Old 02-14-2020, 03:14 PM #1
Hapeacres's Avatar
Hapeacres Hapeacres is offline
Hapeacres is on a distinguished road
Hapeacres's Avatar
key programming
Does anyone know how to program a chipped key for the 06 GX470? I did a search and nothing came up. I did one for my 04 4Runner before so i don't know if there is a similar process such as inserting key open. close door, etc as posted on the 4th gen site.
Hapeacres is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 12:49 AM #2
drzl fabrication drzl fabrication is offline
drzl fabrication is on a distinguished road
I believe you would need equipment
Toyotas I believe can be done without a special tool. But with Lexus I believe you would need a special obd2 scanner to program the transponder in your key.
here is a link I found.
Toyota, Lexus, and Scion Transponder Chip Key Programming Instructions
drzl fabrication is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 02:36 PM #3
TLar25's Avatar
TLar25 TLar25 is offline
Real Name: Taylor
TLar25 will become famous soon enough TLar25 will become famous soon enough
TLar25's Avatar
Real Name: Taylor
I was able to get a fob programmed using the same door open/close process as the 4th gen, but I haven't been able to get the immobilizer working yet so I might end up buying the cable and doing the techstream in 5 minutes process you can find on ih8mud
Sent from my KB2007 using Tapatalk
1985, 22re, 5spd, 4x4, Marlin crawler dual transfer case, locked fr&rr, 35's
1996, 5vz-fe, Auto, 4x4, Bilstein/ome lift, tundra 17's, 33's
Sold(regret it)- 1999 Highlander edition, Auto 4x4, 3"lift, factory rear locker
TLar25 is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 08:53 AM #4
TodiN's Avatar
TodiN TodiN is offline
Real Name: Todi
TodiN will become famous soon enough
TodiN's Avatar
Real Name: Todi
I have a 2018 TRD OR and I was not able to program it using open/close-door method. Using Techstream v14.1 with a Win7 did the job (v12 and v13 did not do the job).
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
TodiN is offline   Reply With QuoteReply With Quote
close , inserting , key , process , similar
Key FOB Programming bpearson 4th Gen T4Rs 37 03-20-2023 04:48 AM
Programming a key TerraCrawler 5th gen T4Rs 19 04-19-2022 02:45 PM
Key FOB Programming Help! navygse1 3rd gen T4Rs 5 07-31-2015 12:40 PM
key programming evarodz New Members 1 04-03-2014 11:41 PM
