Old 12-15-2014, 05:52 PM #1
rubleblake rubleblake is offline
rubleblake is on a distinguished road
2nd gen parking brake.
How do you adjust the parking brake on a 2nd gen 4runner? I've heard out pulling the lever in and out. Is there an adjustment underneath the vehicle?
rubleblake is offline   Reply With QuoteReply With Quote
Old 12-15-2014, 05:54 PM #2
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
that should be drum brakes. before making any adjustments to the park brake cable, make sure the rear brakes aren't worn out, and properly adjusted.
what problem are you having?
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 12-15-2014, 07:05 PM #3
I just put new shoes on it and had the drums turned. Then I adjusted the shoes out so that the drums barely fit on. I went to test drive it and the pedal goes to the floor and there is no braking at all. When the vehicle is off the brakes work great but the second I turn the engine on I can push the pedal all the way to the floor with little resistance.
BTW I have bled the brakes but any other ideas would be greatly appreciated!!
Old 12-15-2014, 07:28 PM #4
nevada's Avatar
nevada's Avatar
pull the drums, and double check everything. sounds like something may have come loose.
brake , brakes , parking brake , parking brake issues
Parking Brake...do you use it?? Thai Polls 33 01-01-2022 02:30 PM
Is driving 07 T4R with the parking brake shoes on, only hurting the parking brake’s jow 4th Gen T4Rs 2 05-15-2013 02:31 PM
Parking Brake mpleitez Classic T4Rs 8 01-08-2012 01:40 AM
Parking Brake AdoboRunner 4th Gen T4Rs 13 10-14-2011 11:05 PM
Driving while parking-brake is on brake zak4runner Maintenance/Detailing 9 04-07-2007 08:24 AM
