Old 06-11-2017, 01:53 PM #1
monnone monnone is offline
monnone is on a distinguished road
5th Gen Alternator Replacement
Hey everyone! I could use some help/advice on replacing my alternator. The only thing holding me back from removing the unit is the bracket holding the backside of the alternator to the engine. I am missing something here...I can't figure out how to get to that back bolt.
I have the harness off and the two main bolts off...that very back-side bolt/bracket is the only thing holding me back.
Does anyone here have any suggestions? I'd really appreciate it!
monnone is offline   Reply With QuoteReply With Quote
Old 06-11-2017, 07:36 PM #2
I got the bolt out with a series of extensions and swivel joints and was able to remove the alternator but it sure seems like there should be another method. Plus getting the bolt BACK in place seems like it's going to be particularly difficult given it's location.
Anyone done this and have any tips?
Thanks!
Old 06-11-2017, 07:51 PM #3
Antman's Avatar
Antman Antman is offline
Real Name: Jeff
Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all Antman is a name known to all
Antman's Avatar
Real Name: Jeff
Thanks!
That's how I did it. Wear some good gloves is my tip! I smashed the hell out of one of my fingers when the swivel joint let loose. Getting it in was easier, just make sure you get the hole lined up PERFECTLY.
It's a *****. Good Luck.
HERE FISHY FISHY FISHY!
Antman is offline   Reply With QuoteReply With Quote
Old 06-11-2017, 08:16 PM #4
Ok, good to know I'm on the right track. Thanks for the input!
Old 08-03-2019, 05:22 PM #5
leered leered is offline
leered is on a distinguished road
My battery barely turned the engine (2012 T4R LTD) last Monday. Having this battery for over 3 years, I thought it's time for a new one ( bought one but didn't install because I wanted to make sure it is not the alternator causing this).
It turned out battery was only 60% charged . Charged overnight and passed testing the next day ( fully charged). However, I noticed my battery/alternator gauge is a little to the left from the mid line ( 14V) and using a voltmeter confirmed a 13.6-13.8V ( under the expected 14v+). Under load ( AC ON+ FAN @MAX+ HEADLIGHT ON) voltage at battery is 13.58V
Local AutoZone testing of the charging system showed PASS while O'reilly's test returned: REGULATOR FAIL then ALL PASS,.. REGULATOR FAIL.. then ALL PASS...then REGULATOR FAIL.. didn't help at all!
Just replaced the alternator with a Denso Reman and the voltage is 13.6V ( outside temp 99 F)- just like the OLD one!
On Vehicle NEW alternator test @ local O'reilly says REGULATOR FAILED. The old alternator PASSED the bench test ( at O'reilly ! This makes no sense, unless their diagnostic tool is bad .
With the old alternator, I've noticed in the morning ( cooler outside) the voltage is 14V+ while at noon or after driving a while, the voltage goes to 13.6V . Suspected a heat-related issue with alternator/regulator and trying to avoid getting stuck due to a near future alternator-issue, decided to replace it .
During the week I searched but I couldn't find any info on 5th gen T4R charging system. Today, one of the searches returned an article about Alternator Testing and it looks like the alternator output voltage is temperature-dependent. This means that my 13.6V at 99F (14.2V at 68F) is actually OK.
I'm hoping someone can confirm the normal voltage for the charging system . Could not find this or a diagram using Google searches ( at least not for 5th genT4R).
BTW, I've attached pics of the "PITA" rear bracket hoping it will come in handy for the next DIY-er I know I had a hard time just finding the bracket!
Note: I had to remove front/driver side tire to be able to see/access bracket /bolts.
Thanks !
5th Gen Alternator Replacement-2012_t4r_alternatorrearbracket_top_view-jpg  5th Gen Alternator Replacement-2012_t4r_alternatorrearbracket_driver_side_view-jpg
leered is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 08:11 AM #6
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Your charging voltage of 13.6VDC is normal. Sounds like your battery is getting sucked down while the vehicle sits overnight...the term is "parasitic draw". Do you have any aftermarket electronics wired into it that might be causing this?
waypoint is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 05:19 PM #7
I would not say the battery is drained overnight. In fact, the battery is "normal" after the 1 charge I did 1 week ago. I can tell the car starts as it should.
I've never had the battery noticeably low until last week. Now that I know the alternator is working as expected, I suspect it is my short commute ( 15 min) that could "contribute" to the slow battery discharge. I did notice my interior lights mounted on the trunk door were ON, but I believe all interior lights are turned off automatically, when you lock car/arm alarm. Turned them off just to make sure.
The only aftermarket device is an alarm. Installed it over 2 years ago though....
Thank you very much for taking the time to reply!
Old 06-20-2020, 11:52 PM #8
AudioConnect_T4R AudioConnect_T4R is offline
AudioConnect_T4R is on a distinguished road
Just replaced my factory alternator with a Mean Green alternator on my 2019 SR5, thank God for this thread or I would have never found that stupid bracket on the bottom. Every video I found and watched didn't mention this bracket. Thanks everyone.
AudioConnect_T4R is offline   Reply With QuoteReply With Quote
Old 08-08-2022, 07:20 PM #9
psea17 psea17 is offline
psea17 will become famous soon enough
how's the mean green working for you?
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 12-10-2022, 12:35 PM #10
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Thanks !
I can't figure out how the harness comes off the alternator. Removed two 10mm bolts on the alternator which loosened the lower portion of the harness, but can't figure how it comes off the plug.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 12-16-2022, 04:39 PM #11
CCAZ_Ltd's Avatar
CCAZ_Ltd CCAZ_Ltd is offline
CCAZ_Ltd is on a distinguished road
CCAZ_Ltd's Avatar
Is it necessary to re-attach the bracket on the back?
CCAZ_Ltd is offline   Reply With QuoteReply With Quote
Old 01-23-2024, 02:18 PM #12
FifteySeven FifteySeven is offline
FifteySeven is on a distinguished road
Thanks !
How necessary is this bracket for the alternator? I just replaced my alternator last night and thanks to this post I was able to find this bracket to replace. I was having such trouble moutning bolt #2 in the diagram above back on I just said screw it and left it without the bolt. #1 is installed on the alternator.
I hate leaving an installation project with more hardware than I started, but for the major pain it was, I'm wondering how needed that bracket is. Any help would be appreciated. Thank you!
FifteySeven is offline   Reply With QuoteReply With Quote
Old 01-23-2024, 02:20 PM #13
CCAZ, did you find out an answer? I am wondering the same thing. Did you replace yourself and have similar issues? Thanks!
Alternator bearing replacement? Nelsonmd 3rd gen T4Rs 22 12-25-2017 03:31 AM
Alternator replacement oem or aftermarket jonb2 4th Gen T4Rs 7 08-12-2016 09:13 AM
alternator replacement tek9 3rd gen T4Rs 12 11-04-2012 01:26 PM
Replacement Alternator markopolo 3rd gen T4Rs 5 01-11-2012 03:28 PM
Alternator Replacement AK Kilted Guy 3rd gen T4Rs 2 02-14-2010 12:28 AM
