Old 06-04-2012, 10:35 AM #31
pickerdd pickerdd is offline
pickerdd is on a distinguished road
So, I finally had the tranny flushed last week. I should have asked to see the condition of the old fluid from the tranny. Next time I'll do a drain and fill myself instead of having it done at the dealer. The tranny definitely shifts more quietly and smoother now.
David
2008 4Runner V8 4WD Limited,
Galactic Gray/Stone Interior
Delivered 5/5/2008
pickerdd is offline   Reply With QuoteReply With Quote
Old 06-04-2012, 10:41 AM #32
Ducman's Avatar
Ducman Ducman is offline
Ducman is on a distinguished road
Ducman's Avatar
I experienced the same thing when I did my drain and fills.
More proof that there are no magical pixies inside our so-called 'sealed' transmissions.
I always get a good laugh when people post the ATF fluid never needs to be changed in our trucks.
As the miles start to rack up, transmission fluid breaks down. Period. I don't care what kind it is.
05 SR5 V8 4WD | Cracked Exhaust Manifolds| Magnaflow Catback | Bilstein 5100s | Kenwood DNX5120 Nav | Rear DVD | OEM 06+ LED Tails | Heated Leather | A/T Revos
Ducman is offline   Reply With QuoteReply With Quote
Old 06-04-2012, 02:14 PM #33
The thing that pissed me off a bit was the mechanic who worked on my truck at the dealer was sloppy. I had them do a power steering fluid flush (probably a stupid thing to do, but that's another story) and the mech got power steering fluid all over the engine compartment and some grease on the seat.
I tend to keep my truck (inside, outside and engine compartment) clean, so this kind of tweaked me. I believe sloppy work is a sign that folks don't care.
David
Delivered 5/5/2008
Old 07-14-2012, 08:28 PM #34
ChaosStarter ChaosStarter is offline
ChaosStarter is on a distinguished road
MY GARAGE
MY GARAGE
Originally Posted by DexTech View Post
I just worry that with the sealed trans and no dip stick to check the levels if I do have a mechanic change the fluid there isn't a reasonable way to see if the fluid level is correct.
I would have to trust that either the machine or drain and fill replacement is at the proper level. I'm not THAT trusting ;)
LOL. What are you, crazy?
There's an exact procedure for checking the trans level. However, it needs to be in a precise temperature range, and the truck (perferably) should be on a lift to make it easier to access the fluid level plug. When it's in the range, it' should be a constant drip. If there's nothing, then add. If it's pouring out, let it.
If the temp is too hot, then then engine needs to be shut off to let the fluid cool for a bit.
ChaosStarter is offline   Reply With QuoteReply With Quote
Old 07-14-2012, 10:15 PM #35
ToolmanJohn ToolmanJohn is offline
ToolmanJohn is on a distinguished road
Just did the change myself last week
With tthe assistance of my brother, I replaced all of the old fluid in the transmission by using the fluid ereturn line as the drain.
There is a sticky detailing how to do it. Because my truck has the dipstick (2003 4speed) , I had my brother start the rngine, and the fluid would pump itself out of the return line into a pan, about 4 quarts each time. I would dump the fluid into a gallon container (old windshield washer bottle) that I had already marked with marker showing quart levels. This way, I knew exactly how much to put back in each time.
After I reached the 13th quart , fresh fluid was starting to come out. So I refilled to the cold mark on the dipstick, and drove around until it was warmed up (about 1/2 hour) . Checked the fluid level, it was down about a quart, and filled.
It's been fine and does shift just slightly smoother. I will say the old fluid did NOT look all bad. It still had some red color to it and smelled just like the new stuff. No burnt smell. I don't know how long a transmission would last without the fluid change, but it must depend on how hard it's used. If the truck is a daily driver with no towing or hard wheeling, it probably would last a long time like Toyota says. BUT it's easy enough to change out and have that insurance that fluid problems won't be an issue.
2003 4runner V6 Limited 4x4 - A good ten years.
4 out of 5 dentists recommend Trident to their patients who chew gum, the 5th dentist recommends chewing a cup of pure cane sugar before bedtime. Don't go to that dentist!!!
ToolmanJohn is offline   Reply With QuoteReply With Quote
Old 10-09-2019, 06:02 PM #36
Captsolo Captsolo is offline
Captsolo is on a distinguished road
Originally Posted by <<<< View Post
Never changed mine in any cars. I dont see what can happen to ATF. Hydravlic fluid doesn't break down like engine of differential oil.
But, doesn't your fluid change to black in color from all the wear?
But don't get me wrong. I wonder if ATF needs changing at all!
Captsolo is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 09:40 AM #37
<<<<'s Avatar
<<<< <<<< is offline
<<<< will become famous soon enough <<<< will become famous soon enough
MY GARAGE
<<<<'s Avatar
MY GARAGE
Changing it makes sense but Toyota recommends it only if severe use such as towing. I've heard people having issues after messing with old transmission and would be better off if left it alone. Ill just stick with factory recommendation and let it be unchanged for normal driving.
Who Dares Wins
2013 TRAIL KDSS / Forged TRD 17x8.5 Wheels / Nitto TG 285/70/17 / Shrockworks Sliders / ASFIR Aluminum Trans Skid / 5000K HID Low HL / 5000K 10000 Lumen LED High HL /3000K LED Fogs / TRD Billet Oil Cap / B&I Carbon Fiber Dash / TRD Black Shift Knob / LED Interior / XUJI Leather Steer Wheel / Aluminum Pedals / Aluminum Battery Holddown / Northstar AGM battery / TRD Carpet Mats / LED floor lights / ARB on-board Air
<<<< is offline   Reply With QuoteReply With Quote
Tranny fluid change Aquabear Maintenance/Detailing 22 06-11-2011 06:48 AM
2003 4Runner: automatic fluid change? testrider 4th Gen T4Rs 9 02-15-2009 03:07 PM
Automatic Tranny Fluid Change Question Steve8v92 Classic T4Rs 0 01-07-2009 04:36 PM
Tranny fluid change...which fluid? wm69 3rd gen T4Rs 3 02-12-2008 01:11 AM
What is the proper way to check your automatic tranny fluid ? MudbogPete Maintenance/Detailing 3 11-28-2003 01:54 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
