Old 04-15-2016, 08:24 PM #1
HNTMUP HNTMUP is offline
HNTMUP is an unknown quantity at this point
Getting adhesive off of body?
Decided to remove the plastic 4Runner and SR5 badges from the back of my truck. They came off easily but the thick adhesive did not. What's the best way to remove all traces of thr residual the?
Thanks,
JDG
HNTMUP is offline   Reply With QuoteReply With Quote
Old 04-15-2016, 08:31 PM #2
Lineman's Avatar
Lineman Lineman is offline
Lineman is on a distinguished road
Lineman's Avatar
Try using a hair dryer and soap and water first. If that doesn't work WD-40 it. Finally if that doesn't work a little gasoline on a rag will. Just make sure to wash and wax when done.
Black 2003 Sport, V8, 4WD, 115K miles - as of June
2016, AMSOIL lubed, JVC Headunit 925BT, Rockford Fosgate Amp, Rockford Fosgate 10'' P2's in custom box
Lineman is offline   Reply With QuoteReply With Quote
Old 04-15-2016, 08:33 PM #3
mizzouxc mizzouxc is offline
Banned
mizzouxc is an unknown quantity at this point
Banned
Thanks,
JDG
You can use something like automotive goo gone. I've used it in the past with good results. I caution to test in an area of paint that doesn't matter first though. Also, a very little bit soaking in goes a long way. I've had just a drop on a q-tip remove an entire bumper sticker. Just give it a second to work. (some *** wad put a Hillary sticker on my previous truck)
Goo Gone Automotive Products
mizzouxc is offline   Reply With QuoteReply With Quote
Old 04-15-2016, 08:34 PM #4
Banned
Banned
If you go this route, be very careful. Heat like that can hurt your finish. Gasoline will strip your clear coat right off. Just spend the $4 for the goo gone!
Old 04-15-2016, 08:55 PM #5
RedSled's Avatar
RedSled RedSled is offline
RedSled has a spectacular aura about RedSled has a spectacular aura about
RedSled's Avatar
W-D 40 works, and will not damage the finish.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
RedSled is offline   Reply With QuoteReply With Quote
Old 04-21-2016, 09:23 AM #6
Volnut Volnut is offline
Volnut is on a distinguished road
Hard to beat this.
http://www.amazon.com/AES-Industries...+stripe+eraser
2011 SR5
Volnut is offline   Reply With QuoteReply With Quote
Old 04-21-2016, 09:50 AM #7
I've been working on it with Goo Off and WD 40 and a plastic scraper. It still thick. This erase wheel may be the ticket when I get most of the heavy stiff off. Think some heat might speed up the process?
Old 04-21-2016, 10:01 AM #8
RedSled's Avatar
RedSled's Avatar
Yes, you need to get the thick stuff off, then use the WD 40 for the rest. I just kept at it with plastic scraper, take your time and just try to roll the thick stuff up without pushing against the paint to hard.
Vietnam 67-68
Old 04-21-2016, 11:32 AM #9
tigger tigger is offline
tigger is on a distinguished road
Some thin fish line will make the removal quicker. Be careful of the above advice if any of those badges were on chrome parts. The above chemicals are effective for painted body parts. Chrome coated plastic can very easily be damaged by any chemical.
Heat will make the adhesive come off easier. Heat up a section and use the plastic scraper. You can apply the adhesive remover to help break down the adhesive. WD-40 will not help at this point. Be careful of the adhesive as you are breaking it down. It will be really sticky and if you drop it, it will stick to anything it touches, other areas of the body, bumper, floor, shoes etc...
I would also advise against the eraser wheel. It is easy to damage the paint if you aren't used to using one. Shouldn't need that for a job this small. They are more for removing large graphics.
tigger is offline   Reply With QuoteReply With Quote
Old 04-25-2016, 08:18 PM #10
77Bronc 77Bronc is offline
Real Name: Richard
77Bronc is on a distinguished road
Real Name: Richard
I use WD40 for most of these issues.
77
77Bronc is offline   Reply With QuoteReply With Quote
Old 04-26-2016, 05:31 AM #11
truc.karl truc.karl is offline
truc.karl is on a distinguished road
3m adhesive remover is formulated for that kind of job. Wd40 works also but will remove wax/protection on the paint.
truc.karl is offline   Reply With QuoteReply With Quote
Old 05-28-2016, 02:55 PM #12
NauticalWheeler NauticalWheeler is offline
NauticalWheeler is on a distinguished road
I would take some tape and outline the area to protect the surrounding paint.
Then take a heat gun (low heat) or blow dryer (medium heat) and wave it over the sticker for about 15 seconds (keep them both moving).
Then take a pencil eraser and rub off the sticker. That's why the tape is there, to protect the surrounding paint from the abrasive eraser. Rub for 15 seconds, then more heat, then rub again.
If this doesn't do much good, then goo-gone would be the next step.
If the goo gone take off most of it, but not all of it, go back to the eraser.
Don't be tempted by using a razor blade, although for uncoated glass that would be useful.
NauticalWheeler is offline   Reply With QuoteReply With Quote
Old 07-07-2016, 09:12 PM #13
MylesStandish's Avatar
MylesStandish MylesStandish is offline
MylesStandish is on a distinguished road
Thanks,
JDG
Acry-Solv. This stuff is the best! Use gloves and flush immediately with water once you remove the adhesive. Cleans up very quick and will not hurt your paint. I use it all the time. Also great to get tar off the paint from roadwork. Good luck.
Getting adhesive off of body?-img_0598-jpg
Lay low and don't anger those who are still living in their parents basement for way to long.
2016 TEP w/KDSS- Precision LED interior package, license plate, reverse and headlights- TRD Black wheels. Ellis Precision shift and t-case knobs, Gobi stealth rack w/ladder
MylesStandish is offline   Reply With QuoteReply With Quote
Old 07-09-2016, 04:22 PM #14
Googled Acry-Solv and Amazon and couldn't find a retailer. Where can I find this stuff?
Thanks,
JDG
Old 07-10-2016, 07:26 PM #15
Crest Industries Inc - Specialty Solvents
Just used it on my wife's car to get an emblem off. Go lightly on it. A little dab will do ya.
Adhesive recommendation? OCMike General Discussions 3 06-17-2013 09:33 PM
Adhesive? smallfry Engines / Suspension / Wheels / Tires / Audio / Accessories 2 11-29-2012 08:41 AM
Help removing adhesive. wtn11 Maintenance/Detailing 8 10-08-2012 12:09 AM
Decal Adhesive SoAZ General Discussions 5 09-15-2012 03:07 AM
adhesive recomendations jlfindley74 Classic T4Rs 1 12-28-2008 02:09 PM
