01-25-2017, 06:03 PM
#16
Originally Posted by DeathCougar
GX470 has air suspension I believe, so that might make a difference. Toyota says they have different part numbers
Will yes, different part number due to non elocker and elocker. But fjc will bolt straight up on to gx470 and 4th 4runner
(DD)-97 4runner limited Green. Camburg uca, Icon w/700 Rear 210v w/ Foxs, Arb locker, Gear- 4.88 F&R. Tundra Trans cooler. All armor BFF
(Crawler) 95 Toyota pickup 22re, dualcases 4.7, Longfields, 37s, Dual Arbs.
IG: Jaysen4runner
01-27-2017, 03:25 PM
#17
Have you actually confirmed this? FJ also came with a non-elocker option and thats listed as a different part number as well
Parting Multiple 4Runners HERE
Also parting 1996, 1997, 1998. 1999, 2000, 2001, and 2002 4Runners! PLEASE PM any requests or visit my page PNW 4Runner Connection
01-27-2017, 03:27 PM
#18
Originally Posted by kylebacc
That true, but if it's just a matter of cutting off the mounts and welding the air suspension mounts, it could be something that someone is able to do? lol
The FJ is the same width?
Just curious...how much are you selling for?
@ kylebacc
$700, includes the switch but you have to arrange transport. I have no way of strapping to a pallet or anything else.
01-28-2017, 05:23 AM
#19
Not to be a dick, but acourse the part Number won't be the same. 2 different vehicle. I been rocking crawling for 10 yrs now I think I know what fit in what. It's pretty common most toyotas are interchangeable. If you ever look at a 4th 4runner and a fjc look at the links in the rear end and you see what I mean by it will bolt up.
IG: Jaysen4runner
01-28-2017, 03:16 PM
#20
Let's not start a "I've been doing X longer I'm smarter than you" battle. If you haven't done the actual swap, you are merely assuming it will fit. And we all know what happens when you assume.
Can you provide concrete evidence? I'd certainly hate to sell someone an axle only to find out it doesn't fit. And if it requires modifying the axle it's simply not a bolt up swap. Not everyone has the access or ability to weld.
01-31-2017, 04:15 PM
#21
As far as I know, the FJ 3rd will fit, however the locker will require a couple of holes drilled into the diff (?) to accommodate the wiring, etc. Not something I'd have a regular mechanic do, but it shouldn't be too expensive to work out with an experienced offroad shop.
GCLC# 2259 TCLA# 22851
2003 Toyota 4Runner SR5 4.0 V6 SOLD
2007 Lexus GX470 IN PROGRESS
01-31-2017, 04:16 PM
#22
Originally Posted by Morphyne
Let me know if you ever get a gx and pull the RAS. I love the rear air ride and would love to have some cheap spare parts
I have the rear air suspension parts from my 2007 gx. Air bags, lines, sensors, all intact and all for sale. PM me if you're interested.
