Old 05-17-2006, 09:58 PM #1
lopatoj lopatoj is offline
lopatoj is on a distinguished road
Question 2000 4Runner: Accessory Power outlet fuse??
Hi All
The accessory power outlets, two in the front, one in the rear stopped having power. The cigarette lighter still has power. I
lopatoj is offline   Reply With QuoteReply With Quote
Old 05-18-2006, 10:18 PM #2
GSGALLANT GSGALLANT is offline
GSGALLANT is on a distinguished road
There is an accessories fuse that powers some relays when you turn the key to "acc". I think the fuse is labelled "acc". That must not be blown in order for your power outlets to work. There is also the power outlet relay itself that must work in order for your power outlets to work. Finally, there is the power outlet fuse that must not be blown either.
It's too late for me to go out to the truck to check now, but I think those three are all in your engine compartment fuse box, which is located right next to your battery. Look on the diagram on the fuse box cover to find the right ones to test/replace.
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline   Reply With QuoteReply With Quote
Old 05-23-2006, 05:32 PM #3
Lopatoj,
Any update on this? Were you able to fix the problem?
Old 05-23-2006, 10:11 PM #4
Smile Thanks
Thanks
It was stupidly simple. On the rode, I only had a chance to look at the fuse panel under the dash. There was a fuse labeled so that I thought it was for the power outlet accessories.
it turns out the actual fuse is under the hood in the main fusebox. A 15A fuse and a relay. Replacing the fuse fixed the problem.
Thanks.
Jerry
Old 06-27-2018, 10:50 AM #5
Trail Taxi Trail Taxi is offline
Trail Taxi is on a distinguished road
Removing Power Outlet Relay
Bump for this old thread.
I'm also trying to figure out what is wrong with my power outlets (front and rear). The fuses are good and I wanted to check the power outlet relay -- located in the under hood fuse box.
Now the question -- how in the heck do you pull the relay out? I've really tugged on the relay with no luck, am I missing a release tab or something? Could it have arced the contacts and be stuck in the socket, what am I missing?
TIA, John
1998 4Runner 3.4 Auto
Trail Taxi is offline   Reply With QuoteReply With Quote
Old 07-09-2018, 08:08 PM #6
Never mind -- I ended up forcefully rocking the relay side to side to loosen it up (not front to back). The good news is that the relay is ok and confirmed that by swapping it with its twin relay that was in the same under hood fuse/relay box.
Regards, John
Old 02-20-2021, 11:33 PM #7
RoxToy00 RoxToy00 is offline
RoxToy00 is on a distinguished road
And FYI, note that the power outlets front and rear only work when the ignition is on, which can be damned inconvenient. If you pull the power outlet relay from the under-hood fuse panel, open it up, and put a piece of plastic under the spring-loaded contact to force it into constant contact (search it, many videos on the process), your front and rear outlets will work full time without the 4runner running, with a nod to Lunar Landing. Great for morning coffee at the camp site. Just be careful about draining the battery and leaving yourself stranded, lol.
RoxToy00 is offline   Reply With QuoteReply With Quote
115 volt AC Power Outlet BenSD Engines / Suspension / Wheels / Tires / Audio / Accessories 15 09-21-2023 01:59 AM
pre four runner yy4u 4th Gen T4Rs 12 03-31-2008 10:55 AM
F/S 2000 4Runner Limited White/Silver COLORADO BoulderZJ Classifieds - buy & sell (no commercial ads please) 0 03-27-2008 10:13 PM
4th Gen Toyota 4Runner Reviews Thai Comparisons & Reviews 49 12-10-2007 04:23 AM
Always "ON" Power Outlet 00328 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 03-30-2006 04:38 PM
