Old 11-02-2016, 09:50 AM #1
Twhdvm Twhdvm is offline
Twhdvm is on a distinguished road
Simplifying oil changes
A guy I know just developed this cool device that simplifies oil changes. Check it out.
https://www.valvomax.com
Twhdvm is offline   Reply With QuoteReply With Quote
Old 11-18-2016, 02:48 PM #2
DisguisedRope's Avatar
DisguisedRope DisguisedRope is offline
DisguisedRope is on a distinguished road
So it's a knock off of the Fram sure drain...
I'll stick with the Fumoto Valve. Less pieces to lose, and I can still drain the oil without a separate tube.
2008 4Runner SR5 4.0 V6 4x4
Toytec Boss Suspension System with 2.5 Series Performance Coilovers; Skyjacker Extended Rear Sway Bar Endlinks; Ebay Uniball UCAs; Cooper Discoverer AT3s LT265/70/17; URD MAF Cal; URD Stainless 3" Mark3 Exhaust; aFe Stage-2 Pro DRY S Cold Air Intake; Black Headlight Mod; 5000K HID in Low Beams; 3000K HID in Fogs; 9011 HIR in High Beams; Weathertech in channel visors; 20% tint on front and over factory tint; 5% eyebrow on windshield; Plastidipped grill, badges, rear bar, wheels, etc.
DisguisedRope is offline   Reply With QuoteReply With Quote
Old 11-29-2016, 10:38 PM #3
Rwhockey29 Rwhockey29 is offline
Rwhockey29 is on a distinguished road
FRAM and Fumoto both already make options like this..
1999 Limited
Overland build in progress
Rwhockey29 is offline   Reply With QuoteReply With Quote
Old 01-30-2017, 12:20 AM #4
Nottoday Nottoday is offline
Nottoday is on a distinguished road
+1 Fumoto has worked flawlessly for me with several cars.
Nottoday is offline   Reply With QuoteReply With Quote
Old 04-30-2017, 06:57 PM #5
Herkdriver Herkdriver is offline
Herkdriver is on a distinguished road
Originally Posted by 4runnerguy1 View Post
I prefer the ValvoMax over others. I bought mine a couple months ago and it worked well. I'd be concerned the Fumoto lever would become jarred open during operation. I've heard reports of the Fumoto leaking.
Spammer. Same guy on several different forums hawking valvomax.
Herkdriver is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 01:31 PM #6
waterskier_erie waterskier_erie is offline
waterskier_erie is on a distinguished road
I installed a ValvoMax on my 2005 4runner about 3 months ago and so far so good with me.
I don't have any experience with Fumoto or Fram drains but the ValvoMax installed sits above the skid plate bottom so I like that it won't get bumped easily unless an obstruction happens to be pushed down by the skid plate first, then pops up and hits the valve in the skid plate opening.
I also like that I can direct the flow right into a collection jug with the included hose or add some extra hose if I need to go longer. The Fumoto doesn't easily allow this BUT the Fumoto does not require a screw on adapter to drain that could get lost, like the ValvoMax does.
The machining on the Valvomax is quality work but I had to laugh when the directions stated to use a torque wrench to install....the problem being that when the dust cap is removed the corresponding threads are larger than the 15/16" hex that sits below them to allow a deep well socket to be used. I had to use an open end wrench to install. If I wanted to get a true 90 orientation to the hex, it would have required me to remove my skid plate. Therefore, the long 15/16" wrench had to be at angle to connect. There are open end torque wrenches but they are very rare in comparison to standard ones with 3/8" or 1/2" ratcheting drives used for sockets that a lot of folks have in their toolboxes.
The valve likely starts as a large length of 15/16" stainless hex stock then machined down to final size (acme screw machine with bar stock feeder if I had to guess.) Stainless was quality grade with no magnetic attraction.
Anyone know how far the Fumoto sticks out from the pan?
For the record, I have no affiliation with any of the above companies or products....just relaying my experience for the group.
Thanks,
Ted
waterskier_erie is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 11:03 PM #7
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
The Fumoto doesn’t go below the skid plate if that’s what you mean, at least the F103S on my ‘07 V6 doesn’t.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 02-27-2019, 07:03 PM #8
Gauss Gauss is offline
Gauss is on a distinguished road
I have had fumoto valves for many years and love them. Never had a problem. I do wish my fumoto valve had a nipple though- I wasn't aware those were available when I bought mine.
Gauss is offline   Reply With QuoteReply With Quote
Old 02-27-2019, 10:37 PM #9
Jimmyasheville Jimmyasheville is offline
Jimmyasheville is on a distinguished road
What would be nice is, if the 4runner had the oil filter up top, in the engine bay, upside down like the BMW. Open the hood, unscrew the filter,no dripping, no mess, waist level, in the front of the engine bay. No messy paper core either.
Jimmyasheville is offline   Reply With QuoteReply With Quote
Old 03-16-2019, 12:45 PM #10
4th gen V6 4runner engines have exactly what you describe for the filter.
Old 03-16-2019, 01:15 PM #11
firemedicPQ1's Avatar
firemedicPQ1 firemedicPQ1 is offline
firemedicPQ1 is on a distinguished road
Same as the FJ Cruiser. I do miss that design. Not sure what Toyota was thinking with the current configuration (maybe they want you to go to the dealership). I am not impressed with my local dealership and won't be taking my 4R back there.
firemedicPQ1 is offline   Reply With QuoteReply With Quote
Old 08-18-2019, 09:43 PM #12
fringe fringe is offline
fringe has a little shameless behaviour in the past
he probably is the guy he knows lol
fringe is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 04:05 PM #13
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
I have a 4th gen V6. my oil filter is right on top and up front. I know how to use a wrench so I don't make any mess draining my oil. I guess those doodads a nice if you want them but they aren't even remotely necessary.
2008 SR5 4WD (@280k!!)
bob3dsf is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 04:16 PM #14
DBR4runner DBR4runner is offline
DBR4runner is on a distinguished road
I prefer the suction type devices. I stick a tube down the dipstick hole and vacuum the oil out. No need to get on the ground, pull the skid plate etc. Faster and cleaner. A good setup is only about $60.
DBR4runner is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 04:38 PM #15
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
The early FJ Cruisers may be that way- my 2011 certainly isn't- same PITA filter design as my 2019 4R. At least I only have to keep one type of filter on hand for both.
Sky is offline   Reply With QuoteReply With Quote
Simplifying Life with a 2012 4runner Limited (Hopefully) RubiconSS 5th gen T4Rs 12 08-24-2012 08:02 AM
