Old 08-21-2014, 12:07 PM #1
alphaglitch alphaglitch is offline
alphaglitch is on a distinguished road
Tire rotation, 4-wheel drive light came on
Hi there, first post. I have a 2008 Toyota 4Runner 4x4 SportsEdition.
I just rotated my tires (moved front to rear - same sides). After I rotated them the green 4-wheel drive indicator light came on in the dash and won't turn off.
Any idea why? This is my first time doing this myself.
alphaglitch is offline   Reply With QuoteReply With Quote
Old 08-21-2014, 04:13 PM #2
JB.'s Avatar
JB. JB. is offline
JB. will become famous soon enough
JB. JB. is offline
JB.'s Avatar
If it's just the 4wd light (which I'm not fully familiar with since I have full-time 4wd) it sounds unrelated to the rotation. You probably just hit a button accidentally.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
JB. is offline   Reply With QuoteReply With Quote
Old 08-21-2014, 04:52 PM #3
Not likely. My 4wd is a big knob I have to spin to engage it. And I didn't touch it.
Enlighten me on this "full time 4wd". You have this on a 4runner? Is it just an automatic switch or is it 4wd engaged all the time?
Old 08-21-2014, 06:22 PM #4
JB.'s Avatar
JB. JB. is offline
JB. JB. is offline
JB.'s Avatar
I assume it's not related to the rotation because only the 4wd light is lit up.
V8 4x4s have no 2wd option due to having no auto disconnect front diff. 4 modes instead of 5. Transfer cases are virtually identical to each other.
Pre-Purchase Info, Modifications, Write-Ups, Quick Links, and FAQ's
2005 Limited V8
5th gen SR5 springs
Hanna sliders
Old 08-23-2014, 04:23 AM #5
Greydog's Avatar
Greydog Greydog is offline
Greydog is on a distinguished road
Greydog's Avatar
That is strange coincidence. Try cycling the 4WD selector knob into 4H and then back again, see if it goes off.
Check the wiring connections to the transfer case and also the front diff, make sure everything is clean.
Also check the very top side of the center diff unit, there is a small breather line that can crack and/or pop off, and may let water/moisture in. This has caused corrosion in the past for others and sometimes causes the system to act on its own, lights go on, etc.
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
Greydog is offline   Reply With QuoteReply With Quote
Old 08-24-2014, 12:50 PM #6
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
There should be no relation of 4WD system to Tire Rotation procedure. Can't see any solution.
<<<< is offline   Reply With QuoteReply With Quote
2002 4Runner 4 wheel drive light blinking vinman33 3rd gen T4Rs 2 06-18-2014 10:10 PM
green 4 wheel drive light doesn't come on, 4 wheel drive doesn't engage 4Runnerswa 3rd gen T4Rs 7 02-10-2014 01:51 PM
4 Wheel Drive light keeps flashing bluebaron 5th gen T4Rs 11 01-19-2013 03:27 PM
Type B 4 Wheel Drive Indicator Light mpark525 3rd gen T4Rs 6 09-04-2012 12:59 PM
newbie's question: spare wheel as regular without rotation, screw at edge of tire chee 4th Gen T4Rs 11 05-15-2011 10:52 PM
