Originally Posted by tylrdvs277
I am lifted too. Maybe that plus some full-lock turns cause some leaking?
Yes, that's definitely a possibility. That lift would increase the axle angle unless you have a different drop. If not get one it's just a couple sleeves and bolts and will relieve the extra stress on them. Has the possible excess grease stopped squeezing out yet? You say leaking, I'm imagining squeeze out from over packing. If it's done squeezing out tighten the clamps up good. You should be good to go. Nothing is torn so you should be fine
