Old 07-17-2013, 10:16 PM #1
kwbooth's Avatar
kwbooth kwbooth is offline
kwbooth is on a distinguished road
kwbooth's Avatar
3rd Gen Center AC Vent Fix - $0.92 and tax
Good day all,
I have owned my 1996 SR5 for 4 days now and already found a home at T4R.org for finding out about my "new to me" 4Runner. So far, So good, So fun.
I was looking for a fix to the floppy ac vents and for less than the $30+ that Toyota wants for a them, each or hunting them in the scrap yard. My solution is below and hope it helps someone out and I apologize if it has been done and I didn't find the post before.
I have more pictures of the process but see that I have only 8 max uploads. I put the ones that I hope help illustrate what I did. If you need more process shots, PM me.
I picked up my parts at Lowes in the hardware section in the drawers with specialty fasteners. I picked up 2 packages of Nylon Anchor Nuts for #6 & #8 screws, just in case I messed up one, at 92 cents a package. They come in packages of 2. So technically it cost me $1.84 and tax.
They fit right into the square opening on the ac vent. They don't snap in but do fit nicely into the square cut out and I used glue to hold them in.
I needed to drill the hole a bit bigger. I used a 3/16th inch drill bit and after drilling it straight I had to wallow it out a bit more for a good fit. I held the nylon nut with pliers so as to keep the prongs from spreading out and distorting the nut. Take it slow when drilling or the nylon will just bend out of shape.
Once I had the hole the size I wanted, I test fit it.
Next, in order to not lose any or very little vent directional positioning, I snipped the prongs down to my liking.
I glued the nut in place and added a spot of black paint for aesthetics. In my picture though it is white.
Let it dry or cure and carefully install. It was a bit snug to get it into the pegs as I guess the original square inserts were more flush. But once it was in, the floppy vent issue was no more.
Hope you enjoy.
Ken
1996 SR5 2WD Auto
3rd Gen Center AC Vent Fix - alt=  3rd Gen Center AC Vent Fix - alt=  3rd Gen Center AC Vent Fix - alt=  3rd Gen Center AC Vent Fix - alt=  3rd Gen Center AC Vent Fix - alt=  3rd Gen Center AC Vent Fix - alt=  3rd Gen Center AC Vent Fix - alt=  3rd Gen Center AC Vent Fix - alt=
kwbooth is offline   Reply With QuoteReply With Quote
Old 08-17-2013, 11:43 PM #2
BlazeRunner's Avatar
BlazeRunner BlazeRunner is offline
BlazeRunner is on a distinguished road
Hey, just did the same thing with a similar piece of plastic. I used a blue anchor and could have done it better, but I just wanted a quick easy fix. The only thing not reversible on mine was the cutting I did on one of my vent blades for each front vent. Here's a few quick pics of mine. Sorry about size/quality issues but in the vehicle itself it's hardly visible
1997 4Runner Limited 4WD w/factory RR Diff Lock (4.30:1), Blue Wire Mod, KYB monomax & 'tall' coils, Falken Wildpeak AT3W 265/75 on 16x8" Raceline 887's(+1" spacing), K&N CAI, Tru-cool 4589 bypass, TB gasket mod, OEM sport hood, Satoshi style grill, steel front skid and more
"Do not go where the path may lead, go instead where there is no path and blaze a trail."
BlazeRunner is offline   Reply With QuoteReply With Quote
Old 02-07-2016, 06:29 PM #3
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
Bump for a good thread. Since I've bought mine the passenger side ac vent was cracked and missing pieces. These worked great:
Little super glue here and all is well.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 01:56 PM #4
Kmbeg Kmbeg is offline
Kmbeg is on a distinguished road
Thank you all for the lead on the subject.
I used back cap of a used pen pointer, an 'o' ring that did the job perfectly. Just used a cutter to shorten the length of the back cap so that it does not hinder directional vent louvers and drill it to desired size. Very easy. Fits perfectly. I put the o-ring on the other side of the main panel. It took me half an hour once i figured it out the materials to use.
Anyone who has a similar issue, I would certainly recommend at least try this once. No need spending on getting a new vent.
Kmbeg is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 09:46 PM #5
runnersT4R runnersT4R is offline
runnersT4R is on a distinguished road
Very clever fix! I might use this idea on my '99 vents, thanks!
runnersT4R is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 04:52 PM #6
eugeneparker eugeneparker is offline
eugeneparker is on a distinguished road
Hey guys, I am shopping for a family camping vehicle, set up to be a mild "overlander" to traverse midwest trails, sand dunes, tow a pontoon boat, and haul my wife and kid to various outdoor events. It will not be a heavy duty rock crawler or multi continent expedition vehicle.
I am considering a 4Runner, Sequoia, and now GX470. I don't know a ton about the GX except it shares some drivetrain parts with the others. The Lexus is cheaper than 4Runners of similar year/mileage, and the on road manners of the Lexus appeal to me.
Can you guys share any insight on buying/owning a 2003-2004ish GX470 with 130k-160k miles on it? I expect to drive this vehicle 5k-10k miles per year and would like it to last another 10 years if possible. I do much of my own work, but I'm wondering if Lexus service costs would be much higher than a Toyota for work I can't do myself.
Thanks for your help.https://discord.software/ fetlife vshare
eugeneparker is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 01:00 AM #7
LoneStarr LoneStarr is offline
LoneStarr is on a distinguished road
Nice!
LoneStarr is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 12:50 PM #8
marc1tc marc1tc is offline
marc1tc is on a distinguished road
These Genuine Toyota parts that I purchased from advance auto parts work perfectly to fix my front center bets on my 1996 4runner, And the black to boot
Advance Auto Parts - Down for Maintenance
marc1tc is offline   Reply With QuoteReply With Quote
WTB: 99 cup holder and center consol heat vent 1985taylor1925 Want to Buy/Trade 1 04-17-2012 02:47 AM
anybody know what this vent is for??? Brymat93 3rd gen T4Rs 19 08-16-2011 09:13 PM
AC only out of 1 vent... camit34 Problems & Warranty Issues 2 04-20-2011 02:13 AM
need to vent!!!!!!!!!!!! TD21 3rd gen T4Rs 9 08-15-2006 12:39 AM
