Old 12-11-2018, 12:55 PM #1
gx470 gx470 is offline
gx470 is on a distinguished road
rear spring conversion heights
I am trying to figure out what spring kit to get since I don't exactly know what stock height is. I have the front raised a little via holstein 5100s and the rear air back "trick" but I don't know what I need to get the exact height that I have now and want. I need a rear center of wheel to fender measure measurement of 21.5-22" or a ground to fender measurement of 35.5-36" roughly. Can you guys please help? Do I go with Arnott or Suncore and then do a spacer on the bottom like this: https://www.southernstyleoffroad.com...onversion-kit/
Or, do I do a FJ cruiser spring? I really want as comfortable as possible. Thanks,
gx470 is offline   Reply With QuoteReply With Quote
Old 01-15-2019, 11:43 PM #2
spoonmectr spoonmectr is offline
spoonmectr is on a distinguished road
Your going to want to go with Moog 81081 springs and the Metal Tech spring perches. Also make sure to get the Toyota spring isolators.
spoonmectr is offline   Reply With QuoteReply With Quote
Old 01-16-2019, 02:54 PM #3
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
Do you carry the 3rd row seats or any extra weight on a regular basis?
I'm running stock fronts, FJ Cruiser rear springs w/ SSO conversion kit w/ no spacers, and ended up with about 1/2-3/4" higher in the rear than stock on "N" setting, no 3rd row seats or extra weight.
If I could do it over again I'd have gone with 4Runner springs as the FJC springs seem to ride smoother with a bit of weight in the rear, and then I could add spacers from the SSO kit to achieve the height I was after.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 11:45 PM #4
Oldmanb777 Oldmanb777 is offline
Oldmanb777 has a spectacular aura about Oldmanb777 has a spectacular aura about
What's "air back trick"?
Oldmanb777 is offline   Reply With QuoteReply With Quote
Old 01-19-2019, 10:57 PM #5
the airbag trick is where you add washers in between the mounting plate of the sensors and the frame of the truck in order to trick the sensors into giving more height. The down side, however, is the more air put into the bags to raise the height the stiffer the system becomes.
Old 04-03-2019, 02:41 PM #6
mitchell.marsh mitchell.marsh is offline
mitchell.marsh is on a distinguished road
I am leaning toward replacing the air bags with a coil spring conversion kit. My concern is the ride. Will the car ride rougher with the coil springs? I am going to sell the car after it's fixed. Should I just replace the bags or go with the coil springs?
mitchell.marsh is offline   Reply With QuoteReply With Quote
rear leaf spring conversion Dezerts10 3rd gen T4Rs 12 01-17-2018 02:34 PM
New tires - front/rear lift heights are different? Blute 4th Gen T4Rs 4 07-03-2013 10:32 AM
Has anybody done a leaf spring conversion on a 4th gen? theelectrician 4th Gen T4Rs 0 11-17-2011 06:25 PM
