12-28-2003, 02:40 AM
No master keys - What do i do?
I bought my 99 4 runner from a used dealer. It only came with the sub-key, no masters, no key chain transmitters. My vehicle has the transponder built into the key. I got the key code from the dealer. Where (besides the high priced dealer) can I get the key programmed? Or, what do I need to do to get master keys?
Thanks!
1999 Toyota 4 Runner LTD
01-29-2004, 10:49 AM
I don't know of any other place to get your key programmed. The dealer should be able to cut a master key from the VIN.
02-16-2004, 08:13 PM
To Program An Additional Key:
1) Place an already programmed Master key (one that works all locks) in the ignition, but DO NOT turn on.
2) Press the GAS pedal five (5) times.
3) Press the BRAKE pedal six (6) times.
4) Remove the key from the ignition.
5) Insert the new key, but DO NOT turn it on.
6) Press the GAS pedal one (1) time only and wait about a minute for the security light to quit flashing.
7) Remove the key and Press the BRAKE pedal one (1) time only.
8) Wait at least ten (10) seconds, then re-insert the new key and start the car.
You can have a maximum of ten (10) transponder keys programmed into your car
02-17-2004, 12:00 AM
Super Moderator
Super Moderator
Uh, he said he doesn't have a master key. That's the problem. :duh:
2003 SR5 V6 4WD Titanium with cladding
02-17-2004, 12:37 PM
Oops...
02-17-2004, 01:54 PM
Go to a Toyota dealership and empty your wallet.
Now available a forum for those that have a passion for body weight training http://www.bodyweighttraining.org/
02-17-2004, 02:50 PM
Real Name: JR
Real Name: JR
i take it the 4runners prior to 03 dont have the same engine immobilizer system as the 03-04 does, since he was able to drive it off the used dealer lot.
i know on the 03-04 4runners, if you lose all your chipped keys, you have to replace the whole engine immobilizer system, since the only way to program a new chipped key is to have an original chipped key to program from.
the dealer was very strict on making sure i knew this when i got my new 04 runner.
80 PhoenixLJ/84 CelicaGT/84 & 87 Cressida/89 Toy Truck 2wd/91 Cressida x 2/93 Paseo/96 Protege/98 4Rv6/04 4R Sport v8/06 Taco AC v6/07 Sonata SE v6/09 Rav4 v6/10 Legacy 3.6R/12 Taco DC v6/09 Avenger SXT/09 Corolla XLE/14 4R LE/14 Rav4 XLE/15 Camry XSE/16 Taco DC v6 Sport/16 Highlander XLE/18 Tundra Plat/18 Santa Fe Ult
2014 4R LE Classic Silver Build Thread
E5-Exhaust Tip / MF-Mudflaps / R6-Running Boards / 2Q-All Weather Mats / 3P-Paint Protection Film
02-17-2004, 04:04 PM
Since we're talking about keys
I just bought my 1999 LTD and I only got one remote and one key. I want to make an extra key incase I get locked out....
Questions:
1. How do I find out if my key has a transponder?
2. How do I make a copy of the orginal key with the transponder?
3. How do I know if the key I have is a master key ?
4. what happens if I use a regular (all metal) key that I made in a local hardware store?
Thanks,
Hany
1999 4Runner LTD
bought on 02/16/04
02-17-2004, 04:23 PM
If you need the chip for your key, the metal key will NOT start your car. Try it.
02-17-2004, 05:27 PM
Thanks but
and how do I know that the key I have is a master key or not.
thanks again
1999 4Runner LTD
bought on 02/16/04
02-17-2004, 05:47 PM
Real Name: JR
Real Name: JR
usually :
a. master keys will unlock all locks including glove box
b. valet keys will start the vehicle but will not unlock the glove box
c. sub keys will only unlock the doors
transponder keys have a black covering over them usually and be slightly bigger than the old style master keys (pre transponder keys)
on the new 03-04 keys, you have 2 master chipped keys (black fob), and a valet chipped key (grey fob). i had a sub key made to just un/lock the doors so i can run the truck during the sub zero winters and leave the master chipped key in the ignition.
my wife has the other master chipped key (black fob) and i keep the valet chipped key (grey fob) in the safe, in case i lose a master key. since you need either the master/valet chipped key to program another chipped key.
as far as cutting a new key, they can usually look up the master key id and cut a new one, unless you have the master key id plate.
as far as programming a new chipped key, i am not sure how they work prior to the 03 models, since you are able to drive the vehicle off the lot w/o a chipped key. the 03 and newer versions, the engine will not stay running w/o a chipped key.
02-19-2004, 03:20 PM
http://www.locksmithcharley.com/transponder.html
Quote from their website
"You have no keys. We will have to come out to the car, make a working "mechanical" key and then transfer the cuts onto 2 transponder blanks. With mobile service, labor to originate the original mechanical key, 2 transponder keys at $30.00 per key and programming of the vehicle we charge $150.00 to complete this operation."
"The information presented below is what is being provided to the public by Toyota and ILCO
1998-2001 The Toyota Electronic Control Module does not have programming modes without a
pre-programmed key.
If there is no key available that is already programmed into the module, the module must be replaced.
CHARLEY'S INFORMATION
I have acquired the ability to reset the Toyota / Lexus ECM to its "virgin" state which will allow it
to accept new keys into the ECM. "
1999 4Runner LTD
bought on 02/16/04
02-19-2004, 04:41 PM
Keys
First, you should have made the used dealer you purchased this vehicle from get you the proper keys as part of the deal for nothing. Second, IMO the simplest solution is take what you got stuck now with to the dealer and let them help you in person. Learn a lesson and don't buy an improperly equipped used vehicle next time.
The used dealer screwed you over, shame on them. Another used dealer screws you over again, shame on you.
Good luck!
Please be sure to pound sand.
02-24-2004, 11:24 PM
Check out www.streetkeys.com for replacement keys
Black 2003 SR5 V6 4WD (Option Pkg C) ClearBra, painted pinstripes Mods: Rear glass limo tinted/ fronts 27%, Sunroof Deflector, Auto Dimming Mirror, VVT-i emblem, Homelink, Valor Tip -- Aftermarket: Weathertech Deflector, AVS Ventvisors & Tailshade tail light blackouts, Silver Star bulbs, 7.2" Widescreen TV/DVD, PNI Wayfinder Compass, K&N Air Filter (Part #33-2281), Husky Cargo Liner, Wood Trim Kit, Third Brake Light Flasher, Amber Whelen Slimlighter (aux. rear hazard warning) Rear foglamp housings modifed for aux. tail/brake/signals/hazard (See Rear Fog Mod Thread here : http://www.toyota-4runner.org/showth...threadid=1137)
08-26-2014, 01:14 PM
Valet key to program new master?
Originally Posted by NoDak
usually :
Okay, so I am a bit confused: I have only the valet key, not the black master. but i do have the key code tag. (see above, says a valet key or master can be used? I saw on another post you could only use a master to program a new master?)
Can i use this to program a new MASTER key? I am ready to order on one ebay/amazon but want to be sure.
Thanks much!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
