Old 01-22-2017, 06:40 AM #16
toyo's Avatar
toyo toyo is offline
Real Name: Steven
toyo will become famous soon enough
toyo's Avatar
Real Name: Steven
Have you checked the emergency brake shoes?
PCV Valve?
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
toyo is offline   Reply With QuoteReply With Quote
Old 01-22-2017, 01:08 PM #17
theladyviola's Avatar
theladyviola theladyviola is offline
theladyviola will become famous soon enough
Originally Posted by toyo View Post
Have you checked the emergency brake pads?
PCV Valve?
Great call on the emergency brake. Was able to trace back Toyota maintenance and see where rear pads/rotors were replaced but no mention of parking brake components. Unlike the 4Runner, I'm so used to having rear drum brakes that use the same shoes for the e-brake that I never thought about it.
PCV ✔️ Did that one when I cleaned the throttle bottle and did spark plugs.
You guys are great.
theladyviola is offline   Reply With QuoteReply With Quote
Old 01-31-2017, 11:38 AM #18
Any other opinions?
Old 01-31-2017, 11:46 AM #19
DEF4Runner's Avatar
DEF4Runner DEF4Runner is offline
DEF4Runner will become famous soon enough
DEF4Runner's Avatar
Front differential pinion bearing
Rear differential breather plug
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
DEF4Runner is offline   Reply With QuoteReply With Quote
Old 01-31-2017, 12:47 PM #20
TrueBlue's Avatar
TrueBlue TrueBlue is offline
TrueBlue is on a distinguished road
TrueBlue's Avatar
Just check for leaks. New axle shaft seals on the front diff never hurt along with new wheel seals. Jack her up and check for play in your wheels to see if your bearings are fine. I had a sleeper bearing go bad that didn't make any noise but I had half an inch or so of play in the wheel.
TrueBlue is offline   Reply With QuoteReply With Quote
Old 01-31-2017, 11:14 PM #21
I didn't have any play when I had it up on stands a couple months ago. I was surprised because I expected at least one (Murphy's law) to jiggle, but nothing thus far.
I picked up Toyota seal 90311-47012 and Timken seal 710573. I'm only dealing with the front driver's side. Do these look correct? Am I missing any?
Thank you!
Old 02-01-2017, 12:39 AM #22
TrueBlue's Avatar
TrueBlue's Avatar
Thank you!
I don't know of the part numbers off the top of my head Graciously Looking For Feedback On Upcoming Maintenance (what am I forgetting) I work at Oreillys so I get discounts on their parts so I went with national seals.. ones the shaft seal for the diff and the other is the wheel seal though right?
Old 02-01-2017, 12:45 AM #23
Yep! I would never have a check if I worked at an auto parts store.
Old 02-01-2017, 07:59 AM #24
toyo's Avatar
Real Name: Steven
toyo's Avatar
Real Name: Steven
Why are you changing the seals if they are not leaking? Unless I missed reading where you stated they are.
Old 02-02-2017, 12:31 AM #25
It's pretty much recommended if you're replacing/repairing the cv axle. If they don't get damaged during the removal, then it's peace of mind since you're right there.
Old 02-02-2017, 03:40 PM #26
TrueBlue's Avatar
TrueBlue's Avatar
I said it never hurts to change them. Never said it was a necessity unless they're already leaking
Old 02-05-2017, 07:45 AM #27
toyo's Avatar
Real Name: Steven
toyo's Avatar
Real Name: Steven
I didn't see where you were pulling them. My bad.
Old 02-05-2017, 08:26 AM #28
No worries. I'd just hate to pull the cv and do all that, put it back together and wish I had changed them.
Old 02-15-2017, 11:04 AM #29
Updated.
Old 03-04-2017, 02:46 PM #30
Can't believe I'm finally going to start my stay-cation next week and get rolling on this list!
Graciously asking 4 help w/ headlight assembly removal johnsontl002 4th Gen T4Rs 4 09-03-2014 09:48 PM
Anything I'm forgetting? Preventative maintenance at 200k miles... the rizz 4th Gen T4Rs 9 11-05-2013 04:04 PM
Potential Upcoming Maintenance v2kea412 4th Gen T4Rs 4 03-03-2013 07:50 PM
Upcoming Major Maintenance ???'s Mf Baker 3rd gen T4Rs 6 11-19-2011 04:40 AM
Need some help with upcoming maintenance Tejas_Runner Maintenance/Detailing 3 09-21-2009 09:16 AM
