Old 01-13-2012, 01:58 PM #1
Deputy1211 Deputy1211 is offline
Deputy1211 is on a distinguished road
Oil leak around seal of oil pan?? Pics
Changed my oil, filters and plugs today. Noticed when I took off the splash guard a small amount of oil collected (kinda gritty/gooey, not liquid) on the driver's side of the guard.
Then when I drained the oil (plug is good not leaking,filter seemed tight enough) and took the following pics, that there was oil residue around the drain pan where all those small nuts connect it to the engine. No leaks under the car and I couldn't see any dripping. As for performance Its a 3rd gen 2001 with 170,000 miles on it so some days its hard to tell if its sucking wind or just feeling its age. No other major problems with car or engine to date.
Wondering if this is a seal or gasket issue?
IS this something I could attempt to fix on my own?
If not how much time/labor, parts, and expense is inolved?
Worst case how long can I get away with it by keeping up the oil levels? Yeah i know that is not kosher but when you are broke what are you to do. Wouldn't be changing filters and plugs in 29 degree weather on my Friday off if I could afford not to.
Thanks for any info received.
Deputy1211 is offline   Reply With QuoteReply With Quote
Old 01-13-2012, 03:48 PM #2
cfranck1's Avatar
cfranck1 cfranck1 is offline
cfranck1 is on a distinguished road
cfranck1's Avatar
I think I would start by changing the oil filter or tightening it a little more. Looks like it's leaking a little.
Then spray the whole area with brake clean and wipe down. Then start driving it and keep a close eye on where its leaking from.
Might want to check all the oil pan bolts to see if they are loose.
01 SR5 - 187k+/- 285 BFG A/T KO2 - 99 talls & front Trekmasters / Rear KYB - Hella fogs - Taco Mod - Fixed gaping hole in frame {SOLD}
02 Taco - 197k +/- BFG A/T KO2 285s + rims from 4Runner - saving up for suspension - House gets priority over Taco (for now)
cfranck1 is offline   Reply With QuoteReply With Quote
Old 01-13-2012, 04:18 PM #3
Did that. But still think its from around that seal. Anyone with ideas or answers to my questions...
Old 01-13-2012, 04:53 PM #4
quicksilvr's Avatar
quicksilvr quicksilvr is offline
quicksilvr will become famous soon enough
quicksilvr's Avatar
Hate to be captain obvious, but your oil pan gasket is leaking. They do that. Only thing you can do now is make sure all the oil pan bolt are torqued properly.
Usually, it will never get bad enough to need to be replaced. It'll just weep a little and you'll live with it. If it does get bad enough that you are losing a lot of oil, it's kind of a pain. The front diff has to come out in order to drop the oil pan.
But I would be very surprised if it ever gets bad enough to need replacing. It'll just leak a tiny bit for the rest of it's life.
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
quicksilvr is offline   Reply With QuoteReply With Quote
Old 01-13-2012, 05:45 PM #5
THat does seem to be a plausible explanation. Thanks for the info. I'm thinking of putting some degreaser on that area and washing it off before tightening the bolts and then give it a good 1k miles to see what happens. For me that won't take long as I drive 50 miles each way for work about 14 times a month in addition to around town errands.
Old 01-30-2012, 03:25 PM #6
Theslammer21's Avatar
Theslammer21 Theslammer21 is offline
Theslammer21 is on a distinguished road
i still go with the oil filter. every time you do an oil change the oil drips down there. could just be residual from oil changes. you would be surprised what wind does to fluids under the car when youre driving
2011 SR5, grey, revtek 3", BFG AT KOs 285/70/17, 17x9 Fuel Hostage, toyota hood protector, AVS side window deflectors, toyota running boards, 8000K HIDs low beam and fog, rear view camera mod, 5% all rear, 15% front two, glare strip on windshield
Theslammer21 is offline   Reply With QuoteReply With Quote
Old 05-10-2016, 12:03 PM #7
jreynolds74 jreynolds74 is offline
Real Name: Jason
jreynolds74 is on a distinguished road
Real Name: Jason
UV Dye
I'm surprised nobody has mentioned UV die for the oil yet. I just dropped some in and purchased a cheap UV mag light on Amazon. Cheap test. going to run the engine for a little bit and see where the die is coming out.
I'm already in the process of fixing my front diff seals that are leaking and it does seem my oil pan is leaking as well. But before I take the diff completely out I want to know for sure where the oil is coming from.
If it is leaking from the oil pan, this is the perfect opportunity to fix both at the same time.
I can't wait!!!
jreynolds74 is offline   Reply With QuoteReply With Quote
Old 05-13-2016, 03:13 PM #8
RS Dude's Avatar
RS Dude RS Dude is offline
RS Dude is on a distinguished road
RS Dude's Avatar
De-grease entire area first before anything.
'96 T4R SR5 V6 Auto 2WD 336,000 miles
RS Dude is offline   Reply With QuoteReply With Quote
She's taking a leak! Rear axle seal leak that is.... fightman80 3rd gen T4Rs 76 09-18-2014 04:52 PM
Front CV seal leak help.. maxspeed96ct 3rd gen T4Rs 5 08-31-2011 12:21 PM
Axle Seal 'Leak?' madbomber08 3rd gen T4Rs 2 08-30-2011 02:49 PM
Seal leak in carwash 2000runr 3rd gen T4Rs 4 10-10-2009 03:46 PM
Rear Main Seal Leak tbs954runner Maintenance/Detailing 2 02-03-2005 10:09 PM
