Old 11-07-2019, 04:46 PM #1
Flighht2k Flighht2k is offline
Flighht2k is on a distinguished road
Window switch
I think the drivers side window switch went out in my 05 gx470. The back drivers side window will not roll down from the drivers seat. But it works fine at the actual window. The replacement switch is 6-700 dollars. Phew. How hard is it to replace it? Or hopefully am I missing something as to why it may not be working?
Appreciate the help
Flighht2k is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 02:44 PM #2
Window switch
Took battery cable off and tried to reset the windows. Now I can’t open or close either back window from the drivers side.
Old 01-11-2020, 01:38 AM #3
Gen1FTMFW Gen1FTMFW is offline
Gen1FTMFW is on a distinguished road
Been a bit, but if you haven't figured this out out yet, you just need to reset the switches. Go to each door, roll down the window about halfway, wait a second, then roll the window up. When it gets to the top, hold the switch in the up position for a few seconds. After you do this to each window, you should be able to control them from the driver door panel.
Gen1FTMFW is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 10:14 PM #4
Oldmanb777 Oldmanb777 is offline
Oldmanb777 has a spectacular aura about Oldmanb777 has a spectacular aura about
If that doesn't work. All the wires typically go through the drivers door boot. Since the drivers door is the most used, it gets the most abuse. Those wires are constantly being bent, back and forth, work hardening the wires. Then the wires become brittle, and break. Often this is the problem. Fix the broken wire.
Oldmanb777 is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 03:24 PM #5
[email protected] hankus15@yahoo.com is offline
hankus15@yahoo.com is on a distinguished road
Saved
hankus15@yahoo.com is offline   Reply With QuoteReply With Quote
dollars , drivers , side , switch , window
Tailgate / back window doesn't work (motor works and it isn't the window lock switch) seattlee 3rd gen T4Rs 17 04-03-2022 08:58 PM
4WD selector switch light/Rear window light switch replacement Ventil8 4th Gen T4Rs 22 10-09-2020 11:24 PM
2014 4runner 4x4 switch and rear window switch doesn't light up? slee05 5th gen T4Rs 5 06-28-2014 05:10 PM
1991 T4R - Rear Window Switch and Window Lock Switch ? El_Estrago Classic T4Rs 0 07-25-2011 04:03 AM
rear window switch, sunroof switch cdmasm Classic T4Rs 2 07-06-2006 04:23 PM
