Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 06-17-2017, 04:59 PM #31
barakuder barakuder is offline
barakuder is on a distinguished road
Quick Question: What if I did press the brake pedal while the caliper was off? How can I get the piston back into the bore? I've put all my torque strength into a C-clamp and it's not going in.
Appreciate any tips.
barakuder is offline   Reply With QuoteReply With Quote
Old 05-14-2018, 02:17 PM #32
CoastDog CoastDog is offline
CoastDog is on a distinguished road
Talking Knowlegable and well researched
Thanks for the great write up with pics. Im new to 4Runner group. Love the gen4 4Runner i just bought, but of course had a brake issue right away.
No sweat, I researched here and ordered the correct parts to install. Very knowledgeable well researched posts are much appreciated.
I opted for the reman calipers this time around. I have rebuilt '80s 911 brake calipers, just as illustrated here. Messy with brake fluid, but very straight forward. Pistons can be grief to extract! lol.
Thanks again for write up.
CoastDog is offline   Reply With QuoteReply With Quote
Old 05-19-2018, 07:52 PM #33
2UZ-FE 2UZ-FE is offline
2UZ-FE is on a distinguished road
Both the fronts seized on my 03 for the first time last winter when I was doing the brakes. Didn’t know it was a common problem so I didn’t have a clue what was wrong when the pistons didn’t retract enough to get the new pads in. I thought the new pads were too thick or something. Owned lots of Japanese vehicles with 20+ years on the original calipers and none of them have ever seized.
Got a pair of reman Napa ones, I read on some other threads here that they are lifetime warranty and guys have had them exchanged when they seize up again. If the 4runner was my only vehicle I would have no problem exercising the pistons every year but having to take care of all the vehicles in the family, it isn’t something i’m too keen about.
2UZ-FE is offline   Reply With QuoteReply With Quote
Old 02-16-2019, 06:21 AM #34
Benny123's Avatar
Benny123 Benny123 is offline
Benny123 is on a distinguished road
Benny123's Avatar
Nice thread guys. Are you able to remove the piston with vice grips, before it seizes? Planning on rebuilding the rear calipers before it happens.
Benny123 is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 08:03 AM #35
ilovesingletrac ilovesingletrac is offline
ilovesingletrac is on a distinguished road
Same / similar for the rears?
I have dragging rear calipers and I'm wondering if anyone has done this process for the rears with any success??
Any part no's for the rear piston and seal kit??
Thanks in advance
ilovesingletrac is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 10:11 AM #36
2cast 2cast is offline
2cast is on a distinguished road
2015 4runner same problem
Thanks for posting. Very helpful post and pictures.
Seems front lower inside caliper piston boot has a build up of dirt, snow, salt and any other crap causing mine piston to be froze. As with most vehicles I have own the driver side always catches the extra winter mixture produced by the oncoming vehicles. I am looking at the Power Stop S6278 caliper replacements for both front brakes. 98,000 miles and towing a boat, it seems to be a good time for this.
2cast is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 06:26 PM #37
DrRobot DrRobot is offline
DrRobot is on a distinguished road
Brilliant idea. I wonder if this has eliminated the stuck piston problem for the OP, it has been several years since.
DrRobot is offline   Reply With QuoteReply With Quote
Old 11-22-2019, 04:01 PM #38
SeanWN86 SeanWN86 is offline
SeanWN86 is on a distinguished road
Originally Posted by Kmvreter View Post
No, you would not need to replace the boots and springs as a maintenance item (I did because I bought the kit basically for the new piston seals.)
Yes, just used the Permatex lube.
Let us know how you make out.
@Kmveter how have the calipers held up with your maintenance plan?
SeanWN86 is offline   Reply With QuoteReply With Quote
Old 11-28-2019, 10:14 AM #39
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
I use silicone brake lube . compatible with brake caliper rubber components, I never had any issues with my GM/Toyota brakes. I keep them over 10 yrs. my 1996 chev sedan no brake issues. had to replace the rotors ... still have the OEM factory calipers on that 96 sedan .
do not use any petroleum based lube on the rubber seals pins etc...causes the rubber parts to swell and break down.
just rotated my 2016 4 runner tires . 26K miles pads all look perfect..
I put that silicone based brake lube on my runner when I purchased it .
rotors look like a mirror .. 10% wear on pads.
catrains is offline   Reply With QuoteReply With Quote
Seized Piston in Front Brake Caliper docfeelgood 4th Gen T4Rs 11 10-15-2022 10:16 PM
Brake Caliper Stuck? Kanger328 3rd gen T4Rs 4 10-07-2013 05:33 AM
Brake Caliper: Rebuild or Replace Jeremy03Sport 4th Gen T4Rs 16 09-21-2013 11:18 PM
front brake caliper piston seized...again! t4rmax 4th Gen T4Rs 10 06-27-2012 11:57 AM
one brake piston is stuck out 2WICE Maintenance/Detailing 3 06-05-2005 06:07 PM
