View Poll Results: Which Oil Filters have you used?
Toyota
283 |
50.00% |
Amsoil
32 |
5.65% |
K&N
47 |
8.30% |
Bosch
31 |
5.48% |
FRAM
91 |
16.08% |
Purolator
72 |
12.72% |
Pennzoil
8 |
1.41% |
AC/Delco
16 |
2.83% |
MaxLife
1 |
0.18% |
Other: Please specify
74 |
13.07% |
74 |
13.07% |
05-14-2008, 04:11 PM
#61
Super Moderator
Super Moderator
Originally posted by pickerdd
I'm getting ready to order a couple cases of the larger Toyota OEM V8 filter 90915-20004.
Have you folks had good experience with them? I saw a few folks mention them here in this thread.
Thanks,
No complaints. I have 'zero' noise on cold startup, the oil stays visually clear and good for an exceptionally long time. When you look inside them, study the assembly quality, touch the rubber on the check valve etc they're clearly a premium filter. I say get 'em
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
05-16-2008, 09:15 PM
#62
Thanks for the feedback! I'll order a case or two on monday.
David
2008 4Runner V8 4WD Limited,
Galactic Gray/Stone Interior
Delivered 5/5/2008
07-01-2008, 01:35 AM
#63
Oil Filters
I used Fram for many years and have switched to Wix for all of my vehicles. I've been happy with them.
07-02-2008, 01:26 AM
#64
I use the Toyota Filters. I usually buy a bunch at a time. The engine is warranted to 100,000 miles so I know it won't be my problem if the OEM filter isn't any good.
People overthink stuff like oil and filters.
I am sure the engineers at Toyota are more than competent enough to make an effective oil filter that lasts 5000 miles. I am not sure about a company that needs a pyramid scheme to sell their products.
09-14-2008, 08:33 PM
#65
Banned
Banned
Toyota filters for me. Can't go wrong with those.
10-07-2008, 09:07 PM
#66
ive used K&N filters in everythig i can get them for...except my ram that uses Mopar filters. i am oing to use Royal Purple and a K&N for the first time. i have had the oil changed at a local shop that uses Pennzoil oil and filters. I wish they made K&N's for my mower
'07 4.0L V6 4Runner 4WD SR5 W/Factory 3rd Row, NGK V-Power Plugs, Pennzoil Platinum, NAPA 1515 filter, Goodyear Fortera TripleTread 265/65/17
1999 Dodge Ram 1500 318 4x4 Quad Cab HS 1.7 roller rockers Homeade Plenum plate "PurplDodge"
10-11-2008, 03:26 PM
#67
I run a Purolator Pure One with Castrol Syntec every 5K.
350Z--->T4R--->370Z--->T4R--->TDI--->T4R
2006 Titanium Silver V6 SE 4x4-Sold
2007 Titanium Silver V8 SE 4x4-Wrecked
2008 Galactic Grey V8 SE 4x4-Current
11-09-2008, 08:00 PM
#68
Amsoil Ea057 here and fluids. Change every 20 - 25k. With regular testing
www.lubedealer.com/dbcox
ZO#1568374
FREE catalog:https://www.amsoil.com/AmsoilLogin/Leads.aspx?type=catalog
1997 4runner 212k and counting
1974 baja bug to much to list
1999 Z71 Garage kept
11-24-2008, 11:18 AM
#69
Wix filters here. Use on all our equipment on the golf course as well.
02-15-2009, 01:09 PM
#70
...just adding a link...
Oils Against Oils
http://www.performanceoilnews.com/oi...nst_oils.shtml
via DavidAlexander
. -Kenny- (formerly icantsee) .
• **SOLD** 2007 Toyota 4Runner V6 SR5 4WD - Titanium Metallic
Daystar Spacer Lift 2.5/1.5 (Preload/Topout)|P265/70R17 Bridgestone Dueler A/T Revos|XenonDepot H11 4300k Xtreme HID Kit|Weathertech Floor & Cargo Liners|Rear Axle Diff Breather Extension|Color Matching Grill|Debadged Emblems|FatCat6|Soon/Wishlist|CB Radio|BL 1"|Demello Bolt On Sliders|Icons or Radflo|BajaRack or Rola Rack
05-04-2009, 05:32 PM
#71
Did 1st oil change yesterday at 6 months 4000 mi.Used fram 3614 filter. Decided to read this thread and went and picked up the toyota filter today after reading about the fram filters.Used fram filters with all my other cars with no problems but for 3.00 more now I feel a lot better.Plus dealer is 2 minutes away .
08 sport edition titanium metalic... color matched grill...color match sr5 running board... roof rack deleted...Kenwood deck...alpine seperates front....kenwood 2way .... rims inner spokes painted gunmetal gray... more to come
05-04-2009, 11:53 PM
#72
Went to change fram filter with toyota filter and...had hard time taking it off.Had lubed oring and put on hand tight .Tried filter wrench put only slipped.Used large water pump plier and finally strarted to loosen.But when took it off treaded nipple came off with filter.Tried taking nipple off and it was seized in oil filter.Only thing I can think of why it happened is maybe while taking off with pliers maybe filter sort of cocked and stripped filter tread.Im a mechanic by trade and never had that ever happened.Be it bad luck or I totaly scewed up, ordered nipple from dealer .Need to rent a car for a couple of days now.
05-05-2009, 08:21 AM
#73
Super Moderator
Super Moderator
That sucks!:awais: V6 or V8?
Chris
05-05-2009, 11:41 PM
#74
V-6
06-14-2009, 03:37 AM
#75
Real Name: Brian
Real Name: Brian
Amsoil EAO57 filter. Only filter that will last as long as there oil.
