Old 06-11-2017, 12:00 PM #1
46runner's Avatar
46runner 46runner is offline
46runner has a spectacular aura about 46runner has a spectacular aura about
46runner's Avatar
DIY Rear Axle Seal and Parking Brake
My write up on replacing the rear axle oil seal and the parking brake.
PSA: check your breather plug. It's a simple fix.
Thanks to:
HokieRunner's 4th Gen 4Runner Rear Brake Rotor and Pad DIY
Mr.emergency's 4th Gen Rear Wheel Bearing DIY
fdbyrne for the virtual assist.
DIY Rear Axle Seal and Parking Brake-slide01-jpg
DIY Rear Axle Seal and Parking Brake-slide02-jpg
DIY Rear Axle Seal and Parking Brake-slide03-jpg
DIY Rear Axle Seal and Parking Brake-slide04-jpg
DIY Rear Axle Seal and Parking Brake-slide05-jpg
DIY Rear Axle Seal and Parking Brake-slide06-jpg
DIY Rear Axle Seal and Parking Brake-slide07-jpg
DIY Rear Axle Seal and Parking Brake-slide08-jpg
post continued below...
46runner is offline   Reply With QuoteReply With Quote
Old 06-11-2017, 12:02 PM #2
46runner's Avatar
46runner's Avatar
DIY Rear Axle Seal and Parking Brake, continued
DIY Rear Axle Seal and Parking Brake-slide09-jpg
DIY Rear Axle Seal and Parking Brake-slide10-jpg
DIY Rear Axle Seal and Parking Brake-slide11-jpg
DIY Rear Axle Seal and Parking Brake-slide12-jpg
DIY Rear Axle Seal and Parking Brake-slide13-jpg
DIY Rear Axle Seal and Parking Brake-slide14-jpg
DIY Rear Axle Seal and Parking Brake-slide15-jpg
DIY Rear Axle Seal and Parking Brake-slide16-jpg
Post continued below...
Old 06-11-2017, 12:04 PM #3
46runner's Avatar
46runner's Avatar
DIY Rear Axle Seal and Parking Brake, post 3 of 3
DIY Rear Axle Seal and Parking Brake-slide17-jpg
DIY Rear Axle Seal and Parking Brake-slide18-jpg
DIY Rear Axle Seal and Parking Brake-slide19-jpg
DIY Rear Axle Seal and Parking Brake-slide20-jpg
DIY Rear Axle Seal and Parking Brake-slide21-jpg
DIY Rear Axle Seal and Parking Brake-slide22-jpg
DIY Rear Axle Seal and Parking Brake-slide23-jpg
DIY Rear Axle Seal and Parking Brake-slide24-jpg
Old 04-24-2019, 08:01 PM #4
ThatguyJZ ThatguyJZ is offline
Real Name: Jim
ThatguyJZ is on a distinguished road
Real Name: Jim
Big thanks for this thread.
I would like to add it is possible to do the axle seals WITHOUT removing the rear parking brake shoes and hardware.
Yes, that's right. The most tedious part of this whole process is not actually necessary.
Unbolt the brackets securing the parking brake cable to the frame. 4 total on passenger side and 3 on driver's side. This will provide you with just enough slack to get the axle out.
I did run into an issue on my driver's side where when I was removing the rotor, the parking brake shoes were sticking to it and preventing me from getting it off cleanly. Once I finally removed it, it had undone those spring clips in the process and made a smooth easy job hard.
Let's hope now all is good and no more leaks
- 2014 Magnetic Grey Metallic Tacoma 4x4 TRD Offroad -
- 2008 Natural White 4Runner SR5 4WD -
- 2001 Black Onyx Lexus IS300 -
ThatguyJZ is offline   Reply With QuoteReply With Quote
Old 05-08-2019, 01:38 PM #5
mitchell.marsh mitchell.marsh is offline
mitchell.marsh is on a distinguished road
I noticed few days back that my driver’s side rear axle seal had given up the ghost and I started doing my research on how to go about fixing it. Everything that I learn in the process, I will add to this post. I haven’t found a good write-up on this on T4R.org. Most of what I learned came from a variety of write-ups I found on YT, via Google, talking to several mechanics, and now personal experience.
mitchell.marsh is offline   Reply With QuoteReply With Quote
Old 04-24-2020, 01:02 PM #6
fastbroshi fastbroshi is offline
fastbroshi is on a distinguished road
Can someone else verify if this job is possible without removing the parking brakes? I need to do my seals soon.
fastbroshi is offline   Reply With QuoteReply With Quote
Rear Axle Seal: Axle Puller Tool Design nobb 3rd gen T4Rs 29 11-23-2019 07:39 AM
Rear Axle seal? Gadgetguy 3rd gen T4Rs 18 08-01-2016 04:01 PM
Rear axle seal help Asaspades93 3rd gen T4Rs 16 09-15-2014 03:20 PM
Rear brake and axle seal OEM NEW parts EricG For Sale: T4R Items 9 01-03-2012 04:28 PM
rear axle seal VA4runnerchic 3rd gen T4Rs 64 12-01-2011 09:09 PM
