Thread Tools Rating: Thread Rating: 186 votes, 2.55 average. Display Modes
Old 11-28-2017, 01:44 PM #16
ToyoT4R's Avatar
ToyoT4R ToyoT4R is offline
ToyoT4R will become famous soon enough
ToyoT4R's Avatar
Interesting real world test video. The guy used some metal samples mounted on his frame.
https://youtu.be/4npPOrVtjyc
2017 TRD Pro, Cement
ToyoT4R is offline   Reply With QuoteReply With Quote
Old 11-30-2017, 11:49 AM #17
TrexRunnerGirl's Avatar
TrexRunnerGirl TrexRunnerGirl is offline
Real Name: Teri
TrexRunnerGirl is on a distinguished road
Real Name: Teri
following along. I know what I'll be doing this spring.
TrexRunnerGirl is offline   Reply With QuoteReply With Quote
Old 01-02-2018, 06:21 PM #18
ADK Explorer ADK Explorer is offline
ADK Explorer is on a distinguished road
In hopes of preventing rust as long as I can on my 2016 I sprayed 3 coats of Eastwood Internal Frame Coating inside my frame rails, cross members and lower A arms. This took 10 cans. Where I see rust starting I sand it out and repaint with Eastwood Rust Encapsulating paint. On top of all this I sprayed the crap out of everything metal underneath the truck with Fluidfilm. My sliders rusted out pretty bad last winter despite being painted with (Not) Rust-Oleum. Took them off, ground out the rust and repainted with Eastwoods and sprayed with copious amounts of Fluidfilm. I used 3 cans of FF which I pickup locally at Lowe's hardware. As you know we're having a good ole fashioned hardcore winter so we'll see in the spring how well this works. I am mixed about pressure washing on a regular basis during the winter as I usually do because I don't want to blast off all the Fluidfilm.
2016 TRD Pro: Husky Weatherbeaters \ ARB Breather \ RCI Sliders & belly Skids \ C4 Fab Tank Skid \ Engo 9000S Winch on Pelfrey Hidden Mount
The Tanks Mods & Adventures http://www.toyota-4runner.org/5th-ge...-my-build.html
ADK Explorer is offline   Reply With QuoteReply With Quote
Old 01-02-2018, 06:26 PM #19
Just watched this. Answers my question about pressure washing. Thanks.
Old 05-23-2018, 12:03 PM #20
lunchboxtheman lunchboxtheman is offline
lunchboxtheman is on a distinguished road
I used a single rattle can of fluid film in the fall and was impressed with the results. You can see in the attached pic that the areas that I sprayed had very little road salt stick to them, whereas the areas that I didn't spray appear white from all of the salt.
As of this spring, there is no visible rust anywhere that I sprayed. There is still a thin layer of goo on most of the places I sprayed. I'll probably get a compressor and sprayer for this fall to get more complete coverage.
WARNING: I took my car in for my first "free" oil change and the tech diagnosed a "massive fluid leak" in the front diff. They wanted to do a complete rebuild of the front diff to change a seal between the two halves of the diff housing. I got underneath the truck and didn't notice any leaks. I suspected that the tech misinterpreted the fluid film as a leak and I requested a master tech to give it a second look. Master tech confirmed there was no leak. Just something to keep in mind if you take your truck in for service and have sprayed. (funnily enough, they said I could continue to drive it despite having no diff fluid ).
lunchboxtheman is offline   Reply With QuoteReply With Quote
Old 08-20-2018, 03:56 PM #21
lobody94 lobody94 is offline
lobody94 is on a distinguished road
I can vouch for fluid film. This stuff is gold! I bought my 02' 4Runner in February 2008 and immediately coated with fluid film. At that time the frame was still pretty clean and rust free. I have applied fluid film a few times since then and this thing is still super rust free. I live in Ohio and almost every 4Runner or Tacoma a see is full of rust.
I just bought a 2018 4Runner and will be coating it in the next few weeks. I can only imagine how good starting with fluid film this early will do.
lobody94 is offline   Reply With QuoteReply With Quote
Old 10-18-2020, 10:48 AM #22
legrena's Avatar
legrena legrena is offline
legrena is on a distinguished road
legrena's Avatar
That's a really good testing results video. Stoner jam background tune if good, too.
legrena is offline   Reply With QuoteReply With Quote
Old 11-02-2020, 03:29 PM #23
gp55445's Avatar
gp55445 gp55445 is offline
gp55445 is on a distinguished road
gp55445's Avatar
I also spray some FF in the doors, hood, and rear tailgate weep holes just in case.
gp55445 is offline   Reply With QuoteReply With Quote
Old 01-05-2023, 09:53 PM #24
ebrinker ebrinker is offline
ebrinker is on a distinguished road
Fluid Film on matte black textured powder coat
Hey all: anyone ever have any issues with fluid film on powder coated steel bumpers? I haven’t found anything online that says it hurts the powder coat but interested what folks think and whether it is safe to use on powder coat as a preventative measure from winter and salty roads, when rocks chip the coating and expose metal. Thanks!
ebrinker is offline   Reply With QuoteReply With Quote
Old 06-26-2023, 03:19 PM #25
DWilliam DWilliam is offline
DWilliam is on a distinguished road
I’m learning so much from this forum, thanks for sharing!
DWilliam is offline   Reply With QuoteReply With Quote
Old 09-28-2023, 03:40 PM #26
kirdtheape's Avatar
kirdtheape kirdtheape is offline
kirdtheape is on a distinguished road
kirdtheape's Avatar
Fluid Film Real World Test: Michigan Winter vs Truck Frame - YouTube
Given the results here it looks like fluid film washes off fairly easily. Especially if you plan to use an undercarriage pressure washer attachment for removing salt. My line of thinking is to apply fluid film to the inside of the frame only in the fall, where it will protect but not be washed off, then to use the pressure washer undercarriage attachment year round but especially after snow storms where salt has been applied.
Alternately you could apply fluid film everywhere under the truck (body and frame) and then skip the undercarriage wash but you would have to be very confident that you applied the fluid film it very thoroughly. I'm not that confident . Do people here use undercarriage washing after applying fluid film?
kirdtheape is offline   Reply With QuoteReply With Quote
Old 01-01-2024, 06:01 PM #27
bninja bninja is offline
bninja is on a distinguished road
Just brought an '07 4Runner from Texas to the rustiest part of the rust belt. Absolutely amazed at how clean this thing is underneath. That said I'm doing everything I can to keep it that way.
I can't speak on how well fluid film holds up to undercarriage washes but my guess would be not too well, especially after multiple washes. High pressure and soap will definitely take it off.
On reading this and other threads it seems a lot of car washes recirculate water which can get even more salt in places we certainly don't want it. My local car wash doesn't offer touchless without undercarriage so my move is suck it up and use the manual bays. Tends to yield better results and is a bit more cost effective as well (just not much fun in the winter).
Side note, I know this is a 6+ year old thread but as always big thanks to the community for all the info. Really like the way the black FF turned out!
bninja is offline   Reply With QuoteReply With Quote
Another Transmission Fluid Thread... Mel0 3rd gen T4Rs 18 12-09-2016 11:10 AM
Fluid Film PSA A10GAC General Discussions 1 08-27-2016 01:25 PM
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
3rd gen in film riceandpho General Discussions 19 11-17-2009 04:59 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
