View Poll Results: Which Oil Filters have you used?
Toyota
283 |
50.00% |
Amsoil
32 |
5.65% |
K&N
47 |
8.30% |
Bosch
31 |
5.48% |
FRAM
91 |
16.08% |
Purolator
72 |
12.72% |
Pennzoil
8 |
1.41% |
AC/Delco
16 |
2.83% |
MaxLife
1 |
0.18% |
Other: Please specify
74 |
13.07% |
74 |
13.07% |
11-19-2009, 10:35 AM
#91
i use mobil 1 m1-209 its longer than stock, and it works well on my 4.0, that filter i use , they use it on audi and vw and fords and other brands.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
11-09-2010, 04:52 PM
#92
Has anyone purchased the Toyota 90915-20004 OEM oil filter recently. I called a couple of places today where I used to be able to buy them and they no longer have any in stock.
Thanks,
David
2008 4Runner V8 4WD Limited,
Galactic Gray/Stone Interior
Delivered 5/5/2008
11-09-2010, 04:55 PM
#93
Banned
Banned
Google cruiserdan American Toyota.
He can get them for you.
You should be linked to ih8mud from your google search.
11-09-2010, 06:12 PM
#94
Super Moderator
Super Moderator
Thanks,
Yep... From my notes: "Original Equipment Filter 90915-20004 Dan @ American Toyota 800-432-6668 for filters"
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
11-10-2010, 09:44 AM
#95
Thanks for the info. I bought a couple cases of the filters from Dan 2 years ago, but wasn't sure if they are still available. I'll give him a call today.
David
Delivered 5/5/2008
02-27-2011, 11:34 PM
#96
Toyota World has a special on their oil filters this month:
Champion ToyotaWorld
03-01-2011, 12:00 AM
#97
Any of these
I use any of the following with synthetic oil for 7 months/7,500 miles if I run under severe conditions, if not 15,000 miles/1 year:
-Fram Extended Guard
-Bosch Distance Plus
-Mobil 1 EP
-K&N
The Fram Extended Guard is so well built that it has 2 ply synthetic media that is reinforced with a wire-mesh backing aside from the metal center tube.
04-26-2011, 09:41 PM
#98
As of today, Apr 26 2011 this info is still legit, just ordered 2 x 10 filters at around $9 ea. + shipping. Dan said he had over 400 in stock.
2009 4runner Trail V6, Icon 2.5 Ext travel front CO, Icon 2.0 remote resi rear shock w/ Icon springs, TC UCA, Custom Sway-bar End Links, 1.25" 4crawler BL w/ radiator drop, Cooper Disco AT3 285/70r17, ProComp 7098's, KurtFab diff bracket, Hayden tranny cooler, side-routed exhaust mod, Shrockworks Sliders, Full RCI Metal Works skid plates, Dual-Batteries, Kenwood TS-480HX HF radio, Kenwood TM-D710 VHF/UHF/APRS radio, Husky floor mats.
KJ6QDJ
05-11-2011, 10:05 PM
#99
I run those original OEM Japanese filters too...picked up a few recently.
2005 V8 4Runner 4X4 SR5, FJ TRD Bilstein Suspension, KO2s
2020 Mercedes GLE450
2014 Wrangler Rubicon, Synergy suspension + 35 MTRs + way too many mods
05-23-2011, 03:42 PM
#100
I'm curious how the Toyota OEM 90915-YZZD3 and OEM 90915-20004 oil filters compare because they are the same physical size container. I was told that the YZZD3 filter is the updated version of the 20004 filter, but would like confirmation from someone who has actually opened up both filters. The web site that has been linked to in this thread several times compares the 20004 filter to a 08922-02011 filter, not the YZZD3 filter.
http://www.mkiv.com/techarticles/parts/toyota_filter/
I'm curious as to the benefit of using the 20004 filter verses the YZZD3 filter. Has anyone cracked open the replacement filter (YZZD3) and compared it to the 20004 filter?
Thanks!
David
Delivered 5/5/2008
05-23-2011, 07:40 PM
#101
I use K&N filters, with Castrol Synthetic Oil.
I have a buddy who works at FRAM, you'd be surprised at who all they make filters for.
05-23-2011, 09:55 PM
#102
$9 a filter? wats dif about them than the filter u get a the stealer?
2003 4Runner SR5 V8 AWD + Daystar 2.5/1.5 + FJ Swap + Definity Dakota 285/75r16 MT's
2014 Taco 6spd TRD OR billies/dakar HD pack/33's
01-22-2020, 05:57 PM
#103
Hello
Im new here
I kinda confuse the toyota oil filter the correct number
I purchased 2007 4runner sr5 V6 3 days ago.
I got whole case of YZZD1 oil filters at home
I wondering which one I should use YZZD1 or YZZD3
01-29-2020, 09:39 PM
#104
I use FRAM and have no complaints about it. Purolator has good quality also.
01-29-2020, 10:12 PM
#105
Originally Posted by JH48runner
Hello
Im new here
Use the D3 filters, that’s what I use on my 08 V6.
