Old 07-30-2006, 02:01 AM #1
216133 216133 is offline
216133 is an unknown quantity at this point
Twin ground electrode plugs vs. standard plugs
I know it is recommended, if not insisted, that when replacing the spark plugs for a Toyota 4runner that you buy the twin ground electrode spark plugs as replacements. This seems to beg the question of what damage a standard single ground electrode spark plug would inflict on the engine. I'm running a '97 v6 4runner with around 284,000 miles for the inquisitive types.
216133 is offline   Reply With QuoteReply With Quote
Old 08-01-2006, 12:06 AM #2
Toy-Man's Avatar
Toy-Man Toy-Man is offline
Toy-Man is on a distinguished road
Toy-Man's Avatar
I say, Don't waste your money. Stick with the Toyota recommended replacement plugs (NGK or DENSO).
-Toy-Man-
-Toy-Man-
'03 4Runner V6 Limited
Metallic Silver
Nav System
Borla Exhaust
4Runner Skid Plate
K&N AirCharger Intake Kit
Sylvania Silver Star Bulbs
TRD 18" Wheels (for the summer)
JVC KT-SR2000 Sirius Satellite PnP
with PAC AUX adapter
Nifty Catch-All Xtreme Mats (Winter)
Toy-Man is offline   Reply With QuoteReply With Quote
Old 08-01-2006, 08:26 AM #3
greasefingers's Avatar
greasefingers greasefingers is offline
greasefingers is on a distinguished road
It is only recommended by marketing people of aftermarket products. Once 20 to 40 k volts comes down the wires and plugs, what do think will happen? You get spark! No matter how many paths to ground are provided by the plug.
2003 4x4 Sport 4runner V8 with 287k miles and counting
2015 Lexus RC350 F-sport
greasefingers is offline   Reply With QuoteReply With Quote
Old 08-01-2006, 11:42 AM #4
rustyrazor's Avatar
rustyrazor rustyrazor is offline
rustyrazor is an unknown quantity at this point
rustyrazor's Avatar
I've heard that with the twin ground plugs like split fire they work good at first but after they start to wear in the electrical current will start to follow only one of the ground paths.
Once that happens it may as well be a single ground plug.
Ray
1992 SR5 3L-V6 auto
1990 SR5 4cyl manual - RIP
rustyrazor is offline   Reply With QuoteReply With Quote
Old 08-01-2006, 01:56 PM #5
Ah, that makes sense. Thanks you guys for your insight, you've put my anxieties to a rest.
Old 08-01-2006, 02:18 PM #6
Koz's Avatar
Koz Koz is offline
Koz is on a distinguished road
Koz Koz is offline
Koz's Avatar
Stay with OEM Densos or NGKs, I prefer the NGKs.
Koz
Koz is offline   Reply With QuoteReply With Quote
Old 08-01-2006, 11:00 PM #7
jeober's Avatar
jeober jeober is offline
jeober is on a distinguished road
jeober's Avatar
If the engine didn't achieve proper combustion on every power stroke, you'd see a MIL light from the required on-board diagnostics. If you don't then the plugs are doing the required job.
Clarke
'05 4x2
jeober is offline   Reply With QuoteReply With Quote
Old 09-06-2019, 09:19 AM #8
eatmorechickenx eatmorechickenx is offline
eatmorechickenx is on a distinguished road
You clearly dont know what you are talking about. Every one of these motors has a sticker on it from the factory that says use only twin ground electrode plugs. That is not aftermarket marketing. Dont spread info about somethinh you dont know. For the op, i have tested both, and the motor is noticeably more effecient with the twin grounds. Noticeable better mileage. I was curious once and bout a set of twin grounds and a couple other sets of different plugs to rule out just one set that didnt run well and rotated through them a couple times on a trip that i made almost every weekend. The recommended plugs were consistently 2+ miles to the gallon better. Plus they are cheap.
eatmorechickenx is offline   Reply With QuoteReply With Quote
Old 09-06-2019, 09:51 AM #9
4Reak Show's Avatar
4Reak Show's Avatar
For which engine are you referring? The 3.4 wants twin plugs because it has a waste spark type ignition system. Most who are supercharged run single electrode plugs because those are all that are available to achieve the "colder" rating. All that happens is the plugs wears out faster. Eventually damage could result if you ignored a misfire long enough but that's true for any engine.
If you're stock, get stock plugs.
Old 09-06-2019, 10:37 PM #10
metallitera metallitera is offline
Real Name: Red
metallitera will become famous soon enough
Real Name: Red
That pretty much sums it up!
-ReD
Firefighter/Licensed Paramedic
*SOLD* 2000 4Runner Limited 4x4
2020 Ford F-150 3.5L EB
Build Thread
metallitera is offline   Reply With QuoteReply With Quote
Spark Plugs axle167 3rd gen T4Rs 51 03-07-2019 04:45 PM
spark plugs reefer Maintenance/Detailing 0 08-20-2009 04:01 AM
