Old 11-29-2011, 11:28 AM #1
uwrasta uwrasta is offline
uwrasta is on a distinguished road
broke off a bolt trying to remove front skid plate 05 2wd
I was doing the differential and broke off the front drivers side skid plate bolt. I believe there is for of them??? I changed the rear with no problem with mobil 75-90 and would like to finish off the front. Any Ideas on how I remedy this problem??
let me know jedi's!!!
rd
Also thanks for the details on changing to diff oil. It was a breeze thanks to this site!!!!
uwrasta is offline   Reply With QuoteReply With Quote
Old 11-29-2011, 11:49 AM #2
wrestler157's Avatar
wrestler157 wrestler157 is offline
wrestler157 is on a distinguished road
i had the same problem. them bolts get pretty bad but i did this and its great now
Toyota 4Runner Skid Plate Bolts
wrestler157 is offline   Reply With QuoteReply With Quote
Old 11-29-2011, 12:45 PM #3
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
rd
Where is it broken off at? If you can get at it, you can try slotting the end with a cutoff wheel and back it out with a screwdriver and vice grips, or try welding a nut to the end and turn it that way. If it's buried, you could look to see if maybe there's a captured nut on the back side you could grind free? Barring that, a good drill just became your best friend.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 11-29-2011, 08:09 PM #4
Metzbower Metzbower is offline
Metzbower is on a distinguished road
I don't know how hard the metal on the bolt is but the same thing happened on a transmission mount bolt on a Celica. I drilled a small hole in the center of the bolt and screwed in an "Easy Out". Basically it is threaded backwards and as it gets tighter and tighter it puts pressure on the bolt to come out. Apply penetrating oil in advance to make the threads break free more easily. If it does not work, drill it out and use a larger bolt, after tapping new threads.
Metzbower - German for over-educated redneck wanna be.
2007 SR5 V6 4wd 4Runner, Yakima roof rack, Alpine head unit, Polk speakers, Weathertech Extreme floor mats, FJ suspension, LED interior lights
Metzbower is offline   Reply With QuoteReply With Quote
Old 11-29-2011, 08:15 PM #5
how many bolts are there????? thanks
Old 12-02-2011, 10:08 PM #6
Burt Burt is offline
Burt is on a distinguished road
Really soft metal on my '08 bolts. Had to drill small hole like mentioned above, then was ablke to just un-screw by hand. Replaced all 4 bolts on skid plate with stainless bolts, no tapping new threads needed. Maybe I was just lucky...
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
Old 12-03-2011, 10:37 PM #7
KB084RUNNER KB084RUNNER is offline
KB084RUNNER is on a distinguished road
Get a carbide left hand twist drill bit and some PB blaster. Soak the stud overnight and then drill it out running your drill in reverse. Then use some loctite anti-seize on the bolts in the future.
2008 4Runner Limited 4.0L V6
KB084RUNNER is offline   Reply With QuoteReply With Quote
Old 12-07-2011, 11:50 PM #8
Radial GT's Avatar
Radial GT Radial GT is offline
Radial GT is on a distinguished road
Radial GT's Avatar
You are not alone! My quick diff fluid change was hung up with me snapping two of those bolts! I had to drill and tap both of them. Drill straight and your can still tap the same 12mm bolt style. My arms are still sore from drilling upside down... Good luck!
Radial GT is offline   Reply With QuoteReply With Quote
Old 12-15-2011, 04:50 PM #9
toybox's Avatar
toybox toybox is offline
toybox is on a distinguished road
toybox's Avatar
That sucks! I've been putting anti-sieze stuff on the bolts every other oil change and they go in and out pretty easily.
Joe l 2003 V8 Sport 4x4
Titanium Silver
toybox is offline   Reply With QuoteReply With Quote
Old 12-15-2011, 05:15 PM #10
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
Once you get the bolt out, clean up the threads with a wire brush, and paint them with anti-seize before putting it back together. You'll never have this problem again.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Skid Plate Bolt Replacement? Noahfn 4th Gen T4Rs 4 02-19-2010 12:19 PM
Front skid plate bolt insert?? lbrunner Engines / Suspension / Wheels / Tires / Audio / Accessories 2 04-26-2008 12:08 AM
bolt sizes on skid plate ohio4runner4x4 3rd gen T4Rs 1 08-03-2005 06:52 PM
Had to Tap & Die a Skid Plate Bolt Bluto Problems & Warranty Issues 20 03-04-2005 11:39 AM
Need part number for front skid plate bolt dman90012 Maintenance/Detailing 6 07-17-2004 01:56 AM
