Old 09-08-2006, 02:39 PM #1
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
Electronic Rust Protection
Has anyone every heard of or had experience with an "Electronic Rust Protection" system from CounterAct? Canadian Tire here has just started selling them. I noticed they are on sale (C$100.00 off initial promotion) until the end of today. Their website www.counteractrust.com has some decent info on the systems. Any comments or input?
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 09-08-2006, 08:25 PM #2
toto toto is offline
toto is on a distinguished road
That web site is filled with impressive-sounding words and hype about active rust/corrosion protection. But it hardly describes what the product is or how it works.
This paragraph about the product itself is a great example:
"A small, self-regulating , pulsed DC power supply-control module utilizing "smart technology" (in the case of a typical passenger vehicle system about the size of a pack of cigarettes) is the heart of our corrosion proofing systems. The power supply is all solid state circuitry embedded in electronics grade (UL 94V-0 flame retardant) epoxy encapsulant for long life and durability in any climate. The power supply/control unit utilizes internal self-diagnostics with a simple intuitive led indicator which provides warning of low battery voltage, ground faults or short circuits. This eliminates the need for specialized testing instruments or failure prone PC docking ports and static sensitive internal. componentry. On automobile and light trucks it is typically installed under the hood or in the trunk (wherever the battery is located)) where it runs off the 12V from the vehicle battery drawing less current than a typical digital clock."
I still have no idea what this product does, but I was especially impressed by the flame-retardant UL-listed epoxy encapsulant!
I certainly wouldn't buy something that's 90% hype and maybe 10% substance.
2006 Limited V8 4x4, Shadow Mica/Stone
toto is offline   Reply With QuoteReply With Quote
Old 09-08-2006, 11:34 PM #3
jharris2 jharris2 is offline
Super Moderator
jharris2 is on a distinguished road
Super Moderator
Sounds like one of those "too good to be true" things....I'd be very skeptical.
2003 SR5 V6 4WD Titanium with cladding
jharris2 is offline   Reply With QuoteReply With Quote
Old 09-09-2006, 12:45 AM #4
Mashimaru's Avatar
Mashimaru Mashimaru is offline
Mashimaru is an unknown quantity at this point
Mashimaru's Avatar
Back where i come from, which is the island of Guam our climate is quite rough on the cars since we are surounded by the ocean. Most cars i've seen sold on the dealerships, especially the toyota ones have these installed in the engine bay.
I could probably say myself that this wouldn't prevent rust, but rather just slow it down.
2004 Galactic Grey 4Runner Sport Edition
2006 Redline 350Z Coupe
Current Mods- | Sylvania Silverstar lights | White LED front side markers | DEH-9450Mp3 Pioneer HU | White LED Door step, Map Light, Dome Light bulbs | 6x9 front Type S Alpines | 6.5 Rear Type S Alpines | Alpine V-Power F240 4channel amp |
Plans - 2006 LED tail lights | Alpine Mono amp + 12inch Type R | Independant fog light mod | 4.3k Hid Retrofit (Possibly with Projectors)
" Nothing is ever perfect, so don't go ranting around every issue... think and fix it rather than opening your mouth."
Mashimaru is offline   Reply With QuoteReply With Quote
Old 09-09-2006, 06:06 PM #5
Kmvreter's Avatar
Kmvreter's Avatar
You're right. They don't claim to prevent, just protect and slow the process.
The site does like to hype but it also gives good info:
"1. A small, self-regulating , pulsed DC power supply-control module utilizing "smart technology" (in the case of a typical passenger vehicle system about the size of a pack of cigarettes) is the heart of our corrosion proofing systems...
2. A removable modular wiring harness with fused power lead (to permit easy access to the power supply/control module for inspection or for easy transferability of our corrosion control devices to another vehicle.)...
3. One or more of our unique "programmed capacitive couplers". These capacitive couplers, which are attached to the protected metal surface with aircraft grade adhesive, are charged by the power supply/control module and function as if they were the positive half of a capacitor. They are wired to the power supply in parallel (each on individual circuits) and meticulously engineered and controlled so that each serves to produce a measured and specific limited range of capacitance and thus deliver a measured and specific limited range electrostatic charge via capacitive coupling...
Together these three components serve to induce a measured and specific negative electrostatic surface charge on the metal surface being protected (your vehicle's body for instance) thus capacitive coupling treats the metal body as if it were the negative half of a capacitor. This negative surface charge serves to interfere with the normal electrochemical corrosion processes that create corrosion on metals..."
They also explain elsewhere the difference between their new approach versus traditional systems (which I've heard of before, ie. underground pipe systems.) They are basically covering the vehicle with an ongoing static charge.
I'll be the guinea pig. It can't hurt to try. The sale was ending yesterday so I sprang for one at the last minute. Now to find time for the easy install.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 09-10-2006, 03:10 AM #6
Jacobzky's Avatar
Jacobzky Jacobzky is offline
Jacobzky is on a distinguished road
Jacobzky's Avatar
boy im sure they make good and convincing job resume as well. they have some sweet candy words to sell thier product.
Jacobzky is offline   Reply With QuoteReply With Quote
Old 09-12-2006, 06:09 PM #7
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
It will Increase horsepower by 15% and might improve your gas milage by up to 10% it will also increase your penis size by 5% . LOL, do not waste your money on it it does not work, if it did automakers would install them during assembly.
<<<< is offline   Reply With QuoteReply With Quote
Old 09-12-2006, 09:32 PM #8
darkmark darkmark is offline
darkmark is an unknown quantity at this point
Rust
Cathodic protection makes the iron a cathode in a battery formed whenever water contacts the iron and also a sacrificial anode made from something with a more negative electrode potential, commonly zinc or magnesium. The electrode itself doesn't react in water, but only to provide electrons to prevent the iron rusting.
They install these on massive bridges too to prevent corrosion.
(!wired) ? (coffee++) : (wired);
darkmark is offline   Reply With QuoteReply With Quote
Old 09-12-2006, 10:26 PM #9
Light_Mania Light_Mania is offline
Light_Mania is on a distinguished road
The electronic underwater bridge support corrosion protection systems rely on a closed circuit between an anode, and the bridge support which is a cathode, with water functioning as the electrolyte or conductor. This is based on well known electrochemical properties and is not BS.
Unfortunately, there is no way to do this with an automobile. The corrosion cell on automobile bodies is extremely small and there is no practical way to apply a current to conteract it.
In short, those electronic corrosion protection devices for automobiles are in the same league as the magnetic fuel molecule aligners seen in the JC Whitney catalogue and (in days past) on late night TV infomercials.
The good news is that it probably won't hurt anything either.
Light_Mania is offline   Reply With QuoteReply With Quote
Old 09-27-2006, 10:18 PM #10
Kmvreter's Avatar
Kmvreter's Avatar
I know there is a lot of skepticism about this but like was said it can't hurt. I got it on sale. Finally getting around to posting the install pics.
Ran the wire to the back along the frame rail and attached the rear coupler pad on the inside sheet metal behind the jack/tools:
Electronic Rust Protection-t4rcounteract01-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 09-27-2006, 10:21 PM #11
Kmvreter's Avatar
Kmvreter's Avatar
Attached the front coupler pad on the passenger side in the engine bay ahead of the firewall:
Electronic Rust Protection-t4rcounteract02-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 09-27-2006, 10:28 PM #12
Kmvreter's Avatar
Kmvreter's Avatar
Mounted the control unit behind the fuse box. Cleaned up the wiring with wire loom and made the battery connections (may clean this up more by hiding the wiring more.)
I plan on running a long term test by mounting some professionally painted test panels (one grounded; the other insulated) just to see if there is any validity to what they claim.
Electronic Rust Protection-t4rcounteract03-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 09-27-2006, 11:59 PM #13
Mashimaru's Avatar
Mashimaru's Avatar
Looks exactly what i see on Guam based Toyota vehicles. I tell ya that ocean air is jus killer on our cars. Let us know how it goes Kmv, thanks for being the guinea pig hehe
Old 07-01-2010, 10:38 PM #14
CAHobbs CAHobbs is offline
CAHobbs is on a distinguished road
Long term update?
Hey KM
I think I just joined the club - I have a deposit down on an '07 Limited V8. The stealership graciously provided me with a way to give them more money, and I figure your 4 year run is a good test. Has it worked?
Chris
CAHobbs is offline   Reply With QuoteReply With Quote
Old 08-30-2010, 10:12 AM #15
Jed Jed is offline
Banned
Jed is on a distinguished road
Jed Jed is offline
Banned
Hmmm......lets bump this up and see if we get an update!
Jed is offline   Reply With QuoteReply With Quote
Rust beneath door handle(s) eliask08 4th Gen T4Rs 21 01-27-2022 04:09 PM
Rust Protection dustyjerry 4th Gen T4Rs 23 01-06-2022 07:02 PM
Need opinion! Undercoat? Paint protection? Plasmablade 5th gen T4Rs 9 04-23-2010 12:00 PM
Rust and rust prevention Thai Maintenance/Detailing 0 02-21-2007 10:58 PM
Noisy brakes? It could be rust. Thai Maintenance/Detailing 0 06-09-2003 11:21 AM
