Originally Posted by batmobile
I have a '87 t4r. It originally had the 6 cylinder and now has the 22-r swapped in. I want to replace the fuel filter and air filter but I'm unsure if I need parts for the original engine or the current one. I would assume the fuel filter would need the original and the air filter needs the one for the current. I'd rather have the correct parts the first time than have to fool with returning a wrong part.
does it have the 22re airbox? im assuming so, but have never even seen a 3.0 to 22r conversion in person. I know it happens, just never seen it, not sure what all is swapped.
you need the filter for whichever air box its using, regardless of the engine.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
