Old 11-21-2005, 02:07 PM #31
RL Lemke's Avatar
RL Lemke RL Lemke is offline
RL Lemke is on a distinguished road
RL Lemke's Avatar
Re: Install q's
Originally posted by Whoknows
I'm going to drill and use bolts as you did for installing the adapter plate.
What size whole did you drill in the bumper?
Did you use a washer on the inside of the bumper to ensure the bolt heads are secure?
Things I should be particularly careful about?
I have a large collection of stainless bolts, so nearly every project I have uses these bolts & nylock nuts.
The hole size? Just a bit bigger than the bolts you use.
Washer? Use a locking washer to help keep it from spinning. I also squirted a bunch of 1 minute epoxy in the hole to hold everything in place. There is a Devcon brand with a long tube that mixes the two epoxy parts as you squeeze. Lowe's has it I think, if not Home Depot. Then I held the bolt tight as it cured.
When I thighteded the nuts, the bolt broke free from the epoxy. I used Vice Grips to hold the bolt as I completed tightening the nuts.
If I were to do it again? I would probably add angle iron to support the weight from the top of the bumper too.
All steel parts I painted with several coats of rust proof paint after drilling the holes.
RL
Dallas, Texas
2004 4Runner Sport Edition
RL Lemke is offline   Reply With QuoteReply With Quote
Old 11-21-2005, 10:51 PM #32
Whoknows's Avatar
Whoknows Whoknows is online now
Whoknows will become famous soon enough
Whoknows's Avatar
Thanks for the advice and info. Since I'm going to be also installing the Ams-Oiler (overkill? Perhaps, but so is most of what we do here, and I'm psyched about it) I'm definitely going to heed your advice the bracket on top.
Thanks Again.
19 TRD ORP w/KDSS
Super White
Whoknows is online now   Reply With QuoteReply With Quote
Old 11-22-2005, 07:51 PM #33
spyne's Avatar
spyne spyne is offline
spyne is an unknown quantity at this point
spyne's Avatar
Couple of questions. Maybe I'm mistaken, but if you get into any kind of an impact that pushes back the front bumper aren't you going to crush the filters and lose your oil? Seems to me that you're going to be having to tow the 4R home from a lot of accidents that would have been driveable before. Not that any of us wants to think about getting in accidents.
How is the clearance for getting an oil filter wrench on the filters? Seems a bit tight, but again I haven't looked up under my bumper to see how much space there really is there.
BTW, nice job and interesting thread.
03 Limited V8 - Sold
X-REAS
Dorado Gold Pearl
spyne is offline   Reply With QuoteReply With Quote
Old 11-22-2005, 11:16 PM #34
RL Lemke's Avatar
RL Lemke's Avatar
I would suspect that if the impact is enough to move the bumper back that far, the 4Runner had better be towed to a garage anyway.
Minor hits, where idiots park by sound, will have no negative effect on the relocated filter.
Room to remove the filters? I have rubber strap wrenches, so no problem. Much easier than the removal from next to the anti-roll bar behind the skid plate.
Another Amsoil Oil Filter Bypass Installed-gap-jpg
RL
Dallas, Texas
Old 11-12-2020, 08:31 PM #35
The_Runner The_Runner is offline
The_Runner is on a distinguished road
Originally Posted by RL Lemke View Post
Here is the oil bypass installed onto the 4Runner oil filter location.
Do you remember which adapter that you used?
The_Runner is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 08:42 PM #36
RL Lemke's Avatar
RL Lemke's Avatar
In reality, a bypass is unnecessary because the EAO oil filters are so darn good. Look at the dimension charts and select an EAO oil filter that is a little longer if you desire a larger filtration area.
RL
Dallas, Texas
Synthetic Engine Oil Thai Maintenance/Detailing 114 02-18-2023 01:39 PM
Oil Filter Bypass theory? CJ3Flyr General Discussions 40 10-12-2018 07:44 AM
Changing the V8 oil filter from the top JB. Maintenance/Detailing 7 02-13-2015 04:15 PM
Oil Real vs. Synthetic CVsGX470 Maintenance/Detailing 175 12-27-2010 07:15 PM
FRAM oil filter oua Maintenance/Detailing 20 12-03-2006 11:57 AM
