08-21-2018, 04:21 PM
#16
I strongly recommend this paint coating........... https://www.autogeek.net/nano-paint-sealant.html
Its reasonably prices, fairly simple to put on, and it has truly lasted a year. I am VERY particular about sealing and coating my paint and this has been the best and most durable product I've ever used. All the work is in the prep but why let all those hours of anguish go to waste without putting an excellent product on top.
Plenty of youtube videos to support the product also.
2019 Subaru Outback Limited 3.6 - Silver (replaced 2016 Trail Premium w/KDSS)
2007 V8 Sport 4Runner - Magnetic Gray
"A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty" - Winston Churchill
08-21-2018, 09:59 PM
#17
Real Name: Chris
Real Name: Chris
Originally Posted by MSRP.
Sorry, but no that's not true (for 99% of those reading this), what paste wax do you use?
Unless you're using Collinite or a handful of "online only" specialty paste waxes that are durable, you're maybe getting 30-60 days of real protection.
Please don't say nu-finish or anything that you can get from a local walmart/advanced auto.
If you go through the effort of paste wax, just understand that there are sealants and semi-permanent sealants that take less time to apply (not including the spray and rinse coatings) which will last 6-24 months depending on your local weather conditions.
As you said, your truck, do what makes you happy. A 4runner will probably take you just over 30 minutes start to finish with a paste wax (if you are quick) that will last, optimistically, 90 days. A sealant like collinite/Mckee's will be marginally quicker to apply but last you 6-24 months. A spray and rinse sealant will take you 2 additional minutes to incorporate into a regular car wash and last you 90 days. I clay with a clay sponge which is marginally quicker than regular clay too.
This is all assuming you wash properly, and are able to avoid wash-induced swirls and marring. If you have a brand new truck and want ot keep it that way, your #1 priority is to avoid touching the paint as much as possible. The old ways of paste waxes that need buffing, bead water instead of sheeting would be a point of contact that I would recommend skipping to put off the need to machine polish the paint. (if that is your goal)
Meguiars yellow 26 paste wax. I'm 6 months in and water still rolls off the paint. You're opinion is yours however your spray on way will not hold up as long as this.
08-24-2018, 04:31 PM
#19
Real Name: Chris
Real Name: Chris
Maybe so however I clay and wax every 6 months. This holds up just fine between waxes.
08-26-2018, 10:49 AM
#20
I haven’t tried #26 yet but IIRC it’s carnuba plus synthetic stuff which may help its longevity. I’ve always seen positive reviews for it. P21s on the other hand doesn’t last nearly as long for me but it looks amazing while on there.
08-27-2018, 04:22 PM
#21
No shortcuts
Well someone told me about this product #topcoat-f11 and I was like no way. If you ever heard of this product, again no way. Most polishes these days are pretty good and just require a little elbow pressure and focus so just thought I would share the knowledge. Happy detailing to you all!
https://www.youtube.com/watch?v=DBCGgUgvYs0
'04 SE 4WD V6 Pacific Blue Metallic | Stock | Tires+Wheels/Lift Kit | Underbody Coat/Armor Protection coming FALL '17
09-09-2018, 08:12 PM
#22
Do you use the same clay bar after a few uses or do you throw away and get new? I throw away after 3 or 4 jobs do to the fact that the clay bar has a lot of contaminants in it. Just my theory.
09-22-2018, 08:18 PM
#23
Waxing After Clay Bar
Well, it depends yes on the heaviness of use. I really don’t throw them away unless
Dropped
Using on multiple cars
Extreme contaminates build up from tar/sap/etc
What I use the old ones that pass 3-4 times of use is on spots like near the mud guards, lower door panels. Then, I use older piece on wheels ONLY!
Clay bar is something of like a scalpel and should only be used under extreme conditions. On personal vehicles I use clay bar maybe every 2 years. I keep a few layers on polish and sealant on my paint throughout the year due to the beating it takes from sun, rain, and mud/debris on trails.
Before doing this one should sit and plan their vehicle clean and paint correction regimen.
Hope that helps! Happy cleaning, paint correcting, polishing, waxing!
01-01-2019, 05:18 PM
#24
As a pro detailer, I rinse after claying and use an Isopropyl alcohol solution to prep the paint for the wax. Surface prep is 90% of the key to success in auto detailing.
01-30-2019, 05:45 PM
#25
I agree with the post above, prep and keeping up with washing is the best prep. I have had great success with 3M Marine Ultra Performance Paste Wax. This goes on easy, comes off complete with micro fiber rags and looks great. Being designed for marine, it handles really tough conditions well. This was suggested to me several years ago by a detail guy and I have not been disappointed or found anything better. I use Adams and Chemical Guy products with success, but for pure waxing the 3M product has been great.
01-30-2019, 06:00 PM
#26
+1. The importance is that you have a well prepped surface after claying--this could be achieved by a wash, post-clay wipe down, or both. I try to do both if time permits (post-clay wash, then wipe down).
If you're committed to using a wax as opposed to a polymer or ceramic coating, you could follow this process:
Wash
Clay
Wash
IPA wipe down
Polish (optional, depending on condition of paint and/or personal preference)
Sealant (optional)
Wax
Depending on the level of contamination, you might be able to consolidate the first few steps by using a clay wash mitt.
While Meguiars makes great products, I personally prefer Collinite 845 wax.
02-02-2019, 09:51 AM
#27
Wash
Clay
Wash
IPA wipe down
Sealant (optional)
Wax
I would never have thought to use IPA on the paint. Seems like it would have too strong of a drying effect and suck some life out of the paint/clear coat. I guess not though! But I won’t try it, my routine seems to work fine without as I try to minimize steps
02-06-2019, 01:39 PM
#28
Sorry for the late response. I should clarify that IPA is often diluted and not used at full strength.
There are ready to use solutions made specifically for detailing that can be used instead of a diluted IPA solution, such as CarPro Eraser.
02-06-2019, 02:00 PM
#29
Real Name: Eddie
Real Name: Eddie
Can someone offer some suggestions on this? Looking for product recommendations and tips.
Thanks all.
Wash (two bucket method using Dawn)
Clay (will use a clay bar and I got this)
Wash (new water and Dawn)
IPA wipe down (what % IPA? How much to dilute?)
Polish (What brand?)
Sealant (What brand?)
Wax (going with 3M 09030 Marine Ultra Performance Paste Wax)
Any sealant/protector/extender needed after the Wax step?
Eddie
2001 T4R SR5 - 180k miles and counting.
02-06-2019, 02:38 PM
#30
AKA, do the same thing but pay 10x the cost.
Thanks all.
Eddie
Go on youtube, there's 20 ways of saying the same thing.
IPA wipe down not really necessary after you clay, before you polish.
Polish/compounding without a machine is just about pointless.
Sealant/Wax are just about interchangeable, you don't really need both.
No experience with your 3M wax, if it lasts at least 6 months, you're good. If that's all the durability you get from it, you can get the same results with 80% less work in a hybrid ceramic coating/Si02 type of coating. Again, lots of vendors producing a very similar product. Most are under $20 for a 16oz bottle.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
waxing!
Wonderbreadman |
5th gen T4Rs |
6 |
07-15-2011 05:28 PM |
Waxing ?
westwind77 |
5th gen T4Rs |
11 |
01-06-2010 09:48 AM |
waxing
LBeard87 |
Maintenance/Detailing |
7 |
04-22-2009 06:40 AM |
Waxing around the badging, how?
scott78945 |
9 |
05-11-2005 06:25 PM |
How long before waxing?
DocData757 |
3 |
10-24-2003 12:55 PM |
