS - delete). LS460 + STi retrofit, Switchback Halos, LEDs in/out, Fog light mod.
CBI front bumper. 285/70/17 Duratracs.
JVC KW-V50BT with Hertz HCP4D & Hertz HCP1D, Hertz ESK-165 components and JL 10TW3 in custom stealth enclosure. Backup camera and steering wheel controls.
paraordnance is offline   Reply With QuoteReply With Quote
Old 12-29-2015, 11:17 AM #9
chips2002 chips2002 is offline
chips2002 is on a distinguished road
Is the lower half required for this install? I'm trying to route air lines for the Airlift system and was planning on using the hole where the lower spring tail isolators would attach onto the rear axle.
chips2002 is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 04:38 PM #10
OCGX470 OCGX470 is offline
OCGX470 is on a distinguished road
Install
FYI, if I didn't have a buddy to help, I would have probably lost a finger trying to install my HD coils!
OCGX470 is offline   Reply With QuoteReply With Quote
Metal Tech Sliders jbstrd 5th gen T4Rs 55 09-18-2018 11:58 PM
20% Off Metal Tech Rear Long Travel Suspension Kits MT4X4 5th gen T4Rs 0 11-25-2013 02:47 PM
4th Gen Metal Tech Offset Rear Lower Links Install cmiller 4th Gen T4Rs 7 06-05-2013 01:14 AM
$50 Off Rear Upper Links - Metal Tech 4x4 MT4X4 5th gen T4Rs 0 11-13-2012 07:27 PM
10% off code for Metal Tech 4X4!!! Krazynative 4th Gen T4Rs 3 02-24-2011 03:48 AM
