Old 06-24-2013, 09:38 PM #1
T_Craun62 T_Craun62 is offline
T_Craun62 is on a distinguished road
Oil Leak from H**L
I have a 1990 4-Runner V6 4x4. The whole undercarriage and engine compartment of the vehicle are covered in oil. Also I am having to put a couple (Usually 3) quarts of oil into it every 3 weeks. I have heard that it maybe the gasket on the back of the oil pan leaking to where it is dripping on the drive shaft and then the oil is getting thrown around.. Does anyone have any ideas of what it could be? Also is this a common 4-Runner issue? Thanks for the help.
T_Craun62 is offline   Reply With QuoteReply With Quote
Old 06-25-2013, 03:37 AM #2
christo's Avatar
christo christo is offline
christo is an unknown quantity at this point
christo's Avatar
This is not a common issue it might be two possibilities. There could be a leakage from somewhere otherwise your engine needs a major service because if it is reducing the engine oil so you have to do the major service of your engine.
car mechanics brisbane
christo is offline   Reply With QuoteReply With Quote
Old 06-25-2013, 05:02 AM #3
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
There's absolutely no way for any of us to know where your engine is leaking oil from. You've got two options - get a good degreaser and go to town on your motor so you can see where the fresh oil is coming from (a good idea anyway, a clean motor runs cooler and is easier to work on), or pick up one of the UV dye kits from a parts store and find the leak that way.
Once you've pinpointed it, somebody may be able to offer advice on how to deal with it.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 06-25-2013, 10:04 PM #4
Ok thanks guys Ill clean her up really good and look into the dye.. Does it hurt the vehicle at all?
Old 06-26-2013, 06:27 AM #5
Real Name: Kevin
Real Name: Kevin
I've never used it, but I've never heard of it harming a motor.
Old 06-26-2013, 07:00 AM #6
dorton's Avatar
dorton dorton is offline
dorton is on a distinguished road
dorton's Avatar
The dye will not cause damage. You're not going to use very much of it, and it's designed for this job.
dorton is offline   Reply With QuoteReply With Quote
Old 06-26-2013, 07:02 AM #7
Desert Fox's Avatar
Desert Fox Desert Fox is offline
Real Name: Bill
Desert Fox is on a distinguished road
Desert Fox's Avatar
Real Name: Bill
If I was losing 3 quarts every 3 weeks, I would be checking my oil more often than every 3 weeks. That is over half of your oil you are losing.
Running it that low of oil is not a good thing. I run a larger oil filter so I can run an additional half quart of oil. Good oil is vital to the life of the engine.
Never run out of oil
Change the oil yourself so you never run out of oil
Use good quality oil and never run out of it
Keep the oil cool and clean and never run out of it
If the point I am making is not clear let me know
I pledge allegiance to the flag of the United States of America, and to the republic for which it stands, one nation under God, indivisible, with liberty and justice for all.
Desert Fox is offline   Reply With QuoteReply With Quote
Old 08-04-2013, 12:34 AM #8
A/V1's Avatar
A/V1 A/V1 is offline
Real Name: Brad
A/V1 is on a distinguished road
A/V1's Avatar
Real Name: Brad
Did you find the problem (or better yet - find the fix) that you were having?
If the oil is leaking from around the filter area, you might want to double check that the old filter gasket came off with the previous one...
Just a thought.[/
Vehicle: Black 2003 T4R Limited V8 4WD Mods & Equipment: Hail Damage; Kenwood DDX573BH/ rear camera; GX470 Overhead; DC power, A/V aux jacks, & USB plug inside center console box; DAC switch relocate; Interior LED swap; Footwell LED lighting; Muth heated signal mirrors, LED tails, & Valor exhaust tip.
Support our troops!
A/V1 is offline   Reply With QuoteReply With Quote
1990 , 4-runner , leak , oil , toyota
She's taking a leak! Rear axle seal leak that is.... fightman80 3rd gen T4Rs 76 09-18-2014 04:52 PM
Radiator leak, and oil leak maybe tranny? Not sure what should I do? ironmaidn23 Classic T4Rs 14 06-25-2013 10:34 AM
Leak Damo Classic T4Rs 2 12-21-2012 09:46 AM
New Leak - Help! bergeron37 3rd gen T4Rs 2 09-09-2012 12:39 AM
Coolant leak, whining noise, vacuum leak, alternator, starter, battery issues Max O 3rd gen T4Rs 4 12-03-2009 10:31 AM
