Old 01-12-2004, 09:42 AM #1
pag04 pag04 is offline
pag04 is on a distinguished road
Rustproofing/Undercoating
I posted an earlier note asking how to protect a new vehicle from rust in the Northeast. I received some replies mentioning rustproofing and undercoating. I've always heard that undercoating is a scam. Has that thinking changed? Googling for undercoating yields two completely different opinions - it's an absolute must if you want a vehicle to last..... and absolutely do not do it, it will make rust worse!
What opinions do people here have? Have you rustproofed/udnercoated your vehicle? Are you satisfied? Would you do it again? What type of shop is the best to apply it?
pag04
pag04 is offline   Reply With QuoteReply With Quote
Old 06-02-2012, 09:08 PM #2
redbull9944's Avatar
redbull9944 redbull9944 is offline
redbull9944 is on a distinguished road
bump
redbull9944 is offline   Reply With QuoteReply With Quote
Old 06-04-2012, 08:09 AM #3
ironhippy ironhippy is offline
ironhippy is on a distinguished road
You are talking about a brand new vehicle that has not seen a salty winter before?
If so, then rustproofing/undercoating will help. The amount it will help will mostly depend on the quality of rustproofing and ability of the person installing the rustproofing.
The reason why people will say it will make it worse, is if you take a vehicle that has been rusting for 10 years, and then cover all the rust with a solid undercoating, the existing rust will grow under the undercoating and eventually you will be left with nothing but the undercoating. If you scrape all the rust off of a 10 year old vehicle, repaint the bare steal and then undercoat, it will help keep new rust from forming.
This gentleman has been fixing rust on his truck Nelsonmd's Build Thread
2005 Limited 4wd, 85,000 miles
2002 Tacoma SR5 4wd, 5 spd 123,000 miles
sold 1997 Lexus LX450 - triple locked from the factory 305,000 kms sold
sold 1998 SR5 4wd - 4cyl, 5 spd 205,000 kms sold
sold 2000 SR5, 4wd - V6, auto 190,000 kms sold
ironhippy is offline   Reply With QuoteReply With Quote
Old 06-04-2012, 09:23 AM #4
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Rust converter converts Fe2O3 (Ferrous Oxide or Rust) to primer like dark finish. I use that on big suspension parts where I can't get to with brush wheel.
I found this online:
"How a Rust Converter Works in Theory
Rust converters are designed to neutralize existing rust as well as prevent it from advancing its damage. The active ingredient in most rust converters is Tannin, in the form of tannic acid. This tannic acid combines with the Iron Oxide to form a more stable compound called Iron Tannate, which is typically black in color compared to the reddish color of rust. Many commercial rust converters will include both a polymer to act as a protective layer, and an additional acidic compound designed to accelerate the chemical processes related to the tannic acids. One such acid, known as Phosphoric acid may also work as a rust converter itself, by reacting with the Iron oxide and converting it to black ferric phosphate. "
I hope this helps.
<<<< is offline   Reply With QuoteReply With Quote
Old 06-04-2012, 03:59 PM #5
pattycakes's Avatar
pattycakes pattycakes is offline
pattycakes is on a distinguished road
pattycakes's Avatar
I gave up fighting it long ago , its a loseing battle , and I tryed everything. Those who don't have to deal with it will never have the privlige of the smell of the sweet salt air on summer mornings nor the pleasure of driving a new vehicle every 5-6 years . sucks to be them
2011 CDN SR-5 upgrade package
1982 BJ42 RHD Diesel
2002 Dodge Cummins 24v
1998 Dodge Cummins 12v
IBEW 424 build it union !!!!!!!!!!!!!!
pattycakes is offline   Reply With QuoteReply With Quote
Old 06-10-2012, 01:27 PM #6
zerowkul98's Avatar
zerowkul98 zerowkul98 is offline
zerowkul98 is on a distinguished road
zerowkul98's Avatar
Last fall i went under my 03 and 08 4Runners with POR15's products (marine clean, metal ready, and black under-coating). This stuff hold up REALLY WELL! You just have to be careful with it on a few things...mainly YOURSELF! You gotta wear gloves throughout the whole thing (the marine clean and metal ready will make yer skin feel like it's encased in a plastic-glaze if youre not careful, and the actual POR15 black stuff NEVER comes out of clothes, and takes quite a while to come out of skin!)
I did the OEM skidplates first. The 03's was in tough shape. No holes, but being in Massachusetts with the winters and icey roads we get, salt is used in abundance. Here's how the 03 came out after 2 coats of the stuff:
You dont have to sand or grind to shiney, bare, new metal either. You just have to get the loose stuff off. It even states you SHOULDNT get down to new metal as it "grabs" and "holds" onto better.
I plan on doing the entire undercarriage this summer.
2003 Sport Edition V8 (sold)
2008 Sport Edition V8 (sold)
2016 Trail - Classic Silver Metallic - 17" Black TRD Wheels w/ BFG All-Terrains
zerowkul98 is offline   Reply With QuoteReply With Quote
Old 06-15-2012, 11:19 AM #7
<<<<'s Avatar
<<<<'s Avatar
I had good luck with POR15 for a while, but after few years rust came back lifting POR like a skin off the snake. The fix: no more expansive POR15, instead I do steel wire sanding of rusted spots followed by Rust Convertor and finally Bed Liner for middle and gas tank skid plates as well flat bottom surfaces of the frame and control arms. Bed Liner keeps steel protected from rock chips and salt from eating trough. Front skid plate I keep semi-gloss black for stock look and ease of cleaning.
Just my $ 0.02
Old 06-17-2012, 02:17 PM #8
trailrazer's Avatar
trailrazer trailrazer is offline
Real Name: Eric
trailrazer is on a distinguished road
trailrazer's Avatar
Real Name: Eric
This is a great thread. I live in the Northwest where we don't salt the roads. My 4Runner was previously owned in New York. I couldn't believe how bad it was under.
I went the route of taking it almost down to bare metal. I used my 4 1/2" angle grinder with a knotted wire wheel. It took quite some time getting the front and rear cleaned up. I pulled both bumpers, skid plates and the spare tire. I had considered POR-15 but ended up not doing that. Instead I used rattle cans of primer for two coats and two coats of semi-gloss. Mostly due to the fact that I cleaned down to bare metal.
Since I'm installing FJ coils, spacers and 5100's tomorrow, I'll get the other areas that I couldn't reach. You can check out my "Trailrazer build" thread in the 4th Gen section to see the before and after pictures. It was pretty bad.
As for smelling the salt air and such... I'm glad I won't have to clean up after a salty winter again. If I lived in the Northeast I'd probably be doing this clean up every couple years or doing an undercoating that was rust preventative. Luckily most of the rust was down low. The sides and bottom of the frame had no soft spots. I went through some PB Blaster to get screws out without twisting the heads off.
I'd also recommend regularly lowering your spare tire and keeping the cable system lubricated. It was almost impossible to get the spare tire out. There was a lot of corrosion and rust jamming it up.
2003 4Runner SR5 4WD V6... Sold
2008 4Runner SR5 4WD V6- 5100's FJ Coils DS Spacers - 265/70-17 Cooper ATP's on Ultra Drifter's
http://www.toyota-4runner.org/4th-ge...d-v-2-0-a.html
trailrazer is offline   Reply With QuoteReply With Quote
Old 06-19-2012, 11:35 AM #9
jwyshrek jwyshrek is offline
Registered User
jwyshrek is on a distinguished road
Registered User
Didn't someone here use chainsaw oil???
I remember inquiring why chainsaw oil was used...it was because it 'sticks'.
jwyshrek is offline   Reply With QuoteReply With Quote
Old 06-19-2012, 01:03 PM #10
<<<<'s Avatar
<<<<'s Avatar
I don't think it'll stay on during winter trough snow, ice and road salt. Also I'd hate to see that end up in ground water.
Old 06-19-2012, 01:35 PM #11
Registered User
Registered User
True...but, here is the thread link...FYI.
She got a hot oil spray today!
Old 07-01-2012, 12:56 PM #12
jdkilroy's Avatar
jdkilroy jdkilroy is offline
Real Name: Jon
jdkilroy is on a distinguished road
jdkilroy's Avatar
Real Name: Jon
Living in New England rust is a given so I consider rust an ongoing maintenance issue.
I use a product called "Ospho" which has phosphoric acid in it. Remove the scale, leave the surface rust and brush it on. It has surfactants added so that it wicks into every nook and cranny. Turns the rust into black, inert iron phosphate (ferric phosphate). Its no cure for the problem, just a great maintenance tool.
Rust on frames and major metal components usually starts out at the welds due to the local alteration of the chemical/electrical properties of the metal. (put a sharp bend in a common steel nail and set it outside for a bit; notice where the rust gets started)
Marine outfitter called Jamestown Distributers sells Ospho in various sizes. Its not cheap but it goes a long ways.
Safe travels, Jon
2008 4R SR5 4.7 great tunes and a lot of work: Build Thread
2002 Taco SR5 3.4 4x4 manual; stock ... for now
jdkilroy is offline   Reply With QuoteReply With Quote
Old 01-21-2021, 09:40 PM #13
Farid Farid is offline
Farid is on a distinguished road
I have a bran new 4runner in NW.
Do i need to scuff the chassis with sand paper first and then apply the POR15 ?
What about Fluid film? do i need the same approach with FF?
is there any product that works for brand new cars and does not need scuffing ?
Thank you !
Farid is offline   Reply With QuoteReply With Quote
Old 01-21-2021, 09:47 PM #14
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
Thank you !
Good luck with either POR 15 or Fluid Film. Been down that road many years ago.
Both are "Forum Darlings" that are not good at all.
You will be reapplying FF at least once a year.
If you have that kind of time and diligence, go for FF.
New vehicle? No need to scuff frame.
Look into WoolWax if you are thinking of Fluid Film.
WaxOyl (2 parts) and Cosmoline are excellent.
Don't use black as if you try to resell, someone may think you are hiding rust.plus it makes things hard to identify. Clear/Amber is the way to go.
I did my 4R before I hit 250 miles and used Cosmoline this time.
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 02-07-2021, 05:09 PM #15
altruistic altruistic is offline
altruistic is on a distinguished road
I second the WoolWax or FluidFilm type of coatings. I'm planning on doing that DIY for my truck soon.
There's a few YouTube videos show that even after 5+ years in a salty northern climate, there's hardly any rust. Yes, it sucks to reapply twice a year, but it's really an investment on your vehicle.
altruistic is offline   Reply With QuoteReply With Quote
